Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 10-28-2010, 16:10   #1 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
X3 fbus flashing bug can you fix this ??
Hi I use v5.90 and still can't flash X3 nokia RM-540 can you fix this in upcoming update ?? Problem is the same like sometime ago was with 6700c. I waiting for solution. Cable is 100% OK I flash this phone with the same cable without any problem with other box.
16:47:24 : MCU: V 04.11 09-12-09 RM-540 (c) Nokia
16:47:24 : IMEI: 352008043849113
16:47:24 : Model : Nokia X3-00
16:47:24 : Product Serial Number: KKV320508
16:47:24 : Product Code : 0580753
16:47:24 : Module Code : 0204201
16:47:24 : Basic Production Code: 0578316
16:47:24 : Default SN Type : 0
16:47:24 : MCU SW Version : V 04.11 09-12-09 RM-540 (c) Nokia B
16:47:25 : BT MCM Version : 1673-46034
16:47:25 : PPM Version : V 04.11 09-12-09 RM-540 (c) Nokia
16:47:25 : HW Version : 2000
16:47:25 : RFIC Version : 0831
16:47:25 : DSP Version : ICPR91_09w44_RC
16:47:25 : LCD Version : SEIKO
16:47:25 : Content Pack Version : Content: b_0580753 V 04.11 09-12-09 RM-540 (c) Nokia
16:47:25 : AHNE Version : 41
16:47:26 : Retu Version : 40
16:47:26 : Tahvo Version : 00
16:47:26 :
16:47:26 : ******** Reading SimLock ********
16:47:26 : CONFIG KEY: 0000000000000000
16:47:26 : PROVIDER KEY: 2440700000000000
16:47:26 : Provider : AT&T;U.S.A. (3650)
16:47:26 : Counters : 0/3 , 0/10
16:47:26 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
16:47:26 : SP Lock Status : Not Locked
16:47:26 :
16:47:26 : SIMLOCK_TEST : PASSED
16:47:26 : SECURITY_TEST : PASSED
16:47:26 : SECURITY_CODE : 12345
16:47:27 : PHONE_MODE : LOCAL MODE
16:47:27 :
16:47:27 : ================================================
16:47:27 : Dynamic Camera Configuration
16:47:27 : DCC ID : NI00IIIIRR0301035420
16:47:27 : DCC Ver: 003008
16:47:27 : Status : OK
16:47:27 :
16:47:27 :
16:48:01 : Number of Image Files: 3
16:48:02 : MCU: V 04.11 09-12-09 RM-540 (c) Nokia
16:48:02 : IMEI: 352008043849113
16:48:02 : Model : Nokia X3-00
16:48:02 : Product Serial Number: KKV320508
16:48:02 : Product Code : 0580753
16:48:02 : Module Code : 0204201
16:48:02 : Basic Production Code: 0578316
16:48:02 : Default SN Type : 0
16:48:02 : MCU SW Version : V 04.11 09-12-09 RM-540 (c) Nokia B
16:48:02 : BT MCM Version : 1673-46034
16:48:02 : PPM Version : V 04.11 09-12-09 RM-540 (c) Nokia
16:48:02 : HW Version : 2000
16:48:02 : RFIC Version : 0831
16:48:02 : DSP Version : ICPR91_09w44_RC
16:48:03 : LCD Version : SEIKO
16:48:03 : Content Pack Version : Content: b_0580753 V 04.11 09-12-09 RM-540 (c) Nokia
16:48:03 : AHNE Version : 41
16:48:03 : Retu Version : 40
16:48:03 : Tahvo Version : 00
16:48:03 :
16:48:03 : ******** Reading SimLock ********
16:48:04 : CONFIG KEY: 0000000000000000
16:48:04 : PROVIDER KEY: 2440700000000000
16:48:04 : Provider : AT&T;U.S.A. (3650)
16:48:04 : Counters : 0/3 , 0/10
16:48:04 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
16:48:04 : SP Lock Status : Not Locked
16:48:04 :
16:48:04 : SIMLOCK_TEST : PASSED
16:48:04 : SECURITY_TEST : PASSED
16:48:04 : SECURITY_CODE : 12345
16:48:05 : PHONE_MODE : LOCAL MODE
16:48:05 :
16:48:05 : ================================================
16:48:05 : Dynamic Camera Configuration
16:48:05 : DCC ID : NI00IIIIRR0301035420
16:48:05 : DCC Ver: 003008
16:48:05 : Status : OK
16:48:05 :
16:48:05 :
16:48:05 : PM 120 Found...
