03-06-2010, 11:47 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: inside forum
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | huawei 3308 dead Selected Model...Huawei c3308 Asking Server Access Take Few Seconds... Successed to connect server User name...xxxxxxxxxxxxxx Searching Phone Please Wait : Phone Found...Jan 10 200800:21:20Jun 29 200619:00:00SCNRZ...* Model Name.. C3308 Version.. C3308C53B106 Boot Version..: 6000P1B101 Hardware Version..: Ver.C Sending Boot Mode.. Phone Is In Boot Mode Now.. Unlocking Started...Huawei c3308 GETTING SECURITY DATA... CALCULATING BOOT AND MINLOCK... MINLOCK FOUND 1... ALL MINLOCK DISABLED... Total Time Take...00:01:22 Unlocking Finish Test Phone... |
03-06-2010, 14:11 | #2 (permalink) |
No Life Poster Join Date: Mar 2009
Member: 988879 Status: Offline Thanks Meter: 1,310 | i trying from last 2 days to find out problem i found some info is. if phone have Jan 10 2008 then your phone getting dead. but it have same version B106 don't know why huawei did this. if phone have Jan 04 2008 then your phone get unlock perfect without any problem. so solution for you try to keep battery out side from phone for few minutes to get it complete off. open huawei pst 1.25 or newer press & hold * + 5 then insert battery and insert cable keep holding that buttons. press power on once . if all this steps ok then huawei pst will show you phone "CONNECTED" select flash file from support area and flash set then unlock with combo. as you can see we supported B106 we was not awar there is 2 pcb type of huawei c3308 b106. we already ordered one pc like this date to make supported it untill there you can use REPAIR user code & cs button to detect version date. Best Regards. Advance Cdma Team. |
03-07-2010, 08:51 | #3 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Thanks for your response but as on combo news 3308 B106 supported.Not mentioned that either it is JAN 10 2008 or JAN 04 2008 I actual don't know who's fault is this sorry i am not going to blame combo team b,coz they work hard for us to give us best solution but my customer is now criying that i make his set dead he is not goin to blame team & now the phone is also not conneting with pst i already tried |
03-07-2010, 08:55 | #4 (permalink) | |
Member: 988879 Status: Offline Thanks Meter: 1,310 | Quote:
just leave battery out side for few minuts. its impossible to not connect in boot mode at any cost of unlocking trust me. just try harder to connect it. you success once then flash it. | |
The Following User Says Thank You to Advance cdma For This Useful Post: |
03-07-2010, 09:28 | #5 (permalink) |
Member: 759477 Status: Offline Sonork: 100.1618763 Thanks Meter: 111 | Thanks combo team for your good support after a hard try phone successfully connected & flashed with pst & become alive now clear it to all forum members check the date version of phone before make it unlock & I request team sort out this buz many many thanks to combo team for helping me |
The Following User Says Thank You to mediapeople For This Useful Post: |
03-07-2010, 13:27 | #6 (permalink) |
Member: 988879 Status: Offline Thanks Meter: 1,310 | thank you for test report. more info updated at sticky warning. http://forum.gsmhosting.com/vbb/showthread.php?t=944994 |
