Problem on instalation: Self-Registration Error [SOLVED] |
Read Faq Please |
thx to Mobile Smoker for help http://forum.gsmhosting.com/vbb/../ubb/icons/icon14.gif ..::FAQ & Important Information About Axe Box::.. Q : How To Activate Box A : Intall The Latest Installer Of Axe Box & Run Registry Tool, Then Activate & Register Your Box. Q: After Axe Box Installation I Faced Erorr [application failed to initialize properly(0x0150002)]? A: Install AXEBOX Installer 2. Install Microsoft .NET Framework 3.5 ( if u already installed Remove and Reinstall and Restart Computer ) 3. REMOVE all boxes and other smart cards from your computer. 4. Run Registration tool. Q : How To Run Axe Box Exe? A : You Must Have To Connected With Internet. Q:- Am I Need Internet For All Operations? A : Yes You Need To Connected With Internet For Cid Unlock (Hard Spl), SimLock Operation & Imei Change. Q : How To Connect Phone With Axe Box Software? A : You Must Need Latest Version Of Active Sync Installed On Your Pc Q : Do I Need Simlocked Before Change Imei? A : Yes You Must Run Simlock Before Going To Change Imei. Q : Do I Need Cid Unlock (Hard Spl) Before Flash ? A : Yes. You Must Need To Do CID Unlock (Hard Spl) Before Flash Or Unlock. Q : Do I Need Specific Software Ver On Device To Do All Operations? A : No All Operations Work On All Available Device Software Versions. Q : Do I Need Downgrade Or Debrand To Do Any Operation? A : No. No Need To Downgrade Or Debrand For Any Operation Q : When I Cicked On Scan Device, It Says 'No Device Found' ? A : Just Install This File Into Your Mobile Manually. Cautions IMEI Repair : We recomended to try IMEI REPAIR only those Devices already Posted and TESTED MODEL by us. We will not be responsible for any damage if you try IMEI REPAIR on those models which are not yet announced and tested |
