12-03-2013, 08:19 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Punjab Age: 36
Member: 1298426 Status: Offline Sonork: 100.1603765 Thanks Meter: 266 | Why supporters not solving my prob i m facing problem with atf all ver after 9.20 Here is post http://forum.gsmhosting.com/vbb/f609...7/#post9912420 |
12-03-2013, 08:37 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Ramuwalia 1. Disconnect ATF Box and other GSM Boxes from Your PC. 2. Run ATF Software WITHOUT BOX Connected 3. Goto "Product Support" ===> "Box Tools" ===> click "Restore EEPROM" 4. After it finishes, disconnect ATF BOX from USB Port and Close ATF Software 5. Run This: C:\AdvanceBox Turbo Flasher\Driver\Remove_ATF_Drivers\Remove_ATF_Drive rs.bat 6. Connect ATF Box and FORCE IT to use: C:\AdvanceBox Turbo Flasher\Driver\ATF_NEW_DRIVERS\ *** IF You let windows automatically install the drivers, then you will never solve this problem... FORCE WINDOWS TO USE DRIVERS FOR ATF BOX! *** Windows Might want you to restart PC after you install Drivers. So restart PC and install same Drivers on the second ATF Box Device in USB device manager. This will fix your problem |
