03-24-2014, 08:38 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Remove ATF drivers using this file: Remove_atf_driver.bat inside Drivers folder. Remove ATF software installed in PC Restart PC Install only ATF full installer v11.10 Connect Box and Install New atf drivers from Drivers folder Put AdvanceBox.exe into your antivirus program's Exclusion List Put AdvanceBox.exe into your windows firewall's Exclusion List After doing all the steps, run software and it should work properly. If still you got Not Responding error, then pls check on other windows/PC |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
