Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-07-2013, 16:35   #1 (permalink)
Member: 7077
X1-01 RM-713 dead phone flashing
Hi!
I have a nokia x1-01 rm-713 which i tried to flash it with mt-box and killed it.How can i bring it back to life with advance box?What is the procedure for dead phone flashing?Thanks!
Old 01-08-2013, 02:51   #2 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Originally Posted by zafisinl View Post
Hi!
Autorize phone then past log here (with ATF)
Polaco
Old 01-08-2013, 05:23   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Hi!
Its a infinion CPU phone .
Simply flash the phone with ATF & dont try to erase it manually
Post the flashing LOG
Polaco
No need to authorize & this model will not authorize by ATF network
Br - srinibas
Old 01-08-2013, 07:04   #4 (permalink)
Member: 7077
Hi!
Phone is dead.Cannot communicate with atf.How to flash it?Tried manually to checking infineon x1-01 and set phone mode power off but nothing flashing error.Tried buscheck same thing.Is there a way to communicate with a dead phne?
Old 01-08-2013, 07:12   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Hi!
If you are using big box then connect it with EXTENSION port . If not booting after that ( must with good cable ) then check hardware
Br - srinibas
Old 01-08-2013, 08:05   #6 (permalink)
Member: 7077
I am using nitro atf.The phone was new.Dead after flashing with mt-box.The cable is from ipmart very good quality.
Old 01-08-2013, 08:30   #7 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
OK Bus-check & post the error LOG or screenshot here
Br - srinibas
Old 01-08-2013, 09:01   #8 (permalink)
Member: 7077
Here is the log:
Booting Phone...
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
SET BSI Load Done
Booting Phone...
ERROR: Phone did not Boot !!!
Try booting this phone with "Live Phone" option
Check the option beside the "Scan Phone" button
Flashing ERROR
Tried also with live phone checked and here is the log:
Booting Phone...
Flashing ERROR
Old 01-08-2013, 09:43   #9 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Live phone booting problem means all live phone ?
Have you select Infinion Tab ?
Br - srinibas
Old 01-08-2013, 09:52   #10 (permalink)
Member: 7077
I am only having problem with this phone.I flashed nokia 100 successfully.I didn't check live phone though.I selected infineon tab.
Old 01-08-2013, 09:57   #11 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
See the 8th no of post by you -
Booting Phone...
Br - srinibas
Old 01-08-2013, 10:30   #12 (permalink)
Member: 7077
I don't understand what you are saying.I tried with live phone enabled only becauseo in the first log that i posted it says at the end :
Flashing ERROR
Old 01-08-2013, 15:43   #13 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: UseGooGle
Originally Posted by srinibas View Post
About
authorize Phone..
Br - srinibas
hI...
I think, the step authorize phone is very useful way for check if the Phone is Live o dead (ever talking about USB conexion)
Thnks for Info Sr
Polaco
Old 01-08-2013, 16:09   #14 (permalink)
Member: 7077
It doesn't have usb nokia x1-01.How do i autorize the phone?Thanks!
Old 01-08-2013, 16:25   #15 (permalink)
Member: 7077
The authorize function is only for bb5 and n9...
Page generated in 0.54696 seconds with 10 queries
