05-16-2011, 16:45 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | X1-00 RM-732 ATF First In The World FBUS Flashing from 4.35 to 4.55 !!! X1-00 Requires an FBUS cable and it does not have a USB port... PPM only and CNT only flashing (MCU Skipped) is also supported for those who only want to change the Language Pack! Code: VBATT OFF... VBATT ON Setting VBATT Done!... Booting Phone... CPU ID Response: A200341100 CPU Type: XG110 2.1B Phone Booted at after First attempt... ****************************************************** TIME STARTS HERE ****************************************************** Sending PBL 37888 bytes... PBL Successfully Sent... Sending SBL 65024 bytes... SBL Successfully Sent... Flash Chip Manufacturer: Samsung Electronics Corp. Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR Extended Information: Multiple Bank / Burst / 1.8v Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-732\rm732_004.550 FIRMWARE Image Found... Number of Sections: 03 FIRMWARE Certificate Block Sent Successfully... Processing Section 01 of 03 FIRMWARE Erase Block: 0x00000000~0x0001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24576 bytes Data Checksum: D131 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 of 03 FIRMWARE Erase Block: 0x00800000~0x00BFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4128768 bytes Data Checksum: BE42 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 of 03 FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1697536 bytes Data Checksum: 4501 Uploading Data Blocks to phone... FIRMWARE Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-732\rm732_004.55az PPM Image Found... Number of Sections: 01 PPM Certificate Block Sent Successfully... Processing Section 01 of 01 PPM Erase Block: 0x00100000~0x005A943E Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 4887616 bytes Data Checksum: A45A Uploading Data Blocks to phone... PPM Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Processing Image File: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-732\rm7320_nai04.55az CONTENT Image Found... Number of Sections: 01 CONTENT Certificate Block Sent Successfully... Processing Section 01 of 01 CONTENT Erase Block: 0x00E60000~0x00ED8EFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 495360 bytes Data Checksum: E2FE Uploading Data Blocks to phone... CONTENT Data Blocks uploaded to phone... Start Data Verification... (Please wait) Data Verification Successful... Exit Flash Mode Done... Time Elapse : 00:04:33 ****************************************************** You must Factory Reset the phone to enable the ringtones and other customized settings to work ****************************************************** Waiting For Phone to go Online... 5, 4, 3, 2, 1... MCU: V 04.55 14-04-11 RM-732 (c) Nokia IMEI: 356262040089316 Product Serial Number: 18D0ED9AH Product Code : 059G4C3 Module Code : 0204743 Basic Production Code: 059C435 MCU SW Version : V 04.55 14-04-11 RM-732 (c) Nokia AZ ADSP Version : p V 04.55\n14-04-11\nRM-732\n(c) NMP\naz PPM Version : V 04.55 14-04-11 RM-732 (c) Nokia HW Version : 1000 UEM Version : 1328 UPP Version : 8850 LCD Version : TPO:BARACOAv82 HX5081 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 0000000000030002 Asic : 11 Provider : Default Test Operator Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open ST_LCD_TEST : PASSED FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK Last edited by gsmfun; 05-17-2011 at 04:19. |
The Following 28 Users Say Thank You to Advance-Box For This Useful Post: |
05-17-2011, 05:16 | #7 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @ryumahon It will be availble after lunchbreak @haji rahim This phone does not have a USB Port... Nokia Service Manul Level 1 & 2 shows that you should update the phone using a CA-101 cable... But they are totally wrong So only FBUS Works,, same as 1280, 1616, 1800 and C1-00 phones... B.R> |
The Following 3 Users Say Thank You to Advance-Box For This Useful Post: |
05-17-2011, 05:45 | #10 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: colombia
Member: 576776 Status: Offline Thanks Meter: 133 | Quote:
05-17-2011, 05:54 | #11 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
Regards Subr4t4 | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
fbus-mbus | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-05-1999 13:46 |
