Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Axe Box
Old 04-29-2010, 13:54   #1 (permalink)
..::Mobile Smoker::..'s Avatar
Member: 170380
Sonork: 100.1577994
Thumbs up ..::FAQ & Important Information About Axe Box::..
Q : How To Activate Box
A : Intall The Latest Installer Of Axe Box & Run Registry Tool, Then Activate & Register Your Box.
Q: After Axe Box Installation I Faced Erorr [application failed to initialize properly(0x0150002)]?
A: Install AXEBOX Installer
2. Install Microsoft .NET Framework 3.5 ( if u already installed Remove and Reinstall and Restart Computer )
3. REMOVE all boxes and other smart cards from your computer.
4. Run Registration tool.
Q : How To Run Axe Box Exe?
A : You Must Have To Connected With Internet.
Q:- Am I Need Internet For All Operations?
A : Yes You Need To Connected With Internet For Cid Unlock (Hard Spl), SimLock Operation & Imei Change.
Q : How To Connect Phone With Axe Box Software?
A : You Must Need Latest Version Of Active Sync Installed On Your Pc
Q : Do I Need Simlocked Before Change Imei?
A : Yes You Must Run Simlock Before Going To Change Imei.
Q : Do I Need Cid Unlock (Hard Spl) Before Flash ?
A : Yes. You Must Need To Do CID Unlock (Hard Spl) Before Flash Or Unlock.
Q : Do I Need Specific Software Ver On Device To Do All Operations?
A : No All Operations Work On All Available Device Software Versions.
Q : Do I Need Downgrade Or Debrand To Do Any Operation?
A : No. No Need To Downgrade Or Debrand For Any Operation
Q : When I Cicked On Scan Device, It Says 'No Device Found' ?
A : Just Install This File Into Your Mobile Manually.
Q : when i press cid unlock phone go in bootloader and softshow fatal error
A : when phone go in bootloader just replug usb cable from phone and process will complete without any error
Cautions IMEI Repair :
We recomended to try IMEI REPAIR only those Devices already Posted and TESTED MODEL by us.
We will not be responsible for any damage if you try IMEI REPAIR on those models which are not yet announced and tested
Old 06-24-2010, 21:17   #2 (permalink)
Member: 170380
Sonork: 100.1577994
Thumbs up How To Downgrade G2 / Hero Hboot 1.76.0007 [USER GUIDE]
1st of all you must need to make gold card with axe box for your htc hero
Tahir Make Good Manual For Gold Card Making here
Now downgrade your Htc Hero with
RUU_Hero_HTC_WWE_2.73.405.5_WWE_release_signed_NoD river.exe
Quick Howto Downgrade Hboot:
1. On your phone, goto Settings, Applications, and make sure Unknown source is checked ON.
2. On your phone, goto Settings, SD card and phone storage, and click Unmount SD card.
3. Then click Format SD card (it should automatically remount after this).
4. Plug the phone into the compuer via USB, then pull down the notification bar and click on the SD card notification. Then click mount.
5. Download this APK and recovery image & hboot zip from here
and save it to your computer:
6. Save both the recovery.img and the flashrec-1.1.2-20090909.apk to your computer, then copy them both to your SD card
(do NOT put them inside any folders on the SD card, just put them in the root of the SD card itself).
7. Unplug the phone from the computer once they are downloaded to the SD card.
8. Goto the Market and download Linda File Manager or any file manager program if you do not already have one.
9. Open the file manager and goto SDCard and then find the flashrec-1.1.2-20090909.apk file and click on it.
If asked, tell it to use Package Installer to open it. It should automatically install the apk.
10. Open the FlashRec program and click on Backup Recovery Image and wait for it to finish.
11. Once done, click on the empty text box in the FlashRec program and type:
/sdcard/recovery.img
Then click on the Flash Custom Recovery Image button and wait for it to finish.
12. Turn off the phone and turn it on into Recovery mode by holding down Home and Power to turn it on
(keep holding until the recovery screen comes up has a bunch of text on a black background).
