Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 05-21-2012, 19:46   #2296 (permalink)
Member: 1571557
Originally Posted by datalife2000 View Post
@ hao124 here:
suppose you have 2 pc's A and B
pc A runs windows 32 bit and has oclHashcat-lite-0.09 (i.e. c:\oclHashcat-lite-0.09)
pc B runs windows 64 bit and has oclHashcat-lite-0.06 (i.e. c:\oclHashcat-lite-0.06)
pc A network name is TMC4-PC
pc B network name is SIBONX-PC
suppose we want to calculate for IMEI 357004041091183
after reading log files:
originally we have for pc A:
oclHashcat-lite32 D09535501FE0FD48F56B246FB0195A0A8641422C:003570040 410911800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=357004041091183.cod
originally we have for pc B:
oclHashcat-lite64 D09535501FE0FD48F56B246FB0195A0A8641422C:003570040 410911800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=357004041091183.cod
NOW this is what we need to add
pc A:
if we have a log file for oclHashcat-lite32 D09535501FE0FD48F56B246FB0195A0A8641422C:003570040 410911800 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=357004041091183.cod
copy 357004041091183.cod \\SIBONX-PC\oclHashcat-lite-0.06
pc B:
copy 357004041091183.cod \\TMC4-PC\oclHashcat-lite-0.09
when above is done all is now set.
and dont forget to allow network permissions to read and write on pc and folders to avoid ACCESS IS DENIED
to test if your network is going to work:
create a batch file with the following command for the above example
on pc A:
copy 358258033256464.cod \\SIBONX-PC\oclHashcat-lite-0.06
if you go to pc B: in folder c:\oclHashcat-lite-0.06
you should be able to see the file you copied 358258033256464.cod
if you can see it then all is well for this pc. do the same for the other pc to test
lets know how it works
If I have two super computer, how do I set up the hardware side.
Allow them to work together to achieve greater efficiency.
Please teach me, thanks very much.
pc1 6990x2
pc2 7970x2
Old 05-25-2012, 11:14   #2297 (permalink)
Member: 1571557
Today I had a new problem. Again to ask the master.
If I calculate the power outage in the process, leading to not continue.
What command can be restored to the calculation of the past?
For example: the computer started working, I go to bed. Up in the morning, found that the computer stopped working, I do not know his work where.
At this point, I want to let the computer how to continue his unfinished work it?
Thank you
br
Old 05-25-2012, 11:33   #2298 (permalink)
Member: 1709265
Thank you
br
you need to add in command line --session="phone's imei"
and when want to restore calculation make line
oclhashcat-lite64 --restore --session="phone's imei"
and thats it
The Following User Says Thank You to rastogsm For This Useful Post:
Old 05-26-2012, 17:42   #2299 (permalink)
el-safwa's Avatar
Member: 158471
Sonork: 100.1588029
hi all can any one help me i need to buy watercooling for ati card 6990 and 6970 i Want Buy Online better way more best if can buy from China
If there is better than other tell me
some info about my pc
2x6970 +1 6990 (9pc)
2x5870 +1 5970 (1pc)
Old 05-30-2012, 04:33   #2300 (permalink)
Member: 1747553
Sonork: camecana
Originally Posted by nimanima View Post
how to use random salt with oclhashcat9
you can use MXBOX LBF, it have salt
Old 05-30-2012, 13:24   #2301 (permalink)
Member: 8843
and thats it
please
check post #2292
Old 05-30-2012, 13:27   #2302 (permalink)
Member: 8843
pc1 6990x2
pc2 7970x2
just follow as above for your two super computers. that means u have
super computer 1 is PC A
and
super computer 2 is PC B
Old 06-01-2012, 20:30   #2303 (permalink)
PEGEGORY's Avatar
Member: 340703
Sonork: 100.1592496
Can someone please help me out with this card ??? HD6670 its very cheap but i want to know how many days a quad of those can finish 1 calculation ... GPU estimations I did check here but its not there ....I want to know before i buy them.