16:48:09 : PM 308 Found...
16:48:09 : Certificate saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 04.11 09-12-09 RM-540 (c) Nokia_352008043849113_Not Locked_164805.pm
16:48:09 : Changing MODE : FLASH
16:48:12 : VBATT OFF...
16:48:15 : VBATT ON
16:48:15 : Setting VBATT Done!...
16:48:18 : VBATT OFF...
16:48:21 : VBATT ON
16:48:22 : Setting VBATT Done!...
16:48:25 : VBATT OFF...
16:48:28 : VBATT ON
16:48:33 : Setting VBATT Done!...
16:48:34 : BootFlashModeDCT5Ex Failed
16:48:34 : Failed to complete RPL backup..
16:48:50 : VBATT OFF...
16:48:53 : VBATT ON
16:48:54 : Setting VBATT Done!...
16:48:56 : VBATT OFF...
16:49:00 : VBATT ON
16:49:00 : Setting VBATT Done!...
16:49:03 : VBATT OFF...
16:49:06 : VBATT ON
16:49:11 : Setting VBATT Done!...
16:49:12 : BootFlashModeDCT5Ex Failed
16:49:12 : Failed to complete RPL backup..
16:49:41 : Forcing Test Mode via BUSCHECK...
16:49:44 : VBATT OFF...
16:49:47 : VBATT ON
16:49:48 : Setting VBATT Done!...
16:49:50 : VBATT OFF...
16:49:54 : VBATT ON
16:49:54 : Setting VBATT Done!...
16:49:56 : VBATT OFF...
16:50:00 : VBATT ON
16:50:05 : Setting VBATT Done!...
16:50:05 : BootFlashModeDCT5Ex Failed
16:50:05 :
16:50:05 : ERROR : PHONE READ INFO FAILED
16:50:05 :
16:50:05 : Use "BUSCHECK" Button to Force the Phone
16:50:05 : into Local Mode... Then "SCANPHONE" after.
16:50:05 :
16:50:05 : For N95, N95-8GB and E90 Phones, you need a
16:50:05 : Test Mode Adapter to provide some Extra Power
16:50:05 : so that the Phone will go into Local Mode...
16:50:07 :
Old 10-28-2010, 16:49   #2 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Just open AdvanceBox.ini using notepad, and edit it to VSIG=40 when flashing
X3-00 phones. Do not forget to save the AdvanceBox.ini after you edit it.
After edit and save, run ATF software and flash you X3-00.
PS: After flash, change ini to it's oryginal setting!
Old 10-28-2010, 16:55   #3 (permalink)
agentot's Avatar
Member: 107027
@wgmmmx1
can be u have old cable. so u have to add 2 resistor of 7.5k like this
edited x3 gpg cable
br
sasą
Old 10-28-2010, 17:20   #4 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
I change this like you write but still same the same error nothing change.
Old 10-28-2010, 17:20   #5 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Originally Posted by agentot View Post
@wgmmmx1
edited x3 gpg cable
br
sasą
I MOD cable and add 7,5k ressistors 2x but this still not help.
Old 10-29-2010, 10:39   #6 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
OK I find problem like always bad biulded cable bad mounted pinout in plastic and becosue this not work not all pin good connection. Bad that this cable is from GPG. Now I see that all cable are **** even if cost bigger money.
I find other cable
and all work ok. Even no need modification INI file all work ok.
