05-10-2012, 13:04 | #1 (permalink) |
Junior Member Join Date: Oct 2007
Member: 613859 Status: Offline Thanks Meter: 1 | x2 rm-618ERROR: Phone is NOT AUTHORIZED Code: ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020819 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.12 Software Version : v8.70 AdvanceBox SN : 89ADD9D2FD1A1E58C5936EFB Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Operation Cancelled... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 353423046437692 IMEI Spare : A353423046437690 IMEI SV : 33534230464376912F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: 3994D75AI Product Code : 0595310 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia MEA BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 2000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: meaa_0595310 V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 30:38:55:A2:B5:55 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00BC0000040A4E2000 DCC Ver: 003005 Status : OK Make sure you have installed the COMPLETE Flash Package for this Phone... Goto "Settings" --> "Nokia Settings" and verify that the Folder where you installed your Flash Files are in the "PRODUCT PATH TO SCAN" List... Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 353423046437692 IMEI Spare : A353423046437690 IMEI SV : 33534230464376912F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: 3994D75AI Product Code : 0595310 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia MEA BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 2000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: meaa_0595310 V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 30:38:55:A2:B5:55 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ERROR: Phone is NOT AUTHORIZED! Authorize this phone via The ATF Network |
The Following User Says Thank You to elgakar For This Useful Post: |
05-10-2012, 13:45 | #5 (permalink) |
Member: 613859 Status: Offline Thanks Meter: 1 | i want unlock this poner Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 352699042419260 IMEI Spare : A352699042419260 IMEI SV : 33526990424192612F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: DNP064859 Product Code : 059C3T3 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia C BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 1000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: kpn nl V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 80:50:1B:49:4A:E9 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2040800000000000 NETWORK NAME : KPN;Netherlands [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00BC0000040A4E2000 DCC Ver: 003005 Status : OK ================================================== ==== Selected VPL File: RM618_0595310_04.80_015.vpl ================================================== ==== Variant Details : RM-618 MEA-1 RED ARABIC Software Version : 04.80 Product Type : RM-618 Product Code : 0595310 Variant Version : 015 Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 352699042419260 IMEI Spare : A352699042419260 IMEI SV : 33526990424192612F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: DNP064859 Product Code : 059C3T3 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia C BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 1000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: kpn nl V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 80:50:1B:49:4A:E9 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2040800000000000 NETWORK NAME : KPN;Netherlands [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ERROR: Phone is NOT AUTHORIZED! Authorize this phone via The ATF Network |
05-10-2012, 14:59 | #7 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | How to Authorize and Decrypt PM120 HASH for BF unlock: http://forum.gsmhosting.com/vbb/7135826-post7.html BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
05-10-2012, 16:36 | #8 (permalink) |
Member: 613859 Status: Offline Thanks Meter: 1 | h do this but he can"t read hash this is info ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020819 Library Version : 00030207 Box Type : ATF Nitro Box Firmware : LogiCore 10.3.12 Software Version : v8.70 AdvanceBox SN : 89ADD9D2FD1A1E58C5936EFB Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done ///////// /// /// /////// /////// ///////// /// /// /// /// // /// /// /// /// /// /// /// /////// /////// /// /// /// /// /// /// /// /// /// /// /// /// ///// /// /// /////// ////// ======================================= /// /// /// ///////// /////// ////// ///// /// /// /// /// // /// /// /// ///// /// /// /////// /// /// /// //// /// /// /// /// /// /// /// /// /// /// /// /// ////// ======================================= Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 352699042419260 IMEI Spare : A352699042419260 IMEI SV : 