PEGEGORY.
Old 06-03-2012, 04:14   #2304 (permalink)
Member: 149256
PEGEGORY.
approximately 15 days/ code
Old 06-03-2012, 13:24   #2305 (permalink)
Member: 1737085
sir this software support ati radeon 7970 cards , i mean can work with these cards
please let me know .. i had purchased two cards of 7970 but .. i m looking for any device can support these cards for bruteforce file caluclation.. thanks
contact me congresphonewala.com
Old 06-07-2012, 13:27   #2306 (permalink)
Member: 205474
Sonork: 100.1585171
buy sl3net software client for yr pc
Old 06-18-2012, 10:17   #2307 (permalink)
Member: 1773402
I think best way using icloud : MSM or sl3net is good than edit text OLC.
Old 06-20-2012, 08:42   #2308 (permalink)
winnitsa's Avatar
Member: 372207
Sonork: 100.1575741
OCL Haschcat 0.08 stops does not go to the next...
3 x HD5970 wattercooled
1800 W PSU
OCL 0.08 / Windows 7 x64
Driver: 11.3 (with another driver allways Bluescreen or Problem)
MSI Afterburner 2.2.1
Temp.: 60,63,70,72,60,70
Hier is Start.bat:
oclHashcat-lite64 6F9F49DA12C1BA6E5E096DDFE7C6C27C89E246CF:003582410 331888100 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile-format=1 --outfile=358241033188812_2700.cod
oclHashcat-lite64 CA55BD6DD9092ED462EF0ADDD2DC3438D15A38C9:003520170 443326500 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile-format=1 --outfile=352017044332656_1616.cod
oclHashcat-lite64 EB82A7F74241659FDB552708E8925EEB7811DA38:003527090 477575200 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 800 --outfile-format=1 --outfile=352709047757521_1800.cod
or here
Here is ERROR LOG:
C:\08>oclHashcat-lite64 6F9F49DA12C1BA6E5E096DDFE7C6C27C89E246CF:003582410331888
oclHashcat-lite v0.8 by atom starting...
GPU-Loops: 1024
GPU-Accel: 800
Password lengths range: 15 - 15
Platform: AMD compatible platform found
Watchdog: Temperature limit set to 90c
Device #1: Cypress, 1024MB, 0Mhz, 20MCU
Device #2: Cypress, 1024MB, 0Mhz, 20MCU
Device #3: Cypress, 1024MB, 0Mhz, 20MCU
Device #4: Cypress, 1024MB, 0Mhz, 20MCU
Device #5: Cypress, 1024MB, 0Mhz, 20MCU
Device #6: Cypress, 1024MB, 0Mhz, 20MCU
[s]tatus [p]ause [r]esume [q]uit => s
Status.......: Running
Hash.Target..: 6f9f49da12c1ba6e5e096ddfe7c6c27c89e246cf:003582410331888100
Hash.Type....: SL3
Time.Running.: 55 seconds
Time.Left....: 23 hours, 48 minutes
Plain.Mask...: ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1
Plain.Text...: ********0000000004040106000000
