Hi, phone was working properly just it was not deleting the call logs, so i decided to flash it but it hangs on 54% of MCU flashing i used another flash file but stil same problem.
Number of Image Files: 3
Processing Image File :
rm772__08.60.mcusw
rm772__08.60.ppm_m_a
rm772__08.60.image_m_a_059H128
AUTO SELECTED DEAD USB FLASHING...
If Phone Booting does not Start in 5 Seconds,
Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly...
Infineon USB Boot: F00A1FB300020303010100FF
Sending PBL...
PBL Successfully Sent...
Sending SBL...
SBL Successfully Sent...
Setting Transmission Speed Done...
Flash Chip Manufacturer: Intel Electronics Corp.
Flash Boot Successful...
Unique Data: 02300412161B1817
Original Product Code: 059H164
Reading : CCC... OK!
Reading : HWC... OK!
Reading : NPC... OK!
RPL Backup was Successful...
Plain RPL saved to:
C:\AdvanceBox Turbo Flasher\Nokia\Backup\357406043600723\3574060436007 23_20045.rpl
Data Sections : 04
Current File : rm772__08.60.mcusw
Compile Name: rm772__08.60.mcusw_ebl_psi.fls
Image Type : Main Firmware
Data Size : 26742152 Bytes
Sending Certificate Block
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01
FIRMWARE Erase Block: 0x40000000~0x4001FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 131072 bytes
Data Checksum: 849B
Uploading Data Blocks to phone...
Block Write Successful...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02
FIRMWARE Erase Block: 0x40040000~0x4005FFFE
Start Erasing...
Block Erase Done...
Data Checksum: 7ADA
Processing Section 03
FIRMWARE Erase Block: 0x40060000~0x4015FFFE
Start Erasing...
Block Erase Done...
Data Size: 1048576 bytes
Data Checksum: AEDE
Processing Section 04
FIRMWARE Erase Block: 0x40280000~0x41B3FFFE
Start Erasing...
Block Erase Done...
Data Size: 25427968 bytes
Data Checksum: 1698