33526990424192612F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: DNP064859 Product Code : 059C3T3 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia C BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 1000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: kpn nl V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 80:50:1B:49:4A:E9 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2040800000000000 NETWORK NAME : KPN;Netherlands [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00BC0000040A4E2000 DCC Ver: 003005 Status : OK ================================================== ==== Selected VPL File: RM618_0595310_04.80_015.vpl ================================================== ==== Variant Details : RM-618 MEA-1 RED ARABIC Software Version : 04.80 Product Type : RM-618 Product Code : 0595310 Variant Version : 015 Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 352699042419260 IMEI Spare : A352699042419260 IMEI SV : 33526990424192612F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: DNP064859 Product Code : 059C3T3 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia C BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 1000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: kpn nl V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 80:50:1B:49:4A:E9 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 8000000000000000 PROVIDER KEY : 2040800000000000 NETWORK NAME : KPN;Netherlands [GSM] LOCK COUNTERS : KEYPRESS 0/3, FBUS 1/10 SIMLOCK TABLE : Block [1] 1:Close Block [2] 1:Close SIMLOCK STATE : LOCKED SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ERROR: Phone is NOT AUTHORIZED! Authorize this phone via The ATF Network |
05-10-2012, 17:04 | #10 (permalink) |
Member: 613859 Status: Offline Thanks Meter: 1 | yas i'm do this REALY HARD TO READ THIS but not read and i'm use anther phone to read he not read too this info anther phone and he is not locked Basic Phone Information ================================================ MCU Version: V 04.80 03-08-10 RM-618 (c) Nokia IMEI Plain : 353423046437692 IMEI Spare : A353423046437690 IMEI SV : 33534230464376912F Phone Model: Nokia X2-00 Category : Entry Phone Type : RM-618 ================================================ Extended Phone Information ================================================ Product Serial Number: 3994D75AI Product Code : 0595310 Module Code : 0204491 Basic Production Code: 0591973 Long Production SN : 0 PPM SW Version : V 04.80 03-08-10 RM-618 (c) Nokia MEA BT MCM Version : 2.31-SP2.31 MCU SW Version : V 04.80 03-08-10 RM-618 (c) Nokia HW Version : 2000 RFIC Version : 9 LCD Version : SEIKO BOM ID : 00 Content Pack Version : Content: meaa_0595310 V 04.80 03-08-10 RM-618 (c) Nokia Bluetooth ID : 30:38:55:A2:B5:55 CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ CONFIG KEY : 0000000000000000 PROVIDER KEY : 2440700000000000 NETWORK NAME : Nokia Default;Finland LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10 SIMLOCK TABLE : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK STATE : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ERROR: Phone is NOT AUTHORIZED! Authorize this phone via The ATF Network |
05-10-2012, 17:16 | #11 (permalink) |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Grrrrrrrrrrr :O( Man, you still didn't get it. This is last time I'm explaining you, if still don't get I will close this thread. 1. This is SL3 Based Phone... You cannot unlock it DIRECT, need to BruteForce it using own SUPER PC or ATF Server for 25 BF Credits. 2. You cannot DECRYPT/UNLOCK this phone if ITS NOT AUTHORIZED by ATF NETWORK... How to Authorize Phone: http://forum.gsmhosting.com/vbb/7135826-post7.html - Read this again and again, if you still don't understand how to do it. 3. How to UNLOCK SL3 Phones: - AUTHORIZE PHONE via ATF NETWORK - DECRYPT PM120 HASHES - UPLOAD TO ATF SERVER or BRUTEFORCE using OWN SUPER PC 4. IF YOU WANT UNLOCK THIS PHONE DIRECT - THAN ITS NOT POSSIBLE !! Hope this will help you :O( |
05-10-2012, 17:26 | #12 (permalink) |
Member: 613859 Status: Offline Thanks Meter: 1 | i now this 4. IF YOU WANT UNLOCK THIS PHONE DIRECT - THAN ITS NOT POSSIBLE . but i need read hash becus i will sand to server to unlock my be this porblm on cabl or atf netro i'don"t no and i"m usu all Solutions but he is not read any hash think you for help Last edited by elgakar; 05-10-2012 at 17:35. |
05-10-2012, 17:56 | #13 (permalink) | |
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Quote:
In order to Read HASH, You MUST do it first: 1. Go to ATF Network tab 2. Select USB Option 3. Click Authorize a BB5 HASH Phone When its done... go for step # 4: 4. Decrypt PM120 HASH from IMEI and LOCKS tab BR | |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Phone Stuff for FREE & KEy-GEn For Logo Editor ! | BoNtEk - ThA WtC MeMbA | Nokia Multimedia | 8 | 10-31-2012 20:17 |
