Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > Language Editor
Old 04-18-2010, 16:41   #1 (permalink)
Member: 1220598
LanguagePackEdit 2.01 problems
Hello
When I try to write back the firmware (6235) after editing with the language pack editor 2.01 I got the following error:
(but same firmware without editing writes successfully back to the phone)
COM3 [VCP0] selected
module v3.12
Device: Autodetect 6228-6239 NAND
Checking data, wait...
Action: write flash NAND
write: Firmware
editor_corrected_RATECH35_08B_PCB01_GPRS_MT6235B_S 01.M800_YJS_N97_MLA_1030__fullflash_20100417-211046.B4M.bin.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
nfi area detection...
nfi scat area detected
nfi area detection finished: Ok
interface: BROM_DLL_v3.952.00
Connect...
Connecting...
Booting...
Release Power button now !
bootcode current/expected: 3.2/3.2
CPU: 6235:8A04:8A01
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M
chip size: 128Mb
page/spare size: 0800/0040
pages/block: 0040
bits i/o: 08
address cycles: 04
internal RAM size: 00010000
external RAM: absent
done
Set baudrate (115200)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02620000/059E0000
firmware size: 38Mb
ffs size: 89Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: M800_YJS_N97_WIFI_MLA_NOK_091211
detect NAND info...
number of areas to read: 1
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M800_YJS_N97_ WIFI_091210.bi
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 07
sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_YJS_N97_W IFI_MLA_NOK_091211.BIN
project-id: M800_YJS_N97_WIFI_MLA_NOK_091211, 00000000
code offset: 00000000
ffs offset/size [01]: 02620000/059E0000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
number of cores: 3
loading files...
number of areas: 3
done
write...
error: can not write flash: 0BC3:S_DA_NOR_FLASH_NOT_FOUND
error: last error: 0BC3:S_DA_NOR_FLASH_NOT_FOUND
Disconnect...
done
Finished, time used: 3 min 12 sec
Remove/Install battery now !
Old 04-20-2010, 10:48   #2 (permalink)
s.Mobi's Avatar
Member: 7436
Your edited flash open in Editor normally or no? Can you upload it to any filesharing service and give link to me in PM or here?
Old 04-20-2010, 12:16   #3 (permalink)
Member: 1220598
yes i'm edit it normally in editor, add some fonts and its all.
also there was problem with editing virtual keyboard it recognize it, but show only part of the keyboard.
here is two flash'es, before editing and after.
RapidShare: 1-CLICK Web hosting - Easy Filehosting
The Following User Says Thank You to futurpc For This Useful Post:
Old 04-20-2010, 14:52   #4 (permalink)
s.Mobi's Avatar
Member: 7436
Ok, tnx, i check what wrong - error in Editor or in Miracle.
Old 04-20-2010, 15:04   #5 (permalink)
Member: 1220598
Thank you for so prompt reply
Old 04-28-2010, 17:56   #6 (permalink)
Member: 1220598
is there any news about this issue ?
Old 05-17-2010, 10:57   #7 (permalink)
Member: 1220598
Editor or Miracle problem
Can you please inform me if there will be updated for the editor or the miracle when the problem will fixed ?
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 05-22-2012 11:13
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 06-16-2011 09:59
Need info for unliocking 2 lock (with pic microprocesors) Tomas Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-26-1999 01:00
Page generated in 0.33917 seconds with 11 queries
