05-22-2014, 13:03 | #1 (permalink) |
Major Poster Join Date: May 2007
Member: 511506 Status: Offline Thanks Meter: 5 | Why upgrade to V11.3 to reactivate? Nor to the activation! ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 857DFC86F1F86932C6512F3B ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software Activated when prompted Your Box Distributor/Reseller has requested that your Box should be Disabled. Please Contact your Box Distributor/Reseller and settle the Problem. If you think you are getting this Message by Mistake, please visit ATF Support: http://forum.gsmhosting.com/vbb/f609/ |
The Following User Says Thank You to lxh-studio For This Useful Post: |
05-22-2014, 14:18 | #2 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1352787 Status: Offline Sonork: 100.1592083 Thanks Meter: 105 | ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : 99FE5CA8A87E51A4B6400BC5 ERROR: Invalid Reply Detected... 0xA0 ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
05-22-2014, 20:35 | #3 (permalink) |
Freak Poster Join Date: May 2008 Location: algerie
Member: 763859 Status: Offline Thanks Meter: 15 | same problem Driver Version : 00020830 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.00 Software Version : v11.30 AdvanceBox SN : F5032BB2BBA753BAE251F770 Box Status : NOT ACTIVATED |