As long as that screen comes up, you have done it correctly and can now go and load other ROM/hboot/whatever
13. Now Put update-hero-hboot-1.76.0004-signed.zip in sd card
& in recovery mode select option 'update any zip from sd card'
14. Now select update-hero-hboot-1.76.0004-signed.zip & press home button to confirm.
15.now it will ask press home & back button same time for completion the process
16. SDK Drivers
Do exact like that & you done it
Hope this will help members
Old 07-20-2010, 11:31   #3 (permalink)
Member: 1276067
>>>>How to flash your G1 DREAM AND HTC MAGIC G2 DESIRE ROOTING >>>>
As we see many users are facing problem to flash their G1 so here is the easy tutorial to flash your phone.
this tutorial will show you how to flash your HTC Magic / T Mobile G1 with flash ROMs. Android builds are usually distributed as flash ROMs which you can use to update your phone if you have root access to it. Otherwise, you have to wait for official updates which come out once in a blue moon. You can also install modded ROMs which offer extra features and are optimised for performance. You can create ROM backups of the current state of your phone and restore them whenever you want to. You can also apply flash images from other regions. The main reason why you would want to install flash ROMs is to install the latest Android builds directly from source. Also, if something goes wrong in the flashing process, you can restore it using a previous working build
To flash your phone with ROMs,
You need to have
1. A HTC Dream / T Mobile G1 with root access
2. HARD SPL (Secondary Program Loader) installed
3. The Flash ROM
You can follow my previous tutorial to know how to root your phone.
First of all, install Hard SPL (Secondary Program Loader) on your phone. It allows you to flash your phone with ROMs.
Download this file http://rapidshare.com/files/407960559/update.zip.html
Connect your phone to your PC and mount it. Copy update.zip to the root of your phone.
Now, switch off your phone. Start it up in recovery mode by holding the Home key and pressing Power. You will now enter recovery mode. Press Alt + L to see the recovery menu.
Now press Alt + S to apply the update from the SD card to the phone. Now just restart your phone and your installation of Hard SPL has completed.
Now, to install new Android builds, you need to download the ROM and then install them.
You can download the ROMs from a number of sources on the internet, I personally prefer official support site for axebox to download files.
Download the ROM image you want. Rename it to update.zip and copy it to the root of your phone's SD card after connecting it to your PC.
Now, switch off your phone. Hold the Home key and pressing Power. You will now enter recovery mode. Press Alt + W to wipe your phone first. This is needed or the device may hang during installation.
Now press Alt + S to apply the update from the SD card to the phone. Now just restart your phone and the new ROM will have been installed.
If you still need some help just post and we will try our best to solve
AxeBox Team
Old 08-07-2010, 11:35   #4 (permalink)
Member: 1276067
FLASH MAGIC FIRST METHOD
How to Check Your Motherboard Version
1. Turn off your phone
2. Turn the phone on by either holding down the volume down button and power button at the same time OR by holding down the back button and power button at the same time.
3. When the screen comes up, it should say somewhere on the first line either 32A or 32B. THAT is your motherboard version. Remember it…
4. Turn off and on the phone.
5. Goto Settings > Applications  > and make sure Unknown sources is checked ON.
II. Root the Magic
1. Download this APK and the appropriate recovery image for your motherboard (32A or 32B) and save it to your computer:
FlashRec.apk (Updated: 09/26/09)
Amon Ra’s Recovery Image (32B)(Updated 11.18.09)
Amon Ra’s Recovery Image (32A)(Updated 11.18.09)
2. Once they are saved to your computer, copy them both to your SD card (do NOT put them inside any folders on the SD card, just put them on the SD card itself).
3. Unplug the phone from the computer once they are downloaded to the SD card.
4. Goto the Market and download Linda File Manager or any file manager program if you do not already have one.
5. Open the file manager and goto SDCard and then find the FlashRec apk file and click it. If asked tell it to use Package Installer to open it. It should automatically install the apk.
