Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker
Old 03-11-2010, 15:12   #1 (permalink)
caremobiles's Avatar
Member: 332724
Sonork: 100.1605077
Herald 110 Unlock problem.Please give any suggestion for unlock.
I have Herald 110 Model.It was came for unlock.I will try to unlock but it was not done.But this model is in supported list.Here is the log file:
Selected model: Herald
Reading Simlock data ...
Running MemDump task ...Done.
failed.
I was done which are given instructions step by step.Please solve this problem.Its urgent.
The Following User Says Thank You to caremobiles For This Useful Post:
Old 03-12-2010, 06:55   #2 (permalink)
Member: 332724
Sonork: 100.1605077
Is this Model supported are not for unlock?Please tell me any supporters.
Old 03-12-2010, 10:33   #3 (permalink)
Member: 133320
Me too . I have same problom with t-mobile wing
Old 03-14-2010, 18:34   #4 (permalink)
Member: 342221
t-mobile wing ( hera110 ) same
Old 04-26-2010, 09:12   #5 (permalink)
Member: 1153888
Herald T-Mobile Wing - how to unlock and how to solve problem
Set Security Policy ...Done.
Connected.
Syncing from  bkondisk.exe  to  dev:\
 "bkondisk.exe"Copying (New) ...  0/21 k   21/21 k  ok
CopyProcessMemoryToFile(00000042, b002709c, 00000010, simlock\docid.bin)
Connected.
Syncing from  dev:\simlock.bin  to  simlock
Error:  source pattern does not match a file:  \simlock.bin
Copy Failed
Usage:  CeCopy  [options] Source_FileSpec  Destination
Options:
    /is                  Include same files
    /s                   Include subdirectories
Arguments:
    Source_FileSpec      File specification denoting the source of the copy.
    Destination          Where files should be copied to.
For the source, wild cards or directory names may be specifed, as may be single
files.  The destination can be either a directory or a file name, depending
on the type of source specified.
By default, an argument is assumed to live on a local filesystem.  To indicate
that either argument denotes a location on a device connected via ActiveSync,
prepend 'dev:' to that argument.   To articulate that a local filesystem is
referenced, prepend 'desk:' to the argument.
Exiting.
error: simlock.bin not found
Simlock dump failed.
Please help!!!
The Following User Says Thank You to cj_neonyx For This Useful Post:
Old 05-22-2010, 17:18   #6 (permalink)
sakisager's Avatar
Member: 149804
Wink HTC Hera 110 unlock failed ?
Warning: no device connected.
Waiting for a device to connect...
Connected.
Connected.
Copy Failed
Options:
Arguments:
Exiting.
please guide me how to solve this
The Following User Says Thank You to sakisager For This Useful Post:
Old 05-22-2010, 22:37   #7 (permalink)
Fast Unlocking's Avatar
Member: 94675
Sonork: 100.8888
Why don t you read the sticky posts before posting it might be very helpful.
All is explained before.
br
MXKEY Team
Old 05-23-2010, 19:47   #8 (permalink)
Yaio's Avatar
Member: 256260
i have same problem exca110 i not fount one tuto for unlock wit mxkey nthis model
Yaio
jade
T3238 how unlock i try but no luck
Old 05-29-2010, 13:10   #9 (permalink)
Member: 503816
I have already problem with hera110
how can i unlock it sir?
Old 05-29-2010, 14:19   #10 (permalink)
A-H-T's Avatar
Member: 36394
same problem here
please check whats solution for it
wbr,
Old 05-29-2010, 19:33   #11 (permalink)
hugmax's Avatar
Member: 1038811
Sonork: 100.1585462
Index of /htc
please give the solution for unlock z1600 sparshman Infinity-Box 2 04-13-2010 08:36
Herald 110 Unlock problem.Please give any suggestion for unlock. caremobiles FuriouS TeaM Products 1 03-11-2010 15:15
Problem unlocking Sanyo Katana (6600), any Suggestions? Need professional help! jackieix Various CDMA/TDMA Cell Phones 5 03-15-2008 14:55
Ufs-4 Hwk Problem....pls. Give Me Suggestion.. amit123 UFS2 + UFS3-Tornadoflasher 0 01-01-2007 04:09
SimEmu Menu Translation.Any Chinese here please give some suggestion! mygod100 Sim Cloning and Scaning 4 05-10-2004 16:33
Page generated in 0.31840 seconds with 11 queries
