Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2004 Location: nono Age: 42
Member: 48947 Status: Offline Thanks: 3
| x3 flashing problem advance box team please need help same problem with 3 cable but all this cables work fine with my friend see log x3 flashing ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02034100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 19100306 ID DWORD 1 : D9300E49 ID DWORD 2 : FA60474F ID DWORD 3 : 283E54EF ID DWORD 4 : 64BBD89F 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum 72 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT Process Done! |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks: 1
| @agentot Just to confirm that it is RX2 problem... Can you open your cable, then desolder the RX2 wire from the RX2 pin ? And check if you get same error. |
| | #6 (permalink) |
| @agentot Ok, now we confirm that RX2 is the problem.. Reconnect now the RX2 wire and ready your mutitester. Set to Continuity check, connect cable to phone and check the reading on the RJ-45 head. GND to RX2 should be about 0.510 (PIN8 and PIN7 of the RJ-45) Do you get the same reading? |
| | #7 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2005 Age: 38
Member: 107027 Status: Offline Thanks: 178
| Quote:
is about 0.890 br sasą | |
| | #8 (permalink) |
| @agentot And when you connect the Multitester prongs directly to the phones RX2 and GND pads, do you also get 0.890 ? B.R. X-Shadow |
| | #10 (permalink) |
| @agentot Ok, now try to re-allign the cable at the back of the phone until you will get a very similar reading to 1,600 on the RJ-45 pins. This will give you a proper connection. Then try BUSCheck with EXE found here: When dct4 will support fbus flashing the unofficial one... Good Luck |
| | #11 (permalink) |
| Junior Member ![]() ![]() Join Date: May 2005 Age: 30
Member: 145546 Status: Offline Thanks: 24
| flashing x3 (BootFlashModeDCT5Ex Failed) AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK Reading Phone Information... MCU: V 04.11 09-12-09 RM-540 (c) Nokia IMEI: 351536041861830 Product code : 0583887 SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED ******** Reading SimLock ******** Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SL2 Phone Detected... Certificate saved to : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\Backup\sl2_certificate_V 04.11 09-12-09 RM-540 (c) Nokia_351536041861830_Not Locked_94958.pm Changing MODE : FLASH AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed Failed to complete RPL backup.. AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-540\rm540__04.11.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 020C192102034000 > 0203192102034000 > 020C192102034100 > 0203192102034100 > 0203192102054100 > 020C192102054100 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 136 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... BootFlashModeDCT5Ex Failed Operations Failed.... |
| The Following User Says Thank You to kelvin^_^ For This Useful Post: |
| | #12 (permalink) |
| @ kelvin^_^ All X3 cables modified or unmodified can read SIMLOCKS, phone info etc... It can make phone go into Local or Test Mode. However, you need to modify your cable to make it use 2 MBUS data lines in order for you to use your cable to FLASH your phone. Your error "BootFlashModeDCT5Ex Failed" is NOT a bug in our software. Umodifed cables or improperly connected cables will 100% give you errors in booting or flashing. For more information about X3 cable modification and some explanation why "most" X3 cables will not work, please visit this thread: TX2 error on nokia X3 using Gpg GTI cable B.R. X-Shadow |
| | #13 (permalink) | |
| Quote:
ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT now the value are (+or-) the same and the tool version is the unofficial. br sasą | |
| | #14 (permalink) |
| Here is my cable ... I cannot describe it better than with this picture. ![]() If your cable is 1:1 to my picture, and the connections are OK,, then it should work My Wires are just about 10 inches in total length. I have 3 X3 cables from 3 different factories and after modifying them with dual mbus and some adjustment in allignment, they are all working now. Take note if the pins in my drawing have no color, then do not connect anything to them of remove the gold pin completely from the cable. Last edited by X-Shadow; 03-26-2010 at 19:14. |
| | #15 (permalink) |
| After Modifig Cable still get same AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-540\rm540__04.11.mcusw CMT Type : BB5 CMT Algorithm : XSR 1.6 CMT Supported Hardwares : > 020C192102034000 > 0203192102034000 > 020C192102034100 > 0203192102034100 > 0203192102054100 > 020C192102054100 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 19500000Hz Message Reading Speed : 98000Hz Number of Blocks : 136 Entry Point: 0x0259 Page Format : -1 MAX PAGE : 0x00040000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 AdvanceBox Turbo Flasher Found Driver Version : 00020422 Library Version : 00030119 Initialize Device.... Init TRY : 1 Box Name : AdvanceBox Turbo Box Firmware : LogiCore 3.21.10 Software Version : v4.6 AdvanceBox SN : 85A5F21A853DB7EC92693F5E BOX Status : ACTIVATED INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 ************************************************** **** TIME START HERE ************************************************** **** BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0 (0x00) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00000001 ID DWORD 3 : 020C1921 ID DWORD 4 : 02034100 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001040 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00001030 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0B000114 ID DWORD 1 : 2A4C0E49 ID DWORD 2 : 4BEA551C ID DWORD 3 : 654C7ABF ID DWORD 4 : 7F6C44C1 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 7B 04 54 00 E1 75 20 22 F9 EB 80 B0 DE A9 C6 5D 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 67E82268 CRC 1 : F29CEA60 Checksum C6 BootCodeLen : 61 SearchForBootstrap_DCT5.. CMT Loader : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv40_2nd.fg PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" SearchForBootstrap_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT ERROR : Sending Loader Failed, CHECK PHONE RX2 PINOUT Operations Failed.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Nokia x3 flashing problem | laxman kumar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 13 | 11-12-2010 13:50 |
| X3 flashing problem.please help | rehman ali | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 02-23-2010 07:14 |
| nokia x3 flash problem | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 8 | 01-25-2010 17:09 |
| nokia X3 flashing problem | suffa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-10-2009 18:19 |
| O2 X3 Flashing Problem | zubairok | Infinity-Box | 5 | 08-27-2007 17:35 |
