08-20-2012, 21:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | X1-00 can not connect can see text mode but can not read info? cable is ok cuz i can see test mode what i m doing wrong? i m connection cable to EXTENSION . it is possible i modified ATF box that why i can not use EXTENSION ? |
08-20-2012, 22:10 | #2 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Quote:
br polaco | |
08-20-2012, 22:36 | #3 (permalink) | |
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
Code: Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done Booting Phone... ERROR: Phone did not Boot !!! Make sure that you plugged the cable to the RJ-45 Port Marked << EXTENSION >> ======================================= || FLASHBUS EXTENSION || || ======= ======= || || | | |\ /| || || | | (O) (O) (O) | CABLE | || || | | |/ \| || || ======= ======= || || || ======================================= ^ ^ ^ | | | | | | PLUG IN CABLE HERE Try booting this phone with "Live Phone" option Check the option beside the "Scan Phone" button Flashing ERROR | |
08-20-2012, 23:10 | #4 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Go to ATF Network, + Login + Tick in usb Mode + Press Authorize and paste log Put cable + bat ....That never fail.- I think that is the first step for read this Phone br polaco |
08-20-2012, 23:21 | #5 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Ups.... http://forum.gsmhosting.com/vbb/f609...-55-a-1268679/ From X-Shadow This phone does not have a USB Port... Nokia Service Manul Level 1 & 2 shows that you should update the phone using a CA-101 cable... But they are totally wrong So only FBUS Works,, same as 1280, 1616, 1800 and C1-00 phones... Br polaco |
08-21-2012, 00:21 | #6 (permalink) | |
i got x1 fbus cable it can be my cable problem right? but if cable problem how can i see local mode? any way i try to buy new cable and check it out. | |
08-21-2012, 01:37 | #7 (permalink) | |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Pinout Quote:
Maybe have bad Pinout Tx Rx Polaco | |
08-21-2012, 02:15 | #8 (permalink) | |
i really Appreciate ur help | |
08-21-2012, 02:26 | #9 (permalink) | |
08-21-2012, 04:44 | #10 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
