03-08-2010, 12:27 | #16 (permalink) |
Insane Poster Join Date: Feb 2009 Location: MX-KEY is the BEST NOKIA TOOL
Member: 974900 Status: Offline Thanks Meter: 9 | Reading Simlock data ... Running MemDump task ...Done. Simlock data dumped OK. Loading simlock.bin 0x20000... Loading docid.bin... ______________________________ IMEI: 3515530197791180 CID: T-MOB010 OP: 31049 NCK: 75478547 ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ working 100% ok THANKS |
03-08-2010, 12:28 | #17 (permalink) | |
Freak Poster Join Date: Feb 2010
Member: 1230225 Status: Offline Thanks Meter: 545 | Quote:
03-08-2010, 12:37 | #20 (permalink) | |
The Following User Says Thank You to Gultek For This Useful Post: |
03-08-2010, 12:43 | #21 (permalink) |
Junior Member Join Date: Oct 2005
Member: 193070 Status: Offline Thanks Meter: 11 | Using device: NO CONNECTION NO CONNECTION ready. ğ HTC Unlocker Version from module: 1.0.0.142 Version from server: 1.0.0.142 Module version is up to date. Selected model: Elf Reading Simlock data ... Running MemDump task ...Done. failed. |
03-08-2010, 13:08 | #22 (permalink) |
No Life Poster Join Date: Jun 2006
Member: 303419 Status: Offline Sonork: Fes Thanks Meter: 209 | not work with vox 710 still not working Selected model: Vox Reading Simlock data ... Running MemDump task ...Done. Simlock data dumped OK. Loading simlock.bin 0x20000... Loading docid.bin... ______________________________ IMEI: 3552570169402870 CID: HTC__203 OP: ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ |
03-08-2010, 13:12 | #23 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Your_Home Age: 38
Member: 413053 Status: Offline Sonork: 100.114351 Thanks Meter: 458 | working ok S620 T.MOBILE UNLOCK DONE Reading Simlock data ... Running MemDump task ...Done. Simlock data dumped OK. Loading simlock.bin 0x20000... Loading docid.bin... ______________________________ IMEI: 35##******** CID: T-MOB010 OP: 21901 NCK: 23932349 .::LUQMAN::. |
03-08-2010, 22:05 | #27 (permalink) | |
No Life Poster Join Date: May 2005 Location: bridgetown Age: 59
Member: 146939 Status: Offline Sonork: 100.1609615 Thanks Meter: 245 | exca 200 from bt unlock thanks mx key team Quote:
03-09-2010, 04:16 | #28 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | i did the update and all but still this is the result for htc shadow tmobile Quote:
03-09-2010, 04:34 | #29 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: q.c phil Age: 42
Member: 461188 Status: Offline Sonork: 1587510 Thanks Meter: 207 | Quote:
did the phone goes in to test mode? like this? if not go automatic to test mode then it will be the problem if phone goes to test mode try to disconnect then connect and wait a while the code should show in the software wbr shoktong | |
The Following 2 Users Say Thank You to shoktong For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