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-540\rm540__08.50.mcusw
CMT Type : BB5
CMT Algorithm : XSR 1.6
Secondary Sending Speed    : 3250000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 19500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  136
Entry Point:  0x0259
Page Format : -1
MAX PAGE : 0x00040000
VBATT OFF...
VBATT ON
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 73793000  (0xE8) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00000001
     ID DWORD    3 : 020C1921
     ID DWORD    4 : 02034100
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00001040
  3  ROM_ID 15
     ID DWORD    0 : 00001030
  4  PUBLIC_ID 12
     ID DWORD    0 : 17900113
     ID DWORD    1 : 616F0E49
     ID DWORD    2 : D7F8792A
     ID DWORD    3 : AB9124F2
     ID DWORD    4 : 4D638A8C
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
 MessageID  : C1
 SubBlocks  : 06
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : RAM  05
   Device Index      : 00
   Manufacturer Code : 0000 -> Flash
   Device ID         : 0000 -> not detected
   Extended/Fixed ID : 0000
   Revision ID       : 0000
 2 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Manufacturer Code : FFFF -> Flash
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : NOR  00
   Device Index      : 00
   Revision ID       : 0000
 4 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Index      : 01
   Manufacturer Code : 0000 -> SPANSION
   Device ID         : 0001 -> not used
   Revision ID       : 0000
 5 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MuxOneNAND  03
   Device Index      : 00
   Manufacturer Code : 00EC ->
   Device ID         : 0030 -> K5W1G13ACB
   Revision ID       : 0321
 6 Sub Block ID      : 35  NAND_DRIVER_VERSION_BB5
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0030 ExtID :0000 RevID :0321
 RAP3Gv40_XSR17_alg.fg
First Algo byte : 56
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   Size              : 08000000 (128 MB)
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_XSR17_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 01
PAPUB Keys Hash : CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5...
Partition Info
    Partition Blocks :   1
     1   PARTITION_INFO_BB5
            BB ASIC Index     : 0x00 CMT
            Device Type       : 0x03 MuxOneNAND
            Device Index      : 0x00
            Partition Version : 00010000
            Spare             : FFFFFFFF
            Num Partitions    : 00000004
            Partition    1
              Attribute       : 00000002  RO
              Start Address   : 000A0000
            Partition    2
              ID              : 00000008  FILESYSTEM
              Attribute       : 00000001  RW
              Start Address   : 02CC0000
            Partition    3
              Start Address   : 077C0000
            Partition    4
              Start Address   : 07B40000
PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF000000040000000300000002000A000002720000000000080000000102CC000004B000000000000A00000001077C0000003800000000000B0000000107B4000000180000C9
PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
ProcessPartitionInfo_DCT5 : No Error - 0 (0x00)
StartErase_DCT5...
BlockLength  :  0xE1  (225)
ERASE Blocks :  0x04  (4)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x4B (75)
            Device Index     : 0x00
               0             : 00020000-000203FF
               1             : 00060000-0009FFFF
               2             : 000A0000-0025FFFF
               3             : 003E0000-005DFFFF
               4             : 005E0000-010DFFFF
               5             : 01EC0000-01EDFFFF
               6             : 027C0000-02CBFFFF
               7             : 077C0000-07B3FFFF
               8             : 010E0000-01EBFFFF
     1   FORMAT_PARTITION_BB5 0x19
            Block Length     : 0x2F (47)
            Device Index     : 0x00
            Format Info ID   : 0x02000000
            Format Info      : 00000000000000080000000000000002000000640000000200000002000000010000000000000000
     2   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000A0000000100000002000000640000000200000002000000010000000000000000
     3   FORMAT_PARTITION_BB5 0x19
            Device Index     : 0x00
            Format Info      : 000000000000000B0000000000000002000000640000000200000002000000010000000000000000
ERASE_REQUEST_BB5 : 5004124B00030000020000000203FF000600000009FFFF000A00000025FFFF003E0000005DFFFF005E0000010DFFFF01EC000001EDFFFF027C000002CBFFFF077C000007B3FFFF010E000001EBFFFF192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000000000192F00030000000002000000000000000A0000000100000002000000640000000200000002000000010000000000000000192F00030000000002000000000000000B0000000000000002000000640000000200000002000000010000000000000000BC
ERASING in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 15 STATUS_NAND_OK_BB5
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Num Bad Blocks    :  00000000
          Additional Bad    :  00000000
          Correctable ECC   :  00000000
Successfully erased..