Plain.Length.: 15
Progress.....: 645857280000/1000000000000000 (0.06%)
Speed.GPU.#1.:  1945.3M/s
Speed.GPU.#2.:  1940.7M/s
Speed.GPU.#3.:  1942.1M/s
Speed.GPU.#4.:  1942.1M/s
Speed.GPU.#5.:  1946.2M/s
Speed.GPU.#6.:  1943.0M/s
Speed.GPU.#*.: 11659.4M/s
HWMon.GPU.#1.: 99% GPU, 49c Temp
HWMon.GPU.#2.: 99% GPU, 52c Temp
HWMon.GPU.#3.: 99% GPU, 52c Temp
HWMon.GPU.#4.: 99% GPU, 52c Temp
HWMon.GPU.#5.: 99% GPU, 52c Temp
HWMon.GPU.#6.: 99% GPU, 52c Temp
Hash.Type....: SL3
Time.Running.: 15 minutes, 53 seconds
Time.Left....: 23 hours, 31 minutes
Plain.Text...: ********0000000002090500010100
Plain.Length.: 15
Progress.....: 11114774528000/1000000000000000 (1.11%)
Speed.GPU.#1.:  1944.7M/s
Speed.GPU.#2.:  1947.9M/s
Speed.GPU.#3.:  1946.3M/s
Speed.GPU.#4.:  1945.1M/s
Speed.GPU.#5.:  1947.7M/s
Speed.GPU.#6.:  1945.7M/s
Speed.GPU.#*.: 11677.5M/s
HWMon.GPU.#1.: 99% GPU, 62c Temp
HWMon.GPU.#2.: 99% GPU, 65c Temp
HWMon.GPU.#3.: 99% GPU, 65c Temp
HWMon.GPU.#4.: 99% GPU, 65c Temp
HWMon.GPU.#5.: 99% GPU, 65c Temp
HWMon.GPU.#6.: 99% GPU, 65c Temp
Hash.Type....: SL3
Time.Running.: 15 minutes, 56 seconds
Plain.Text...: ********0000000406000201010100
Plain.Length.: 15
Progress.....: 11146854400000/1000000000000000 (1.11%)
Speed.GPU.#1.:  1946.1M/s
Speed.GPU.#2.:  1948.2M/s
Speed.GPU.#3.:  1946.5M/s
Speed.GPU.#4.:  1944.7M/s
Speed.GPU.#5.:  1947.1M/s
Speed.GPU.#6.:  1947.5M/s
Speed.GPU.#*.: 11680.1M/s
Hash.Type....: SL3
Time.Running.: 46 minutes, 14 seconds
Time.Left....: 23 hours, 11 minutes
Plain.Text...: ********0000000404070103020300
Plain.Length.: 15
Progress.....: 32336314368000/1000000000000000 (3.23%)
Speed.GPU.#1.:  1932.9M/s
Speed.GPU.#2.:  1930.2M/s
Speed.GPU.#3.:  1927.2M/s
Speed.GPU.#4.:  1928.3M/s
Speed.GPU.#5.:  1932.0M/s
Speed.GPU.#6.:  1940.2M/s
Speed.GPU.#*.: 11590.8M/s
HWMon.GPU.#1.: 98% GPU, 63c Temp
HWMon.GPU.#2.: 98% GPU, 65c Temp
HWMon.GPU.#3.: 98% GPU, 66c Temp
HWMon.GPU.#4.: 98% GPU, 65c Temp
HWMon.GPU.#5.: 98% GPU, 66c Temp
HWMon.GPU.#6.: 98% GPU, 66c Temp
Hash.Type....: SL3
Time.Running.: 1 hour, 1 minute
Time.Left....: 22 hours, 48 minutes
Plain.Text...: ********0000000004020403020400
Plain.Length.: 15
Progress.....: 42367565824000/1000000000000000 (4.24%)
Speed.GPU.#1.:  1942.8M/s
Speed.GPU.#2.:  1942.8M/s
Speed.GPU.#3.:  1942.8M/s
Speed.GPU.#4.:  1943.6M/s
Speed.GPU.#5.:  1944.0M/s
Speed.GPU.#6.:  1943.3M/s
Speed.GPU.#*.: 11659.3M/s
HWMon.GPU.#1.: 99% GPU, 59c Temp