6. Open the FlashRec program and click on Backup Recovery Image and wait for it to finish.
7 (FOR 32A ONLY) Once done, click on the empty text box in the FlashRec program and type:
/sdcard/recovery-RAv1.6.2H.img
7 (FOR 32B ONLY) Once done, click on the empty text box in the FlashRec program and type:
/sdcard/recovery-RAv1.6.2G.img
8. Then click on the Flash Custom RecoveryImage button and wait for it to finish.
9. Turn off the phone and turn it on into Recovery mode by holding down Home and Power to turn it on (keep holding until the recovery screen comes up has a bunch of text on a
black background). So long as that screen comes up, you have done it correctly and can now go on to the How to Load a ROM video for your appropriate device!
10. To get Root access you MUST go to the next video mentioned above and load a custom ROM.
Reported Issues
Issue: I get Invalid Recovery Image when using the FlashRec program.
Solution: Make sure that the spell correction and auto completion are OFF in the Text Settings (Settings > Locale and Text > Touch Input > Text Input then turn off
Prediction, spell correction, and word completion) of your phone. If not then it may put in spaces where they do not belong. (I had it put a space after .img and couldn’t see it
so couldn’t figure out why it kept saying invalid recovery image, like you guys).
Other than that, just make sure it is on the root of the SD card (not in any folder) and that you are typing in the recovery name and filepath correctly.
Then and it should show Flash Recovery Image.
Issue: When I download the FlashRec.apk it shows up as a .zip not an apk.
Solution: No problem. Do NOT extract it, just simply replace the .zip with .apk and then proceed with the procedure.
Issue: I get backup failed or flash failed when I try to use the FlashRec progam.
Solution: This is most likely because you already have a custom recovery image, please use one of the unrooting procedures to get back to the original recovery image and
THEN you can use this procedure.
Also, instead of doing that, if you have root access, you can just put the recovery image on your SD card then go into Terminal (download it from the Market if you don’t
already have it) and type:
flash_image recovery /sdcard/recovery-RA-dream-v1.2.3.img
IF STILL NEED SOME HELP YOU CAN ASK
AxeBox Team
The Following 8 Users Say Thank You to AxeBox For This Useful Post:
Old 08-07-2010, 11:49   #5 (permalink)
Member: 1276067
FLASH MAGIC SECOND METHOD
1) Make GOLD CARD using AxeBox (method is already posted how to make gold card)
2)Put GOLD CARD in magic
3)Download magic rom from official support
4)Connect phone power on phone with computer (must be connected with htc sync) and run rom exe and wait until it finish that.
and here is your phone depranded
IF NEED ANY FURTHER HELP YOU CAN STILL ASK
AxeBox Team
The Following 3 Users Say Thank You to AxeBox For This Useful Post:
Old 08-18-2010, 01:07   #6 (permalink)
Member: 1276067
how to root the HTC Desire!
Compatibility
This guide will allow you to root your HTC Desire, provided it has a bootloader version of 0.80 or below and ROM version 1.21.xxx.x or below (2 different downloads are available depending on your ROM version). To check this, turn off your device, then turn it back on with the 'back' key held. On the second line in green text you will see HBOOT- and then a number. Provided this is 0.80 or below, this guide should work for you.
If you have a bootloader / OS newer than this,http://forum.gsmhosting.com/vbb/f616...2/#post6222251 please visit this topic for details on how to downgrade.
Desire rooting protection
Back in the early days of Android, rooting was easy. You had several options - you could flash stuff via the bootloader, you could flash an engineering bootloader, you could use kernel exploits - there were many ways of getting the low level access to your device that - in fairness - I think we as paying customers are entitled to. As time has progressed however, the manufacturers have made things harder and harder. The Desire is not a straightforward phone to root, for many reasons, including...
