04-11-2011, 07:47 | #47 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
IMEI (first 14 digits only): 35604603339807 HASH : 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Substitute IMEI with your phone's IMEI Substitute HASH with your phone's HASH Last edited by Advance-Box; 04-12-2011 at 17:31. | |
The Following User Says Thank You to Advance-Box For This Useful Post: |
04-11-2011, 07:51 | #48 (permalink) | |
You problem is Driver Version and Catalyst 11.3 latest OpenCL Drivers. FIRST MAKE A SYSTEM RESTORE POINT WITH WINDOWS 7 so you have a working spashot of your Windows 7 before we try to update your Drivers and Catalyst... Then... Update your ATI Drivers first... Then Restart PC. Now install or update to FULL Catalyst 11.3 with OpenCL Drivers... Restart PC again... All should work. I had similar problems as you... But after ATI Drivers was updated, all of them disappeared. B.R. | |
04-11-2011, 07:51 | #49 (permalink) | |
Cheater -Don't Deal with him- Join Date: Mar 2011 Location: ECUS for Professionals
Member: 1528074 Status: Offline Sonork: 100.99955 Thanks Meter: 184 | Quote:
Intel P35 Motherboard Intel E2160 CPU 2 GB DDR2 800 Ram ATI HD5830 1334 M/s 500 Watt Powersuplly Chassi any No extra Cooling Cards running Pefect and stabel @950MHz GPU 1200MHz Ram Cards are operating between 62 and 70 Degree Cost of 1 PC is 300 USD Regards Easy Client | |
04-11-2011, 07:56 | #50 (permalink) | |
Yes you can RESUME... This file is the RESUME file just in case your PC shutdown: oclHashcat-lite.restore That file is updated every few minutes... So you will not loose BF time when your PC hang, freeze or reboot. To RESUME BF on that "restore" file, just type this command: [Windows 7 64 bit ATI AMD Card] oclHashcat-lite64 --restore [Windows 7 32 bit ATI AMD Card] oclHashcat-lite32 --restore [Windows 7 64 bit NVIDIA Card] cudaHashcat-lite64 --restore [Windows 7 32 bit NVIDIA Card] cudaHashcat-lite32 --restore B.R. Last edited by Advance-Box; 04-11-2011 at 08:18. | |
The Following 7 Users Say Thank You to Advance-Box For This Useful Post: |
04-11-2011, 07:58 | #51 (permalink) | |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | Quote:
Brother did you mean this configuration is super computer ............... i think no need this update ATM. when released sl data corrupted repair That Time is Need This Pc Configuration. best regard Palash Ahammad | |
04-11-2011, 08:04 | #52 (permalink) | |
PERFECT!!! Do like this: PC_1: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:01003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_2: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:02003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_3: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:03003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_4: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:04003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_5: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:05003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_6: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:06003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_7: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:07003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_8: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:08003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_9: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:09003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt PC_10: oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:00003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=14 --pw-max=14 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Take note about ?1?1?1?1?1?1?1?1?1?1?1?1?1?1 ... it is now only 14 char. -n 800 <---- This setting is BEST for 5970 only.... For other cards, you need to fine tune it: -n, --gpu-accel=NUM workload tuning: choose 1, 8, 40, 80 or 160 scales best if you choose the number of SP per SM B.R. Last edited by Advance-Box; 04-11-2011 at 12:12. | |
04-11-2011, 08:08 | #53 (permalink) | |
Will post result here when phone done ! Regards Easy Client | |
04-11-2011, 08:27 | #54 (permalink) |
Junior Member Join Date: Jun 2006
Member: 289279 Status: Offline Thanks Meter: 0 | i have hd5850 crossfire win7 x64 system. installed latest drivers, but program won't run. when i type YES and enter, program close Driver Packaging Version 8.831.2-110308a-115928C-ATI Catalyst Version 11.3 Provider ATI Technologies Inc. 2D Driver Version 8.01.01.1134 2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000 Direct3D Version 7.14.10.0817 OpenGL Version 6.14.10.10600 Catalyst Control Center Version 2011.0308.2325.42017 |
04-11-2011, 08:39 | #56 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | im just curious so i want to ask if how many times or % faster is this new bruteforcer compared to ighashgpu????? |
04-11-2011, 08:49 | #59 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @benguetcowboy1 With same Overclock Settings on 2 x 5970 1149 millivolts @ 900 Mhz I get 5,6xx M HASH/s on ighashgpu and equates to 49 hours for maximum keyspace... I get 7,2xx M HASH/s on ocHashcat-lite64 and equates to 38 hours 29 minutes.. So I save 10 hours if I use oclHashcat-lite64... So it means oclHashcat-lite64 is about 23% faster that ighashgpu... And it supports 6970 and 6990 as well... And more importantly, it supports PAUSE and RESUME and RESTORE session just in case your PC HANG, FREEZE or REBOOT... B.R. |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
