08-07-2012, 09:53 | #1 (permalink) |
Freak Poster Join Date: Mar 2010
Member: 1248435 Status: Offline Thanks Meter: 28 | x2-01 after flashing white lcd <<< SOLVED >>> Processing Image File : rm709__08.70.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 504 Entry Point: 0x01F2 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm709__08.70.ppm_i2 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 103 Entry Point: 0x0113 Page Format : -1 MAX PAGE : 0x0000E000 Processing Image File : rm709__08.70.image_i2_059C7P6 CMT Type : BB5 CMT Algorithm : XSR 1.6 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 548 Entry Point: 0x0147 Page Format : -1 MAX PAGE : 0x0000E000 AUTO SELECTED DEAD USB FLASHING... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 READING BOOTROM BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 6 (0x06) 1 SYSTEM_ASIC_ID 01 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00000000 ID DWORD 2 : 22000509 ID DWORD 3 : 200C0000 2 EM_ASIC_ID 02 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00005361 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000000 ID DWORD 1 : 00AC8437 ID DWORD 2 : 0F00D518 ID DWORD 3 : EB4D37A7 ID DWORD 4 : 04467121 4 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 5 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E 6 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : DE56D582 CRC 1 : BDDE7A3A CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_u sb2nd.fg Secondary Loader Sent.... MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 06 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0010 -> Device ID : 0011 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0431 6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5 Block Length : 09 BB ASIC Index : CMT 00 Data : SearchForBootstrap_DCT5 : No Error - 0 (0x00) Flash Descriptor Manufacturer Code : 00EC Device ID : 0030 Extended/Fixed ID : 0000 Revision ID : 0000 Size : 08000000 (128 MB) VPP Info : 0000 Erase10s : 1E Block1s : 32 BErase1s : 02 Reserved0 : 00 Reserved1 : 00 Reserved2 : 00 CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_X SR16_usbalg.fg Algorithm Loader Sent... FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) FUR control Ok START READING RPL DATA IMEI: 356266044855176 Reading : NPC... OK! Reading : CCC... OK! Reading : HWC... OK! Reading : R&D... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\356266044855176\3562660448551 76_102250.rpl Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 00 CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-709\ ImageFilename: rm709__08.70.mcusw Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : RND ASIC Index : CMT 0 Certificate 5 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 4E 44 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 B6 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00020000 Size : 025E0000 Partition 2 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 02A00000 Size : 04B40000 Partition 3 ID : 0000000A PMM Attribute : 00000001 RW Start Address : 07540000 Size : 00600000 Partition 4 ID : 0000000B Attribute : 00000001 RW Start Address : 07B40000 Size : 00180000 PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000025E0000000000080000000102A0000004B400 000000000A0000000107540000006000000000000B00000001 07B40000001800000D PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x90 (144) ERASE Blocks : 0x03 (3) 0 ERASE_AREA_BB5 0x12 Block Length : 0x2B (43) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00000000-0001FFFF 1 : 00020000-000203FF 2 : 00060000-012FFFFF 3 : 01300000-01DFFFFF 4 : 02600000-029FFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000 2 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info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uccessfully Erased... Total blocks to write : 504 >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : MCUSW1 >> CMT Rootkey Hash CERT : GENIO_INIT >> CMT Rootkey Hash CERT : ISA+DYNSW ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-709\ ImageFilename: rm709__08.70.ppm_i2 StartErase_DCT5... BlockLength : 0x0E (14) ERASE Blocks : 0x01 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 01E00000-025FFFFF ERASE_REQUEST_BB5 : 5001120B00030001E00000025FFFFF9E Successfully Erased... Total blocks to write : 103 ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-709\ ImageFilename: rm709__08.70.image_i2_059C7P6 StartErase_DCT5... BlockLength : 0x3F (63) ERASE Blocks : 0x02 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 02A00000-0753FFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID : 0x02000000 Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000 ERASE_REQUEST_BB5 : 5001120B00030002A000000753FFFFE4 FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E Successfully Erased... Total blocks to write : 548 ContinueFlash_DCT5 Complete Continue Flash Complete : : No Error - 0 (0x00) Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 2 Flashing Done... Total Flashing Time (Erase + Flashing) : 00:00:22 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Operation Cancelled... Phone is not Connected OR it is not in the Required Mode... Reboot the Phone and Enable "PC Suite" Mode |
08-07-2012, 15:20 | #6 (permalink) |
Freak Poster Join Date: Oct 2005 Location: TUNISIA
Member: 190067 Status: Offline Thanks Meter: 68 | yesterday i have flashed same model but this bug from atf software because in last step (Waiting for Phone to Start-Up..(Max 150 seconds) )phone go in test mode and drivers installed and tryed many time to remove cable and plug it again in phone but no success... so last chance to wait untill time up (150 seconds) and evrything ok. |