* a 'perfected bootloader' that doesn't allow flashing or booting of any images (even HTC signed ones)
* a RUU flash process that does not allow downgrading of the bootloader to earlier versions
* a kernel (that as yet does not have publicly available source) that as yet has no known exploits
* a new protection method previously seen on the HTC Tattoo that protects key partitions from having write access. Even with SU access, it is not possible to write to the boot, recovery or system partitions.
In reality, the options for rooting a device this secure are limited. Even if a kernel exploit were found, the key partitions would still be unwritable, rendering su access useless. This was circumvented on the Tattoo very cleverly, using a specific memory address from a confidential Qualcomm datasheet, however this information is not yet available for the Snapdragon chipset used in the Desire (and indeed may never enter the public domain).
And so the root process becomes a process of methodically probing every possible point of exposure on the device, looking for the slightest chink in the armour. I found one and we're putting it to good use! The downside is that it's not as easy or as pretty as rooting a device that is actually DESIGNED to be accessible at the lowest level, such as the Nexus One.
What this root process provides and does not provide
The root process will...
* flash your device with a new, generic 1.15.405.4 based ROM that has Superuser access
The root process will NOT...
* enable you to flash your device with a custom recovery image
* enable you to have write access to the /system partition in normal use of the device
Both of these limitations are being worked on of course.
Pre-requisites
In order to complete this guide, you need the following...
* a computer running Windows (32 bit recommended, some users have reported issues with x64), OSX or Linux
* a microUSB cable
* a microSD card (to be made into a 'goldcard' - only necessary if your device is an operator supplied device)
* the downloads below
Download
To be ready for the guide, download one of the following items...
- If you have a bootloader version 0.75.xxxx or below AND a current ROM of 1.15.xxx.x or below - http://www.mediafire.com/download.php?lwmnz2yifec (MediaFire) ]- MD5: 28dd5acc4104bb49bd4b292cc8e8437c
- ONLY if the above download is not suitable - if you have a bootloader version 0.80.xxxx or below AND a current ROM of 1.21.xxx.x or below http://www.mediafire.com/download.php?zxyyyxotzzg (MediaFire) - MD5: eb2ed5bca1334cacd70e4720f5b29960
Once you have this on your machine, you're ready to start!
The guide
Follow through these steps, one by one and at the end of it you'll have a rooted Desire with the latest ROM.
Note: This process will wipe your device and there is currently no option to backup your device ROM before you start.
* Make your microSD card into a goldcard by using AxeBox (it's a good idea to back up the contents of your card first!).
* Unzip the file you downloaded to a directory, then open a command prompt / terminal window at that directory.
* Copy the 'update.zip' file to your microSD. Do NOT rename it.
* Turn off your HTC Desire, then turn it back on with the 'back' button held down. You'll see 'FASTBOOT' written on the screen in a red box. Connect the phone to the computer.
* In the terminal window, enter either 'step1-windows.bat', './step1-mac.sh' or './step1-linux.sh' as appropriate.
* Navigate to the 'BOOTLOADER' and then 'RECOVERY' option on the menu, using the volume buttons to move and the power button to select.
* When a black screen appears with a red triangle, press and hold 'Volume Up' then tap 'Power'.
* Your device should now be at the 'recovery' screen. Select the 'wipe data/factory reset' option, then select the option to 'Apply sdcard:update.zip'. This will take a little while, so go make a nice cup of tea. When the flash has finished, reboot, and you are DONE!
we are trying our best to give maximum support
AxeBox Team
The Following 4 Users Say Thank You to AxeBox For This Useful Post:
Old 08-18-2010, 01:31   #7 (permalink)
Member: 1276067
How to downgrade your hboot
OBS! There is no reason to downgrade in case you already have hboot version 0.75 or a rooted 0.80 device. This guide is for future leaks of a ENG spl or such.