HWMon.GPU.#2.: 99% GPU, 63c Temp
HWMon.GPU.#3.: 99% GPU, 63c Temp
HWMon.GPU.#4.: 99% GPU, 63c Temp
HWMon.GPU.#5.: 99% GPU, 63c Temp
HWMon.GPU.#6.: 99% GPU, 63c Temp
Hash.Type....: SL3
Time.Running.: 1 hour, 2 minutes
Time.Left....: 22 hours, 49 minutes
Plain.Text...: ********0000000002070405020400
Plain.Length.: 15
Progress.....: 42572365824000/1000000000000000 (4.26%)
Speed.GPU.#1.:  1940.7M/s
Speed.GPU.#2.:  1942.1M/s
Speed.GPU.#3.:  1942.4M/s
Speed.GPU.#4.:  1941.2M/s
Speed.GPU.#6.:  1939.3M/s
Speed.GPU.#*.: 11649.7M/s
HWMon.GPU.#1.: 99% GPU, 60c Temp
Status.......: Cracked
Hash.Type....: SL3
Time.Running.: 2 hours, 34 minutes
Time.Left....: 22 hours, 36 minutes
Plain.Text...: ********0000000002090902030500
Plain.Length.: 15
Progress.....: 53330657280000/1000000000000000 (5.33%)
Speed.GPU.#1.:  1937.7M/s
Speed.GPU.#2.:  1939.1M/s
Speed.GPU.#3.:  1937.4M/s
Speed.GPU.#4.:  1938.2M/s
Speed.GPU.#6.:  1938.7M/s
Speed.GPU.#*.: 11635.2M/s
HWMon.GPU.#1.:  0% GPU, 30c Temp
HWMon.GPU.#2.:  0% GPU, 33c Temp
HWMon.GPU.#3.:  0% GPU, 33c Temp
HWMon.GPU.#4.:  0% GPU, 33c Temp
HWMon.GPU.#5.:  0% GPU, 33c Temp
HWMon.GPU.#6.:  0% GPU, 33c Temp
And here is LOG when I start the same start.bat after error:
GPU-Loops: 1024
GPU-Accel: 800
Hash.Type....: SL3
Time.Running.: 1 minute, 1 second
Plain.Text...: ********0000000408050706000000
Plain.Length.: 15
Progress.....: 713588736000/1000000000000000 (0.07%)
Speed.GPU.#1.:  1941.6M/s
Speed.GPU.#2.:  1944.1M/s
Speed.GPU.#3.:  1945.7M/s
Speed.GPU.#5.:  1941.2M/s
Speed.GPU.#6.:  1942.6M/s
Speed.GPU.#*.: 11658.8M/s
HWMon.GPU.#1.: 87% GPU, 46c Temp
HWMon.GPU.#2.: 89% GPU, 49c Temp
HWMon.GPU.#3.: 89% GPU, 48c Temp
HWMon.GPU.#4.: 89% GPU, 48c Temp
HWMon.GPU.#5.: 89% GPU, 48c Temp
HWMon.GPU.#6.: 89% GPU, 49c Temp
Started: Tue Jun 19 18:15:40 2012
Stopped: Tue Jun 19 18:16:46 2012
C:\08>oclHashcat-lite64 CA55BD6DD9092ED462EF0ADDD2DC3438D15A38C9:003520170443326
GPU-Loops: 1024
GPU-Accel: 800
Hash.Target..: ca55bd6dd9092ed462ef0addd2dc3438d15a38c9:003520170443326500
Hash.Type....: SL3
Time.Running.: 23 seconds
Time.Left....: 23 hours, 52 minutes
Plain.Text...: ********0000000607050402000000
Plain.Length.: 15
Progress.....: 270925824000/1000000000000000 (0.03%)
Speed.GPU.#1.:  1940.9M/s
Speed.GPU.#2.:  1939.2M/s
Speed.GPU.#3.:  1939.7M/s
Speed.GPU.#4.:  1938.6M/s
Speed.GPU.#5.:  1938.6M/s
Speed.GPU.#6.:  1937.0M/s
Speed.GPU.#*.: 11634.1M/s
how to be? where to find the problem?
