Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 03-24-2012, 18:23   #2236 (permalink)
strangerboy's Avatar
Member: 3783
If i install 11.11 drivers computer wont recognize my hd7970 it will show has VGA standart .... how come u could install 11.11 ?? and hd7970 being recognized?
Old 03-24-2012, 19:42   #2237 (permalink)
Member: 1709265
Originally Posted by golumbu View Post
Thanks,
I confirm, hashcat really stops when .cod file is present but i'm not able to start hascat from the remote (local network) pc.
Any sugestion please ? It coud be useful to many of us. Thanks.
WBR
Golumbu
I just tested on windows and it work good but to make it working in one of .bat files you need to add network paths eg:
first file:
oclHashcat-lite64 A347C3E4E864117F741EE84EB566387D941C5304:003582840303318800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile-format=1 --outfile=358284030331886_COD.txt --session=358284030331886_1
second file:
\\Comp_Name\Folder_where_is_hashcat\oclHashcat-lite64 A347C3E4E864117F741EE84EB566387D941C5304:003582840303318800 -1 09080706050403020100 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile-format=1 --outfile=\\Comp_Name\Folder_where_is_hashcat\358284030331886_COD.txt --session=\\Comp_Name\Folder_where_is_hashcat\358284030331886_2
Thanks for @Alkapone for this idea
Old 03-24-2012, 21:41   #2238 (permalink)
Member: 1575682
Old 03-25-2012, 16:39   #2239 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Originally Posted by q116267 View Post
OpenCL need to be updated (from 12.1 package atleast to run with 0.9)
Old 03-25-2012, 16:42   #2240 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
first file:
second file:
Use Dropbox, easy and fast sync if all PC-s are not in same place!
Old 04-03-2012, 06:52   #2241 (permalink)
Member: 576776
please check ups power
Old 04-05-2012, 10:21   #2242 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Originally Posted by strangerboy View Post
Wich drivers are u guys using for hd7970 ???? I´ve tryed all drivers so far even the new 12.4 beta... no luck i can´t make it work with 2x hd7970 ... do we have to use crossfire cables again ?? i´m not using them
no need to put crossfire cable and i used 7970x4 @ 950Mhz with no problem
i use 12.3 drivers
Best Regards
The Following 5 Users Say Thank You to Nonoyxp For This Useful Post:
Old 04-05-2012, 19:36   #2243 (permalink)
Member: 1709265
any one know the way to store info after calculation done to .txt file. I mean date of start and finish and procentage.
thanks
Old 04-05-2012, 19:43   #2244 (permalink)
Member: 1709265
thanks
sorry for double post (internet problem)
Old 04-07-2012, 08:33   #2245 (permalink)
Member: 4263
Sonork: 100.1582330
Hi
what modification i have to do in the command line to start in calculation for 100% to 0%
Old 04-07-2012, 08:52   #2246 (permalink)
Member: 1709265
Originally Posted by MAK_US1977 View Post
Hi
change this part of line
to this
Old 04-07-2012, 08:53   #2247 (permalink)
SPUnlock_SK's Avatar
Member: 13922
this cmd line
change to
The Following 3 Users Say Thank You to SPUnlock_SK For This Useful Post:
Old 04-08-2012, 11:01   #2248 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
is it ok MASTER CODE after successful cracked????
3f848eeab3b90a92c6a80cbdd4cc636119e8a58b:0035xxxxx xxxxxxx00:000000000000000000000000000000
the master code i get is 0000000 i it ok????
Old 04-09-2012, 15:32   #2249 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
come on ATF team reply my post.
Old 04-09-2012, 15:53   #2250 (permalink)
Member: 13922
your mastercode (0000000000000000000000000) is not correct there must be some problem during calculation
you need to calculate again
LinkBacks (?)
LinkBack to this Thread: http://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/
Posted By For Type Date
LBF computer configuration This thread Trackback: 07-04-2011 20:15
Page generated in 0.63785 seconds with 11 queries