Now here are the steps I took:
1. Download a RUU with your desired HBOOT version. Note down the version of the RUU's ROM, e.g. 1.15.405.4.
You can find a list of RUU's at AxeBox support
2. Go to this mtd0.img CID generator Desire mtd0.img creator
3. In the CID generator enter the ROM version you noted down and set CID to 11111111. Let it generate and download it.
4. Download flash_image binary from here http://benocharm.lensworks.org/flash_image and then do the following in adb while the phone is connected:
adb push /{the folder u downloaded it to}/flash_image /data
adb push /{the folder u downloaded it to}/mtd0.img /data
5. In terminal app type following:
chmod 755 /data/flash_image
/data/flash_image misc /data/mtd0.img
Now the mainversion is changed, so that the we pass the RUU's version checking.
6. Type the following while you're device is connected to adb
adb reboot oem-78
It will now reboot into RUU mode. OBS! dont panic, its supposed to just a image, nothing more. Make sure USB cable is connected to the device by:
fastboot devices
If it returns with a device, then you're good.
7. Run the RUU and let it work. Enjoy your downgraded HBOOT version.
AxeBox Team
Old 09-24-2010, 07:22   #8 (permalink)
Member: 62805
Hi all.
The order will be established with
1- Microsoft .NET Framework Version 2.0
2- Microsoft .NET Framework 3.5
3-Download ActiveSync 4.5
4- AxaltoAccessClient
5- AxeBox5.0.rar
reststart pc and run axe box
good days
Windows XP
(to work without problem is needed sp3 and windows must be orginal!! !!)
You need only do few step:
1. install activesync 4.5 from microsoft site.
2. download and install this latest full setup
3. connect box to usb port in computer without usb hub !!
4. if box is not registared need turn regtool from axebox directory
write in it your seller name if he is official and you detial and accept
5. turn axebox software on and all will work ok.
Windows 7 32 or 64bit / Windows Vista 32 or 64bit
1. install WINDOWS MOBILE DRIVERS CENTER from microsoft site
or
Microsoft Windows Mobile Device Center 6.1 Driver for Windows 7 (64-bit) (32 Bit) « Graphic Design Blog
2a. Disconnect all other Gsmboxes, and install
Hotfile.com: One click file hosting: AxaltoAccessClient.rar
also Remove Token Devices From Device Manager
The Following 10 Users Say Thank You to ByMotsan For This Useful Post:
Old 11-08-2010, 20:34   #9 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Tutorial how Root and downgrade Hboot HTC MAGIC/SAPPHIRE 32B !! TO UNLOCK WITH AXEBOX
Hi this is manual all file you got on support in directory
/Shipped Roms/SAPPHIRE_32B/
Procedure for all HTC SAPPHIRE/MAGIC 32B with Hboot higher then 1.33.0004
ROOTING THE PHONE:
0) Get microSD card format it to FAT32 and Creat goldcard with AXEBOX for SAPPHIRE
1) Download your sappimg, stock radio, recovery and SPL from AXEBOX support SAPPHIRE_32B directory.
2) Okay after you download all of those, place the recovery and radio in the tools folder of your AndroidSDK, naming them each something you will remember(name the recovery, "recovery", and the radio, "radio", to make it simple). After all of that place the sappimg on the root of your sdcard(goldcard) and the SPL there as well, name it "update.zip" to make it simpler on you.
3) Power down your device, then turn it on holding volume down and power, let the phone load up the sappimg, and then let it do the upgrade
IF IT DOES NOT WORK YOUR CARD YOU FORMATTED TO BE A GOLDCARD MORE THAN LIKELY SIMPLY CANNOT BE FORMATTED FOR THAT PURPOSE.
4) After it asks you if you want to reboot, reboot your device, notice it says HTC magic now, it's cool. Pull your battery out then place it back in, turn your phone on into fastboot by holding down the back and power button, then plug into usb chord(The device might turn on automatically after pulling the battery and reinserting it., don't panic pull the battery again and this time hold the back button as you place the battery back in).