Many THX
Regards, Alex
Old 06-23-2012, 17:49   #2309 (permalink)
Member: 277940
Try 11.6 or 12.6 driver
Try with disabled CCC MSI ect
Try use -100MHZ clock (if it is working ok you have problem with your 5970
(i have one 5970 that working good only with 650mhz)
The Following User Says Thank You to mikeabcabc For This Useful Post:
Old 06-29-2012, 14:00   #2310 (permalink)
Member: 1731010
oclhashcat-lite 0.10 RELEASED
Markov type based SL3 Hash-cracking added!
GTX680 Supported!
GTX690 Supported!
And very important feature - no more need of worry which driver to use, every driver past 11.12+ is supported from now!
Download latest Version of oclhashcat-lite here:
oclHashcat-lite - advanced password recovery
Full Change log:
type: feature
file: kernels
desc: added -m 0910 = md4($pass.$salt)
type: feature
file: kernels
desc: added -m 1410 = sha256($pass.$salt)
type: feature
file: kernels
desc: added -m 1700 = SHA512
type: feature
file: kernels
desc: added -m 1710 = sha512($pass.$salt)
type: feature
file: kernels
desc: added -m 3100 = Oracle 7-10g, DES(Oracle)
type: feature
file: kernels
desc: on AMD, switched from .kernel to .llvmir to reduce diskspace
type: feature
file: kernels
desc: on NV, switched from .cubin to .ptx to reduce diskspace
type: feature
file: kernels
desc: added kernel cache to avoid unnecessary recompilation
cred: m4tr1x
type: driver
file: kernels
desc: added support for NVidia CUDA 4.2
type: driver
file: kernels
desc: added support for NVidia sm_30 gpu-architecture [ Kepler ]
type: driver
file: host programs
desc: added support for NVAPI R300
type: driver
file: host programs
desc: added support for NVidia NVML library and got rid of nvidia-smi command
type: driver
file: host programs
desc: added support for AMD ADL v4.0 library
type: feature
file: host programs
desc: splitted --gpu-watchdog to --gpu-temp-disable and --gpu-temp-abort
type: feature
file: kernels
desc: added benchmarking mode
cred: m4tr1x
type: feature
file: host programs
desc: added --gpu-temp-retain to try retain temperature at NUM degrees celsius
cred: m4tr1x
type: feature
file: host programs
desc: workarounded AMD bug in clGetDeviceInfo() CL_DEVICE_MAX_CLOCK_FREQUENCY
cred: m4tr1x
type: feature
file: kernels
desc: added early check for zero-length password hashes
cred: m4tr1x
type: feature
file: host programs
desc: show LM-half as soon as it is cracked
type: feature
file: host programs
desc: added support for charset files and some example charset files
type: feature
file: host programs
desc: added support to read hashes from file
type: feature
file: host programs
desc: implemented base64 parser that would allow for dynamic salt lengths in nsldaps
type: feature
file: host programs
desc: added fan-speeds to status display
type: feature
file: host programs
desc: removed --pw-skip-plain and --pw-limit-plain as they are incompatible to markov
type: bug
file: host programs
desc: fixed bug in status display if ETA calculated > 60 years
cred: arex
type: bug
file: host programs
desc: fixed bug in Oracle 11g hash parsing function, salt length increased to 10 byte
cred: flipit
type: bug
file: host programs
desc: fixed bug in salt-length parser for MyBB1.2 hashes
cred: code841
type: change
file: host programs
desc: changed default charset to the one which passpal outputs running on rockyou.txt
cred: arex
More Details:
oclHashcat-lite v0.10
Welcome to oclHashcat-lite v0.10.
Download it here: oclHashcat-lite - advanced password recovery
This release is a big step forward. We have added both, many major and many minor features.
Per-position markov-chains, aka markov-attack/incremental-attack/charset-files
The markov-attack is a statistically based brute-force like attack, but instead of specifying a charset or a mask, we specify a file. This file is once generated by ourself in a previous step. It contains statistical informations which are made out an automated analysis of a given dictionary.
