04-19-2015, 10:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2014
Member: 2205304 Status: Offline Thanks Meter: 52 | Write FFU by direct eMMC Just so tired of wiring between emmc and JTAG. I got old eyes here, with few tremor on hands seriously.. I done managing Flash Signature Block REJECTED Code: ====================================================== ====================================================== eMMC Test Point Connection Module ====================================================== ====================================================== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501004D384732594300F91706FA40C3 CSD : D02701320F5903FFF6DBFFEF96404063 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : USER AREA PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 4096 KB RPMB PARTITION SIZE: 512 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : M8G2YC Product Rev : 0.0 Product SN : F91706FA Manufactured : April 1997 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501004D384732594300F91706FA40C3.ext_csd Backup Directory: D:\_Cells\Nokia\Nokia Flasher\ATF\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ But my write protect still NO. What could be the problem ? |
04-20-2015, 04:17 | #3 (permalink) |
Member: 2205304 Status: Offline Thanks Meter: 52 | It is done. well, this forum is my diary book. Since no any interaction exist on my thread. Code: Scanning USB Ports... ================================================ Basic Phone Information ================================================ SW Version : 3058.50000.1425.0004 Phone Type : RM-846 Operator Name : 000-ID Phone Version : BuildDate : Jun 18 2014 , BuildType : Release , HelloString : NCSd for WP8 , Version : 3.7 Manufacturer ID : RM-846_apac_indonesia_217 ================================================ Extended Phone Information ================================================ Public ID : 6E4DD75B1D241C8FB45393BC11B4F504F49AFAD0 ================================================ Simlock Information ================================================ PROVIDER KEY : 0000000000000000 SIMLOCK STATE : Locked ====================================================== Selected VPL File: RM846_059R4K7_3058.50000.1425.0004_095.vpl ====================================================== Variant Details : RM-846 VAR APAC INDONESIA ID CV Software Version : 3058.50000.1425.0004 Product Type : RM-846 Product Code : 059R4K7 Variant Version : 095 how to fix imei and simlock ? It is possible ? |