Time Taken to Erase : 00:00:00
Is Flashing CLOCK AUTO : -1
Processing  : rm540__08.50.mcusw
Total blocks to write : 136
>>  CMT Rootkey Hash CERT : ADA
>>  CMT Rootkey Hash CERT : KEYS
>>  CMT Rootkey Hash CERT : PRIMAPP
>>  CMT Rootkey Hash CERT : PASUBTOC
>>  CMT Rootkey Hash CERT : PAPUBKEYS
>>  CMT Rootkey Hash CERT : RAP3NAND
>>  CMT Rootkey Hash CERT : UPDAPP
>>  CMT Rootkey Hash CERT : DSP0
>>  CMT Rootkey Hash CERT : MCUSW
>>  CMT Rootkey Hash CERT : MCUSW1
>>  CMT Rootkey Hash CERT : GENIO_INIT
>>  CMT Rootkey Hash CERT : ISA+DYNSW
ContinueFlash_DCT5 Complete
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
FlashInfo.RestartMode : 1
DDR PROTOCOL ERROR: Phone did not Ack !!!
Continue Flash Complete :  : No Error - 0 (0x00)
Time Taken to Flash  : 00:00:13
Making delay between files for 5000ms
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-540\rm540__08.50.ppm_b
CMT Type : BB5
Number of Blocks :  23
Entry Point:  0x011D
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0321
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 01
No RESTORE CERTIFICATE FOUND IN IMAGE FILE
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
BlockLength  :  0x0E  (14)
ERASE Blocks :  0x01  (1)
            Block Length     : 0x0B (11)
            Device Index     : 0x00
               0             : 01EE0000-027BFFFF
ERASE_REQUEST_BB5 : 5001120B00030001EE0000027BFFFF74
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Processing  : rm540__08.50.ppm_b
Total blocks to write : 23
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
FlashInfo.RestartMode : 2
Time Taken to Flash  : 00:00:03
Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-540\rm540__08.50.image_b_0580753_004
CMT Type : BB5
Number of Blocks :  59
Entry Point:  0x0154
Page Format : -1
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0321
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 01
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
BlockLength  :  0x3F  (63)
ERASE Blocks :  0x02  (2)
            Device Index     : 0x00
               0             : 02CC0000-077BFFFF
            Device Index     : 0x00
ERASE_REQUEST_BB5 : 5002120B00030002CC0000077BFFFF192F0003000000000200000000000000080000000000000002000000640000000200000002000000010000000000000000CF
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Erase : 00:00:01
Processing  : rm540__08.50.image_b_0580753_004
Total blocks to write : 59
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
Time Taken to Flash  : 00:00:07
Total Flash Write Time (Flashing Only) : 00:00:24
Total Flashing Time (Booting + Erase + Flashing) : 00:00:34
 Waiting For Phone to go Online...
 5,  4,  3,  2,  1...
MCU: V 08.50 19-07-10 RM-540 (c) Nokia
Model : Nokia X3-00
Default SN Type      : 0
MCU SW Version       : V 08.50 19-07-10 RM-540 (c) Nokia             B
BT MCM Version       : 1673-46038
PPM Version          : V 08.50 19-07-10 RM-540 (c) Nokia
HW Version           : 2000
RFIC Version         : 0831
DSP Version          : ICPR91_10w11_2
LCD Version          : SEIKO
Content Pack Version : Content: b_0580753 V 08.50 19-07-10 RM-540 (c) Nokia
AHNE Version         : 41
Model : Nokia X3-00
Default SN Type      : 0
HW Version           : 2000
RFIC Version         : 0831
LCD Version          : SEIKO
AHNE Version         : 41
Retu Version         : 40
Tahvo Version        : 00
PHONE_MODE              : TEST MODE
Old 10-29-2010, 10:45   #7 (permalink)
PUNEET5154's Avatar
Member: 1023528
Sonork: 100.1594367
Thanks For Test Report...