It can fully replace Brute-Force since it covers the full keyspace.
In Brute-Force Attack (or in Mask Attack) we can limit the keyspace by setting a smaller charset in order to reduce the attack-time. In Markov Attack we have something similar, the "threshold". All you do is to specify a number. The higher the number, the higher the threshold to add a new link between two characters on the two-level table on which the markov-attack bases on.
This background is not so important, just remember that the lower the value, the smaller the keyspace and thus the faster the attack is.
Check these threads for more details
statsprocessor v0.03
statsprocessor v0.04 with per-position markov chains
statsprocessor v0.07
Use .ptx ad .llvmir intermediate kernels
The kernels are distributed in an "intermediate" format (aka IL). It cant be reversed to original C code but still its not a binary format that can be used for execution.
The JIT (just-in-time) compilers from both OpenCL and CUDA, which ship with the driver, compile the final byte-code out of the IL. This takes a few seconds per kernel but once its done the byte-code is cached (CUDA does it automatically, OpenCL not but we add a function to do the same as CUDA does).
This has some nice advantages:
Not 32/64 bit specific
Less HDD space
Smaller .7z
Less problems with driver specific problems as we often see with Catalyst
There is no more need to release a new oclHashcat-* in case a new driver optimization has been added. oclHashcat-* caches driver specific. If it recognizes a driver change it will rebuild thge byte-code from the IL, but using the new JIT from the new driver resulting in driver specific optimized byte-code.
Retaining GPU temperature
When I started with oclHashcat-* Hardware mangement support, some people asked me for add support for fan-speed. For a long time I was not interessted in adding fan-speed code to oclHashcat-* since this is the job for the driver or some specialized controling software.
I did not change my mind completly on this, but still we have added some fan-speed controlling code. The new parameters are:
--gpu-temp-disable Disable temperature and fanspeed readings and triggers
--gpu-temp-abort=NUM Abort session if GPU temperature reaches NUM degrees celsius
--gpu-temp-retain=NUM Try to retain GPU temperature at NUM degrees celsius (AMD only)
So what this thing is doing is: If the temperature configured with the new --gpu-temp-retain parameter is reached, it starts to increase the fan-speed by 1 percent each second. Thats all.
If you imagine a scenario what this means you will come to the conclusion that this feature also enables you to enfore your GPU running always to a very specific temperature.
Some notes:
--gpu-temp-disable you can completly disable all the temperature stuff.
--gpu-temp-retain currently only works for AMD.
--gpu-temp-abort parameter is just the renamed version of the old --gpu-watchdog.
Both parameters accept the 0 value which disables only this specific feature. This means you can step back to the old behavior by specifying --gpu-temp-retain 0.
The default for --gpu-temp-abort is still 90c.
The default for --gpu-temp-retain is 80c.
Built-in benchmarking mode
* Benchmark:
-b, --benchmark Run benchmark
--benchmark-mode Benchmark-mode, see references below
Nothing much to explain here I think, but some notes to the benchmark mode:
As long as you do not set the --benchmark-mode you can modify all the configuration parameters you always use. Something like -d, -n, --gpu-accel or --runtime.
With --runtime you can specify the duration how long each test lasts.
If you add -m you can limit to a specific hash-type. If you do not set it, it will iterate through all hash-types.
All unneccessary parallel threads like hardware monitor, restore-support and outfile-watch are disabled. Also the quiet mode is enabled.
On NVidia, the hashes based on SHA256, SHA512 and DES are limited to -n 32, otherwise the driver throws the error cuStreamSynchronize() 702.
New Algorithms supported
SHA512
md4($pass.$salt)
sha256($pass.$salt)
sha512($pass.$salt)
Massive Thanks goes to atom!
LinkBacks (?)
LinkBack to this Thread: http://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/
Posted By For Type Date
LBF computer configuration This thread Trackback: 07-04-2011 20:15
Page generated in 0.44263 seconds with 11 queries
