Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Temporary banned !! ![]() ![]() ![]() ![]() Join Date: Feb 2010
Member: 1231949 Status: Offline Sonork: 12 Thanks: 116
| why the PSW codes is wrong when phone is not connected ?? hello ATF Team i have a question please when i try to calculate the master code to 15-digit NCK , all the PSW codes is wrong when phone is not connected to ATF can you fix this problem?? hope you understand me thanks BR |
| | #2 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2006 Location: Karachi, Pakistan Age: 22
Member: 643472 Status: Offline Sonork: 100.96901 Thanks: 6
| Hi, You must have made something wrong. Its working fine. Post your master code and IMEI here. I calculate code for you. BR |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 626209 Status: Offline Thanks: 6
| Hi. You MUST be doing something wrong. I use ATF to calculate NCK even when I have the phone and every single time codes work. Do as instructed in the previous post and we will help you. |
| | #6 (permalink) |
| @medie Post here logs of error you are getting. However, its already simple .. Put Master Code in text box of it and click "MasterCode to15 digit NCK" You will be asked if phone is connected or not - if not connected - click No - and write 15-digits IMEI of your phone. Codes will be calculated ! |
| | #7 (permalink) |
| for exemple Imei: 354857046688656 Master Code: 070401080903070903070302010808 Log: Code:
Calculated NCK Codes For 070401080903070
Calculating Codes... Please Wait a while...
Lock Type 15-digit NCK
Level 1 [MNC+MCC ] #pw+672521410488731+1#
Level 2 [GID1 ] #pw+922262360756413+2#
Level 3 [GID2 ] #pw+989312286610488+3#
Level 4 [MSIN ] #pw+967668745437210+4#
Level 5 [MNC+MCC+GID1 ] #pw+557394554004070+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+615981358295322+6#
Level 7 [ALL SIMLOCK(s) ] #pw+922765850572742+7#
Click "Manual Send Unlock Code PSW" Button
to send Unlock Codes to Phone via FBUS...
If the phone does not accept Level 7 Codes,
try using Level 1 Codes to unlock the Phone... the correct codes calculated with another tool is: #pw+062478500710075+1# #pw+816986866508874+2# #pw+363708716449277+3# #pw+634256185001081+4# #pw+447487711672185+5# #pw+386006244216369+6# #pw+795944035653836+7# the problem Mr ANGEL , is when i want to recalculate the NCk another time with ATF , i will get always another code Please , try to fix this problem Thanks BR |
| | #8 (permalink) |
| Hi, As expected, here is the problem: Code: Calculated NCK Codes For 070401080903070 In this image, for example, imei is: 123456789012345 but you will write your phone's IMEI of 15 digits. |
| | #9 (permalink) |
| thanks for reply mr angel this is the log of two time trying to get the correct code ; the result is the same log Code: ================================================
Calculated NCK Codes For 35485704668865
(the software request to digit the first 14 digits of phone IMEI)
Level 1 [MNC+MCC ] #pw+056886802242825+1#
Level 2 [GID1 ] #pw+399276293832006+2#
Level 3 [GID2 ] #pw+842454590778659+3#
Level 4 [MSIN ] #pw+906576846564115+4#
Level 5 [MNC+MCC+GID1 ] #pw+869353119906486+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+294318748248615+6#
Level 7 [ALL SIMLOCK(s) ] #pw+756300931351586+7#
Calculated NCK Codes For 354857046688656
when i try to digit all 15 digit of phone imei, the result is same
Level 1 [MNC+MCC ] #pw+749228044317888+1#
Level 2 [GID1 ] #pw+662140928450658+2#
Level 3 [GID2 ] #pw+733578166209130+3#
Level 4 [MSIN ] #pw+510104805600270+4#
Level 5 [MNC+MCC+GID1 ] #pw+441171585963574+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+308381607858694+6#
Level 7 [ALL SIMLOCK(s) ] #pw+500005718879303+7#
try using Level 1 Codes to unlock the Phone... log Code: ================================================
Level 1 [MNC+MCC ] #pw+630128657584532+1#
Level 2 [GID1 ] #pw+406486173338652+2#
Level 3 [GID2 ] #pw+729257482215758+3#
Level 4 [MSIN ] #pw+968813326868180+4#
Level 5 [MNC+MCC+GID1 ] #pw+130344899699893+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+529508398460781+6#
Level 7 [ALL SIMLOCK(s) ] #pw+634183298666907+7#
try using Level 1 Codes to unlock the Phone... Please , can you try on your software to confirm that?? thanks BR Last edited by hadjimi; 05-04-2012 at 19:37. |
| | #10 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 651945 Status: Offline Thanks: 19
| It has been posted many many many many many ... many many times... That ATF will give you 1000 (YES ONE THOUSAND) different NCK codes for your phone and all 1000 (YES ON THOUSAND) codes are 100% correct. Why 1000 different Codes??? Because ATF Software simulates a different 3-digit Random Number everytime you click the CALCULATE CODES button. This 3-digit RANDOM NUMBERS are probably some SX-5 serial numbers, but it is actually not confirmed but just assumed... Long story short... each SL3 phone will accept 1000 (YES ONE THOUSAND) possible NCKs that will unlock itself. All 1000 (YES ONE THOUSAND) NCK CoDES are correct and will 100% unlock the phone if entered correctly. B.R. |
| | #11 (permalink) |
| Thanks for reply Sir i said this problem is success with me many times and with many phones, and all codes not work when phone is not connected, i have tested to digit manually in the phone , and try the manual send unlock code with the software , but the result is all time (wrong code) Note: when phone is connected ; i can try 1000 times , i will get always the same 7 codes working correctly , it is tested when i try to calculate with another software (ex. HTI) ; all times i get the same 7 codes , and all codes work perfectly I have no doubts about your Software , for me it is the best in the market But, You can try if you want to confirm , maybe i do something wrong Thanks for understanding B.R |
| | #12 (permalink) |
| @hadjimi I will explain you once more, for example: Imei: 35485704668865 <---- 14 digits IMEI Master Code: 070401080903070903070302010808 Its 1st time I'm calculating codes for this IMEI of (14-digits) and Master code: We have results and it will work 100% : Code: Calculated NCK Codes For 35485704668865
Level 1 [MNC+MCC ] #pw+600963512396656+1#
Level 2 [GID1 ] #pw+225193011087588+2#
Level 3 [GID2 ] #pw+911069837690368+3#
Level 4 [MSIN ] #pw+175374693500562+4#
Level 5 [MNC+MCC+GID1 ] #pw+150616206570130+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+539626503774347+6#
Level 7 [ALL SIMLOCK(s) ] #pw+908416475072485+7#
try using Level 1 Codes to unlock the Phone... We have results and it will also work 100% : Code: Calculated NCK Codes For 35485704668865
Level 1 [MNC+MCC ] #pw+643569969957420+1#
Level 2 [GID1 ] #pw+637665224053611+2#
Level 3 [GID2 ] #pw+128862659953302+3#
Level 4 [MSIN ] #pw+000065272016595+4#
Level 5 [MNC+MCC+GID1 ] #pw+996921611188183+5#
Level 6 [MNC+MCC+GID1+GID2] #pw+576219886247011+6#
Level 7 [ALL SIMLOCK(s) ] #pw+887075367896310+7#
try using Level 1 Codes to unlock the Phone... it will be locked again, and write the 2nd code for test, it will work for sure. BR |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 04-10-2013 02:07 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 06-16-1999 08:41 |
