Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 01-19-2011, 07:53   #1 (permalink)
Frenzy_2020's Avatar
Member: 789089
Sonork: 100.1617***
x2 flash error
Hi ATF team,
Got this x2 for flashing tried via used got the following errors
Number of Image Files: 3
Processing Image File :
 rm618__04.90.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 650000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  506
Entry Point:  0x01E5
Page Format : -1
MAX PAGE : 0x0000E000
 rm618__04.90.ppm_mi
CMT Type : BB5
Number of Blocks :  114
Entry Point:  0x0100
Page Format : -1
 rm618__04.90.image_mi_0596510_004
CMT Type : BB5
Number of Blocks :  336
Entry Point:  0x0134
Page Format : -1
AUTO SELECTED DEAD USB FLASHING...
 If Flashing DOES NOT Start in 5 Seconds,
 Then Perform Steps 1, 2, 3 and 4...
1. Remove USB and Battery...
2. Insert USB.
3. Insert Battery. (Some phones boot automatically)
4. Please Power on phone shortly..
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
 BootRom Verified!
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 6 (0x06)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 17  (11)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000000
     ID DWORD    1 : 00000000
     ID DWORD    2 : 22000509
     ID DWORD    3 : 200C0000
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00005361
  3  PUBLIC_ID 12
     Block Length  : 21  (15)
     ID DWORD    1 : 00B1921A
     ID DWORD    2 : 792A0776
     ID DWORD    3 : 1AC183B3
     ID DWORD    4 : E062C975
  4  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
     Hash          :  1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
  6  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
START FLASHING
RawLoaderExtract: Processing rm618__04.90.mcusw
Match LOADER : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_usb2nd.fg
Loader Uploaded.....
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0020 ->
   Device ID         : 0030 -> Type not in database
   Revision ID       : 0131
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Revision ID       : 0131
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              :
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
ROOTHASH : 1B0D74C532CA1C6133940C740E8C786E
Match File.....C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\BB5_USBLoaders\BCM21351_XSR16_usbalg.fg
Done!
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok
 START READING RPL DATA
ERROR: NPC is Corrupted..., 3
 RPL Backup is Skipped
Pabub KEY Request
 No PAPUBKeysHash Returned
ImagePath:
ImadeFilename: rm618__04.90.mcusw
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 00020000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02900000
            Partition    3
              Start Address   : 07540000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000000200020000024E000000000008000000010290000004C400000000000A0000000107540000006000000000000B0000000107B40000001800001D
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0x90  (144)
ERASE Blocks :  0x03  (3)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x2B (43)
            Device Index     : 0x00
               0             : 00000000-0001FFFF
               1             : 00020000-000203FF
               2             : 00060000-011BFFFF
               3             : 011C0000-01CFFFFF
               4             : 02500000-028FFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B00030000020000000203FF120B00030000060000011BFFFF120B000300011C000001CFFFFF120B00030002500000028FFFFF69
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000A00000001000000020000006400000002000000020000000100000000000000003B
ERASE_REQUEST_BB5 : 5001192F00030000000002000000000000000B00000000000000020000006400000002000000020000000100000000000000003B
Successfully erased..
 Image File Not Found...
Flashing Failed....
 Booting/Flashing Failed...
 Please Try Again...
I also have the usb to fbus cable by gpg but dont know how to use it if someone can guide me through it
thanks in advance
frenzy
Old 01-19-2011, 12:44   #2 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Originally Posted by Frenzy_2020 View Post
Hi ATF team,
 rm618__04.90.mcusw
CMT Type : BB5
Entry Point:  0x01E5
Page Format : -1
 rm618__04.90.ppm_mi
CMT Type : BB5
Entry Point:  0x0100
Page Format : -1
CMT Type : BB5
Entry Point:  0x0134
Page Format : -1
2. Insert USB.
BootFlashMode_DCT5
 BootRom Verified!
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  PUBLIC_ID 12
  4  ASIC_MODE_ID 13
     Mode Id       : 00
  5  ROOT_KEY_HASH 14
  6  ROM_ID 15
     CRC         0 : DE56D582
     CRC         1 : BDDE7A3A
START FLASHING
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0131
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0131
   Block Length      : 09
   Data              :
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Done!
FUR control Ok
Pabub KEY Request
ImagePath:
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
            Device Index     : 0x00
            Device Index     : 0x00
            Device Index     : 0x00
Flashing Failed....
 Please Try Again...
thanks in advance
frenzy
Hi,
When you manual Load the flash files you need to click the button "Save Selected Files as Default for User ini"
Thomas
Old 01-19-2011, 13:15   #3 (permalink)
Advance-Box's Avatar
Member: 651945
After click "Save Selected Flash Files for Default Files for User INI"...
Select USER INI
then click the "FLASH" Button
B/R
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-12-2012 12:26
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-28-1999 15:57
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 08-16-1999 12:20
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 07-07-1999 12:27
Page generated in 0.25858 seconds with 11 queries
