10-01-2012, 11:17 | #3 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 826522 Status: Offline Thanks Meter: 33 | my srp credit is 0 will it work without credit. mobile 5130 ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL |
10-01-2012, 11:30 | #5 (permalink) |
Member: 826522 Status: Offline Thanks Meter: 33 | unit 5130 phone in contact service. when i click the start recovery option it doesnt work do it require any settings as itz only first time i am using this service. Basic Phone Information ================================================ MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia IMEI Plain : 35************** IMEI Spare : A355************ IMEI SV : 3355************* Phone Model: Nokia 5130c-2 Category : Classic Phone Phone Type : RM-495 ================================================ Extended Phone Information ================================================ Product Serial Number: IMN088274 Module Code : 0204024 Basic Production Code: 0567773 Long Production SN : 0 PPM SW Version : V 07.97 13-09-10 RM-495 (c) Nokia MEN BT MCM Version : 2222-302 MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia HW Version : 2000 RFIC Version : 06540601 DSP Version : ICPR72_10w01 LCD Version : SEIKO Content Pack Version : Content: mena_a1_bd_red V 07.97 13-09-10 RM-495 (c) Nokia AHNE Version : 30 RETU Version : 16 TAHVO Version : 22 Bluetooth ID : 00:25:CF:EE:CC:BB CS Type : GSM850, GSM900, GSM1800, GSM1900 ================================================ Simlock Information ================================================ Unable to read SP Data.. SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : LOCAL ================================================ Dynamic Camera Configuration ================================================ DCC ID : NIMMIIIIRRFF0A021001 DCC Ver: 002007 Status : OK |
10-01-2012, 11:31 | #6 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
No mater with SRP credit , SRP credit need on Level 3 job upload Level 1 from Flash DUMP = Free Level 1 from phone = Free Level 2 from phone = Free but after ATF network authorization Level 3 ( if fail Level 2 ) = 25 SRP credit Level 1 from Flash DUMP Can extract PM your DUMP file . Level 1 from phone Can recover PM from phone , not verify , The recover PM will work if PM not damaged inside Level 2 from phone Can recover PM from phone , verify the recover PM , some extend repair if found damaged . Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
10-01-2012, 11:35 | #7 (permalink) | |
Member: 826522 Status: Offline Thanks Meter: 33 | Quote:
10-01-2012, 11:42 | #9 (permalink) |
Member: 826522 Status: Offline Thanks Meter: 33 | yes 9.10 will update sooner. it works but it shows: ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: NOR Partition Detected STATUS: Skipping Defragmentation of Blocks STATUS: Scanning PM Entries... ERROR: Phone is not Authorized Authorize the Phone via The ATF Network REPORT: Total Elapsed Time 00:00:36 Last edited by srt6; 10-01-2012 at 11:49. |
10-01-2012, 12:00 | #10 (permalink) |
Member: 826522 Status: Offline Thanks Meter: 33 | ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: NOR Partition Detected STATUS: Skipping Defragmentation of Blocks STATUS: Scanning PM Entries... REPORT: PM 120 Sections Corrupted! Level 2 Recovery CANNOT Continue Level 3 Recovery is NEEDED for this Phone REPORT: Simlock Recovery Profile Saved i checked 2nd 5130 but shows same problem : ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: NOR Partition Detected STATUS: Skipping Defragmentation of Blocks STATUS: Scanning PM Entries... REPORT: PM 120 Sections Corrupted! Level 2 Recovery CANNOT Continue Level 3 Recovery is NEEDED for this Phone REPORT: Simlock Recovery Profile Saved Last edited by srt6; 10-01-2012 at 12:10. |
10-01-2012, 12:03 | #11 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Level 3 Recovery is NEEDED for this Phone this mean you need srp credit to use Level 3 Recovery |
The Following User Says Thank You to malka4u For This Useful Post: |
10-01-2012, 12:12 | #12 (permalink) |
Member: 826522 Status: Offline Thanks Meter: 33 | 2nd unit showing same problem: ATF SL3 Simlock Recovery Module v1.0 ================================================== ===== STATUS: Mounting Flash Dump... STATUS: NOR Partition Detected STATUS: Skipping Defragmentation of Blocks STATUS: Scanning PM Entries... REPORT: PM 120 Sections Corrupted! Level 2 Recovery CANNOT Continue Level 3 Recovery is NEEDED for this Phone REPORT: Simlock Recovery Profile Saved |
10-01-2012, 12:18 | #14 (permalink) |
Member: 1626780 Status: Offline Thanks Meter: 1,275 | @srt6 you need 25 srp credit and here is the process see this How To perform level 3 silmock recovery by Angel |
