Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 08-09-2012, 01:41   #1 (permalink)
Member: 1710813
x2-01
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned
Number of Sub Blocks 6 (0x06)
1 SYSTEM_ASIC_ID 01
Block Length : 17 (11)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000000
ID DWORD 1 : 00000000
ID DWORD 2 : 22000509
ID DWORD 3 : 200C0000
2 EM_ASIC_ID 02
Block Length : 5 (05)
ID DWORD 0 : 00005361
3 PUBLIC_ID 12
Block Length : 21 (15)
ID DWORD 1 : 0001CC04
ID DWORD 2 : 79095E66
ID DWORD 3 : 78F7F292
ID DWORD 4 : C5E49BE2
4 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
5 ROOT_KEY_HASH 14
Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
6 ROM_ID 15
Block Length : 9 (09)
CRC 0 : DE56D582
CRC 1 : BDDE7A3A
CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
Secondary Loader Sent....
ERROR: TRANSMISSION_TYPE_REQUEST_BB5 FAILED 0x00
TIPS:
1. Make Sure your Battery Power is Enough...
2. Make Sure Connectivity Drivers are installed...
3. DO NOT USE USB HUBS...
4. Use an ORIGINAL NOKIA CA-101D USB Cable...
Flashing Failed....
Booting/Flashing Failed...
Please Try Again...
Old 08-09-2012, 03:38   #2 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: 100.1585354
Are you loged to ATF Network, ATF Activated?
Here test in this Moment with a E5 Model
USB Phone Authorization Boot
1. Turn OFF Phone and wait 10 Seconds...
2. Connect the USB Cable to the PHONE Micro USB Port
3. Connect the USB Cable to the PC USB Port
BootFlashMode_DCT5
READING BOOTROM
BootFlashModeDCT5Ex Succeded After 0 Tries
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
ID DWORD 0 : 00000003
ID DWORD 1 : 00000226
ID DWORD 2 : 00010007
ID DWORD 3 : 600C1921
ID DWORD 4 : 02031104
2 EM_ASIC_ID 02
ID DWORD 0 : 00000C35
3 EM_ASIC_ID 02
ID DWORD 0 : 00000C30
4 PUBLIC_ID 12
ID DWORD 0 : 1D100109
ID DWORD 1 : 6BDA0344
ID DWORD 2 : C84DA47F
ID DWORD 3 : 8C0981DC
ID DWORD 4 : 8B465465
5 ASIC_MODE_ID 13
Mode Id : 00
6 ROOT_KEY_HASH 14
Hash : 91 6F 75 21 7F 32 08 12 48 B1 5C 38 DF C8 E8 1B
7 ROM_ID 15
CRC 0 : E693EF0D
CRC 1 : AC22615B
CMT Secondary Loader: C:\ATF\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPUv11_2nd.fg
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 06
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> Type not in database
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0020 ->
Device ID : 0050 -> Type not in database
Revision ID : 0031
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> Type not in database
Revision ID : 0000
5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MuxOneNAND 03
Device Index : 00
Revision ID : 0031
6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
Block Length : 09
Data :
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Flash Descriptor
Device ID : 0050
Revision ID : 0000
Size : 20000000 (512 MB)
VPP Info : 0000
Erase10s : 1E
Block1s : 32
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
CMT Algorithm Loader: C:\ATF\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\Patched\RAPUv11_XSR17_alg .fg
Algorithm Loader Sent...
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
START READING RPL DATA
IMEI: 357920043540747
Reading : NPC... OK!
Reading : CCC... OK!
Reading : HWC... OK!
Reading : R&D... OK!
Reading : PARTNERC... OK!
Reading : RSA... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\ATF\AdvanceBox Turbo Flasher\Nokia\Backup\357920043540747\3579200435407 47_112930.rpl
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 00
CMT PAPUBKEYS HASH:
CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
FlashInfo.RestartMode : Test Mode
Requesting Authorization Code
Authorization Code Received
Verifying Authorization Code
Authorization Code is OK
Saving Authorization Code
Authorization File Save OK
Saving RSA Modulus
File Saving Complete!!!
Phone was Successfully Authorized
Super Dongle Repair, Stand Alone SX-4 and SL3
Decrypt PM 120 HASHES is NOW ENABLED
for this Phone...
Thank you for using The ATF Network
Time Taken to Complete Tasks: 00:00:17
br
Polaco
Old 08-09-2012, 11:18   #3 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
@abbassat1974
Solution already in your logs.. Look at TIPS given by ATF SW.
Old 08-09-2012, 13:36   #4 (permalink)
el-polaco's Avatar
Member: 1057178
Sonork: 100.1585354
Originally Posted by ..::Angel::.. View Post
@abbassat1974
Is a Non Stable test mode? or older loader..?
C3 Booting/Flashing Failed
can you explain Angel? Bcoz i use a Non Original usb BB Cable and never have a problem with my Monster Metal ATF Box .-
Thnks
Polaco
Old 08-10-2012, 04:26   #5 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thnks
Polaco
See , users not mention the condition of the mobile so you cant say what is the specific coz .
In that case so many coz of failure . 1 - hardware , 2 - Cable & 3 - Bad USB port .
Br - srinibas
Old 08-12-2012, 17:59   #6 (permalink)
Member: 643472
Sonork: 100.96901
Thnks
Polaco
Hi,
No, is not about local mode. TIPS 1 and 2 should be the solution.
Cable doesn't matter.
sagem my-x2 unlocking codes...plz! thecremeegg Phone Unlocking Codes & Maps 1 10-09-2003 20:38
Sagem My-x2,x6,g5 nyonyo Wanted Products 1 09-18-2003 15:02
Solution for MY X2 VINCECHRIS Phone Unlocking Codes & Maps 0 09-16-2003 06:57
Solution for MY X2 ???? VINCECHRIS ARM9 BASED M62 / M62+ 2 09-15-2003 18:04
my-x2 unlock code ? equinoks Phone Unlocking Codes & Maps 0 09-08-2003 13:09
Page generated in 0.64845 seconds with 11 queries
