Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-11-2011, 09:20   #76 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
yes we can continue there is commmand line
Old 04-11-2011, 09:21   #77 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@mscomp
Read Post #56
http://forum.gsmhosting.com/vbb/7184154-post56.html
The Following User Says Thank You to Advance-Box For This Useful Post:
Old 04-11-2011, 09:23   #78 (permalink)
Member: 53156
Thanks Meter: 15
Hi maybe somebody will help split to 2 pc?thank you.
Old 04-11-2011, 09:25   #79 (permalink)
Member: 651945
@maryajne
@ance
AMD users require Catalyst v11.3+ with APP SDK2.4+ or integrated OpenCL driver
Catalyst 11.3 Here:
ATI Radeon
APP SDK2.4 Here:
AMD APP SDK Downloads | AMD Developer Central
Integrated OpenCL driver is already inside Catalyst 11.3...
B.R.
Old 04-11-2011, 09:38   #80 (permalink)
Member: 289279
can this software find code, when card is overclocked?
Old 04-11-2011, 09:42   #81 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 2,053
So this means NO more Dongle to be use!
What you need are: sha file+oclHashcat-lite+supported GPU....
Saves money....
Old 04-11-2011, 09:47   #82 (permalink)
Member: 651945
@ance
Yes it will because it does not skip keyspaces aka "salt"...
oclHashcat-lite will search FULL KEYSPACE without skipping.
Also make sure that your extracted HASHES from PM 120 are RSA verified.
As of this moment, only ATF Software uses RSA verification for PM 120 HASHES...
B.R.
Old 04-11-2011, 09:51   #83 (permalink)
Member: 289279
Originally Posted by Advance-Box View Post
@maryajne
@ance
Catalyst 11.3 Here:
ATI Radeon
APP SDK2.4 Here:
B.R.
installed required software
AMD-APP-SDK-v2.4-Windows-64.exe
11-3_vista64_win7_64_dd_ccc_ocl.exe
software still can't run
Old 04-11-2011, 09:51   #84 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
Please check attachment and guide me pl after save this file as,
oclHashcat-lite32 A5EDDCCCE99E4A1E1DE93263B84B17E434218ED8:003582410 3311661 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --hex-salt --hex-charset --output-format=1
in text file which name off file i select for run with this soft.
Old 04-11-2011, 09:57   #85 (permalink)
Member: 651945
@Kanwalgee
Your command line is WRONG.
oclHashcat-lite32 A5EDDCCCE99E4A1E1DE93263B84B17E434218ED8:0035824103311661 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --hex-salt --hex-charset --output-format=1
Please follow my instructions 100% here:
http://forum.gsmhosting.com/vbb/7183692-post15.html
B.R.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 04-11-2011, 10:00   #86 (permalink)
Member: 651945
What error do you get?
What command line did you type?
Do you have Screenshot?
B.R.
Old 04-11-2011, 10:06   #87 (permalink)
Member: 179431
Sonork: 100.1601222
Thanks Meter: 12
hi but how we can calculate code after software finish job??
Old 04-11-2011, 10:07   #88 (permalink)
Member: 12612
Thanks Meter: 15
IMPORTANT
Look at that. Atom writes that salt is prepared from 15 digit IMEI with adding 00 in front and end. Which is the correct salt?
Here is the original post:
oclHashcat-lite SL3 cracking howto
I know we have a lot of new users from gsmhosting because of SL3 cracking. Welcome guys!
Before we get bombed with questions i decided to write a small howto.
Yes, the latest oclHashcat-lite is able to crack SL3! But please keep in mind oclHashcat-lite was not specially designed to crack SL3.
If you want an easy-to-use-one-click solution: buy one. There a diffrent commercial solutions out.
Ok, lets start:
1. AMD/ATI Users only: Get latest catalyst driver! Minimum 11.3. This step is absolutly neccessary otherwise you will not find the code and you will not get a error message!
2. Get oclHashcat-lite v0.2 from Homepage and unpack it
3. Open command shell window and cd to oclHashcat-lite installation directory
4. Get your hash (SHA1). Its a 40 char hex-encoded string and looks like this: 21b5e418af3de249677fbce2fa33db594a2b11a0
5. Get your salt (IMEA). Its a 12 char hex-encoded string and looks like this: 321521047837132
6. Prepare your salt. Prepare and Append 00 to the salt like this: 0032152104783713200
6. The following command starts oclHashcat-lite. Its a complicated looking string but its static, it does not change. The only thing that changes is your hash and your salt. The smart user put it into a .bat file!
oclHashcat64.exe -m 101 -n 160 -1 00010203040506070809 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=out.txt 21b5e418af3de249677fbce2fa33db594a2b11a0:003215210 4783713200 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1
The linux command is exactly the same. I will explain the parameters so you know what you are doing:
-m 101: This sets the hash-type of oclHashcat-lite. SL3 uses the sha1($pass.$salt) scheme.
-n 160: This is the workload-amplifier and its the most important flag that controls the Performance of the program. If you want more speed, raise it. If you want less speed, lower it. This is if your desktop is lagging to much.
-1 00010203040506070809: This binds the charset to our custom charset 1. SL3 uses only a small charset of ten chars (0-9, binary encoded)
--pw-min=15, --pw-max=15: We want to crack a Password with length 15. SL3 Passwords have a static length: 15. If you do not specify it starts with length 4 and ends with length 15. Its good in password cracking but useless in SL3.
--hex-charset: Tells oclHashcat-lite that our charset is given in hex
--hex-salt: Tells oclHashcat-lite that our salt is given in hex
--output-format=1: This is important! Otherwise the output is ascii encoded and useless for SL3
--output-file=out.txt: This is where the cracked pass is stored to
21b5e418af3de249677fbce2fa33db594a2b11a0:003215210 4783713200: The only thing that changes.
?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1: its our "mask". 15 times ?1 (which ist custom charset 1 we bound before)
Of course there are a lot of options to optimize the attack, use it in distributed mode, restore sessions... Stuff like that.
Please play around a bit with it before asking Questions. Its really not that hard.
atom
EDIT
OOPS!!!
He already correct his post. Salt is first 14 digit of IMEI whit adding 00 in front and end
The Following User Says Thank You to ihmgsm For This Useful Post:
Old 04-11-2011, 10:09   #89 (permalink)
Member: 696872
Thanks Meter: 18
AMD Radeon HD 6850 is supported??????
hello
Old 04-11-2011, 10:10   #90 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 71
where we can edit hash and imei
open notepad
then
open oclhashcat-lite32 doesnt open
where we can type command line
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/
Posted By For Type Date
LBF computer configuration This thread Trackback: 07-04-2011 20:15
Page generated in 0.29814 seconds with 10 queries
