04-14-2014, 18:56 | #16 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
POST SCREENSHOOT of Device Manager, Sw Atf open in Nokia tabulate and Full Log of all operation if want to be helped, w/o log and screen you can do anythingh of wrong.... | |
04-15-2014, 14:52 | #17 (permalink) | |
No Life Poster Join Date: Jan 2011 Location: Cuba
Member: 1484663 Status: Offline Thanks Meter: 344 | Quote:
04-15-2014, 23:38 | #18 (permalink) |
Member: 1484663 Status: Offline Thanks Meter: 344 | NOT working! I unnistal all ATF drivers with the little command batch file included in the 11.20 installer. Installed all from 0 and nothing. I say it's a server problem with my SN. What now? Here's my SN :BF39A50589585B6DC6B6F38A |
The Following User Says Thank You to Bscaine For This Useful Post: |
04-16-2014, 09:43 | #21 (permalink) | |
Please try to install ALL in other pc...you had tryed always in this pc where is possible you have other many Box installed...try in other pc installing all... | |
04-21-2014, 13:56 | #22 (permalink) | |
And yet my ATF Nitro can't Update-Restore. What now?!! | |
04-21-2014, 15:58 | #23 (permalink) |
No Life Poster Join Date: Dec 2001 Location: 127.0.0.0.1
Member: 8133 Status: Offline Thanks Meter: 72 | You have Team Viewer? Let me help if i can. Seems the mods here dont like to help via Team Viewer....I just replaced a ATF box i thought was faulty after changing all sorts of drivers, and in the end it was the way the drivers were SETUP. If an ATF mod had logged in via Team Viewer (like i asked them too) and spotted it, i would of saved the expense of another ATF box |
04-22-2014, 09:03 | #24 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IN GSM
Member: 304574 Status: Offline Sonork: 100.1593675 Thanks Meter: 72 | plz mod see my problem give solution plz http://forum.gsmhosting.com/vbb/f609...-only-1805408/ thanks |
04-22-2014, 12:58 | #25 (permalink) | |
04-23-2014, 04:14 | #26 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Did you miss Post #12 here? http://forum.gsmhosting.com/vbb/10225086-post12.html I already said, ERROR 6 is possible HARDWARE PROBLEM which YOU CAN FIX if you OPEN BOX and make sure all LEGS of the 2 ICs are connected properly on the PCB. or Return Box to reseller if still under warranty, ask reseller to CHECK it himself. Either way, ERROR 6 is EASY to fix via HARDWARE. B.R. | |
04-23-2014, 05:17 | #27 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 433942 Status: Offline Thanks Meter: 35 | Quote:
i Face This. 4:15:53 : Advance Turbo Flasher Found 14:15:53 : ================================================ 14:15:53 : Driver Version : 00020817 14:15:53 : 14:15:53 : ############################################# 14:15:53 : ############################################# 14:15:53 : ERROR: Please Update ATF USB Drivers! 14:15:53 : ############################################# 14:15:53 : ############################################# How To Solve it ? Thanks In Advanced.... | |
04-23-2014, 09:05 | #28 (permalink) | ||
You problem not see that the same SW answere for you?.... Quote:
Br allumts | ||
04-23-2014, 10:47 | #29 (permalink) | |
Any link plz. | |