Old 10-30-2010, 05:40   #8 (permalink)
.:Zulfiqar:.'s Avatar
Member: 1224733
Old 10-30-2010, 07:16   #9 (permalink)
GPGIndustries's Avatar
Member: 34016
Sonork: 100.67372
I find other cable
CMT Type : BB5
Entry Point:  0x0259
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0321
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 01
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
Certificate 4
  ASIC Index  : CMT  0
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
            Device Index     : 0x00
            Device Index     : 0x00
            Device Index     : 0x00
            Device Index     : 0x00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
CMT Type : BB5
Entry Point:  0x011D
Page Format : -1
VBATT OFF...
VBATT ON
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0321
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 01
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
            Device Index     : 0x00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
CMT Type : BB5
Entry Point:  0x0154
Page Format : -1
BootFlashMode_DCT5
                  TIME STARTS HERE
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 67E82268
     CRC         1 : F29CEA60
Checksum           C7
 MessageID  : C1
 SubBlocks  : 06
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 01
   Revision ID       : 0000
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0321
   Block Length      : 09
   Data              : XSR 1.6
 Checksum   : 36
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 0030
   Revision ID       : 0000
   VPP Info          : 0000
   Erase10s          : 1E
   Block1s           : 32
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPP INFO :
Algo Loader Sent...
FUR control Ok...
Using Internal VPP
Pabub KEY Request
   BB Asic Index   : 01
Partition Info
            Device Index      : 0x00
            Spare             : FFFFFFFF
            Partition    1
            Partition    2
            Partition    3
            Partition    4
StartErase_DCT5...
            Device Index     : 0x00
            Device Index     : 0x00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
          Block Length      :  0F
          BB ASIC Index     :  00
          Device Type       :  03
          Device Type       :  00
 5,  4,  3,  2,  1...
Model : Nokia X3-00
Default SN Type      : 0
HW Version           : 2000
RFIC Version         : 0831
LCD Version          : SEIKO
AHNE Version         : 41
Model : Nokia X3-00
Default SN Type      : 0
HW Version           : 2000
RFIC Version         : 0831
LCD Version          : SEIKO
AHNE Version         : 41
Retu Version         : 40
Tahvo Version        : 00
Hi,
I see you are facing problem with one of our cable. Strange thing is X3 cable is very tricky and we test each cable. So we are sure 100% cable is fine.
We had a patch of faulty cable but problem was solved after 1 week only. Could you please pm your adress I will arrange replacement for you. And would really appreicate you take some pictures of the cable you have now.
Hope you will find time to send me picture and send me. Thisis important for us. I only guess is this cable was from first patch.
I will give my best to make you believe is us
Thx
Christophe
GPGindustries
Old 10-30-2010, 07:56   #10 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Originally Posted by GPGIndustries View Post
Hi,
Thx
Christophe
GPGindustries
I have same GPG cable its have only 1 mbus pin..... and i modified this cable my self to 2 mbus pin and now cable is working good........i think gpg first patch cable only have 1 mbus pin cable....
Guljee
The Following User Says Thank You to guljee786 For This Useful Post:
Old 10-30-2010, 08:17   #11 (permalink)
Member: 973412
Gooooooood work atf team thankssssssssss
Old 10-30-2010, 11:21   #12 (permalink)
Member: 643472
Sonork: 100.96901
@wgmmmx1
Yes that was cable issue. Thanks for report!
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
fbus-mbus ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-05-1999 13:46
Page generated in 0.53925 seconds with 11 queries
