08-16-2011, 22:07 | #1 (permalink) |
Junior Member Join Date: Aug 2011
Member: 1636621 Status: Offline Thanks Meter: 0 | Need Help with Windows 7 and Axebox [ANSWERED] |
08-17-2011, 22:20 | #3 (permalink) |
Member: 1636621 Status: Offline Thanks Meter: 0 | Any phone so far, but the only ones I've had handy thus far have been an HTC G1, an HTC G2, and I don't know what the other phone that someone else tried was. In all cases, we get no device found errors. |
08-17-2011, 23:59 | #4 (permalink) |
Member: 1636621 Status: Offline Thanks Meter: 0 | Ok, I found a Tilt2 and tried to connect that one, and it connects perfectly. But when I go to try and do a Sim Unlock, It boots the phone to the rainbow colored screen, Then to a grey screen with a progress bar, and then it proceeds to sit at 0% on the PC and phone until it says that an error has occured. |
08-18-2011, 08:56 | #5 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
And this is correct why not use search button in this section ?? Android phones like G1 is not supported and with android mean can't find it with axebox. About secound phone was write lots time that first you need do CID UNLOCK after SIM UNLOCK and after phone turn in tricollor screen must disconnect usb cable from phone to 2-3 secounds and connect it again when you do cid unlock(this is bug with old htc phones on windows mobile system and we can't fix this). All this was writed about 100x times on this section but like all newbei you can't use search button or even read faq topic you must ask the same 101x times. | |
08-20-2011, 18:50 | #6 (permalink) |
Member: 1636621 Status: Offline Thanks Meter: 0 | actually I spent an entire day searching, browsing and checking the faq on this forum before I made that post. I didn't find anything documented that came up in any of my searches that told me that. Thank you so much for assuming that I was a lazy pos who doesn't try to look things up for himself first. |
08-20-2011, 18:56 | #7 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Yes man you are lazy becosue if you wil check what model are supported in stick topic you will know much more then try unsupported model connect with box. And after write NOT WORKING and can't work if is NOT SUPPORTED !! About windows phone just use search button and write here tytn2 unlock and you will find more then you should know about how unlock this model becosue like I write I answer about the same question about 100 times. How much more should write the same about the same problem and the same phone ?? ?? |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