5) Go into CMD prompt and intput these commands:
cd\
cd\AndroidSDK\tools(the name of AndroidSDK varied depending on what you have it named as under the root of your c drive, I renamed it to make it easier)
fastboot devices
Your serial number should pop up, awesome take a sip of that preferred beverage, then input these commands
fastboot flash radio radio.img
fastboot flash recovery recovery.img
fastboot reboot-bootloader
Alright if you replaced the splash screen on the phone you will see it there, pull the battery out again though then place it back in this time turn it back on holding home and power to enter recovery(The device might turn on automatically after reinserting the battery, don't panic pull the battery again and this time hold the home button as you place the battery back in).
6) In recovery click on "usb toggle" and connect phone to usb cable you should see phone like SDCARD reader just place on root sdcard ROM file and back to recovery menu.
8: Final step!!! First wipe all 5 options in the wipe menu, or for clockword click wipe user data, then wipe cache partition, then go under advanced and click on wipe battery stats. Then flash the SPL, notice it says it requires a reboot, no biggie click reboot device on the home screen of your phone and it should take you back to recovery, after that click flash zip from sd, and flash the rom you selected, then click reboot.
That it now you got phone ready to unlock !! !! !!
The Following 7 Users Say Thank You to wgmmmx1 For This Useful Post:
Old 11-08-2010, 20:57   #10 (permalink)
Member: 1276067
Other metode to ROOT and downgrade HTC MAGIC/SAPPHIRE 32B
1. Creat goldcard with axebox for sapphire
2. Copy sappimg.zip to root SDcard, turn phone in fastboot and update phone.
2. Plug the phone into the compuer via USB, then pull down the notification bar and click on the SD card notification. Then click mount.
3. Download this APK and recovery image & hboot from AXEBOX support
files:
spl_signed_Hboot_0004.zip
recovery-RA-sapphire-v1.6.2G.img
6. Save both the recovery-RA-sapphire-v1.6.2G.img and the flashrec.apk to your computer, then copy them both to your SD card
9. Open the file manager and goto SDCard and then find the flashrec.apk file and click on it.
/sdcard/recovery-RA-sapphire-v1.6.2G.img
13. Now Put spl_signed_Hboot_0004.zip in sd card
14. Now select spl_signed_Hboot_0004.zip & press home button to confirm.
16. END !!
The Following 10 Users Say Thank You to AxeBox For This Useful Post:
Old 01-26-2011, 20:10   #11 (permalink)
dawood1208's Avatar
Member: 1093004
Sonork: 100.1614651
HTC polaris unlock (tutorial)
Here i will post step by step how to unlock htc polaris by axe box
First step
. open axe box
. connect the phone and fully sync
. after completing sycn click scan device
Second step
. click cid unlock and wait for program to finish
Third step
. after cid unlock complete close the program and open
. scan the device to confirm
Forth step
. click sim unlock and wait dor program to finish.
Fifth step
. close the program and open
. scan the phone and u will see sim and cid unlocked
By dawood1208
The Following 3 Users Say Thank You to dawood1208 For This Useful Post:
Old 06-15-2011, 13:47   #12 (permalink)
dawood1208's Avatar
Member: 1093004
Sonork: 100.1614651
(htc elf unlock tutorial)
HERE WE HAVE A HTC ELF UNLOCK TURTORIAL WITH (AXE BOX)
FIRST STEP
CONNECT YOUR PHONE AND PRESS SCAN BUTTON
SECOND STEP
NOW CLICK (SIM UNLOCK+SUPER CID)
AFTER THAT THE PROGRAM WILL BEGIN AND IN JUST 15 SEC U HAVE YOUR PHONE UNLOCKED!!!!
IF PHONE ASK FOR CODE U CAN ENTER THAT CODE MANUALLY!!!
BY
DAWOOD1208
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 09-16-2011 13:43
FAQ about unlock n0kia man0n Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:06
Nokia 5110 & 6110 Schemics MyKy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 08-06-1999 08:36
Question about 51xx/61xx Comic Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 07-06-1999 23:47
Page generated in 0.51263 seconds with 11 queries
