Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > T-BOX Products
Old 02-16-2012, 11:57   #1 (permalink)
.::MAHABUB::.'s Avatar
Member: 939797
Sonork: 100.1601089
Thanks Meter: 336
Arrow help me tbox team
I can't identify what tipe flasher in this phone? but others flash tool easy to find flasher name.
ex: Toshiba,spansion etc.
Please Hold "ON" to connect with the phone...
3474 Connected to Phone.
CPU: MT6225 Ver: 8A05 SW:8A00
CPU ID: 032D0500
Downloading Boot4 ...
Nor Flash Code: 0001227E(22202200)
Nor Flash Size: 0x1000000 Hex Bytes
INT/EXT RAM Size: 0xC000+0x400000
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
The phone information:
HEDY25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W0 8_12_H02-5_VM_0_25.BIN
help me tbox team.
Old 02-16-2012, 12:32   #2 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,129
I cant understand your question ?
What Flasher ?
Old 02-16-2012, 12:45   #3 (permalink)
Member: 1597873
Thanks Meter: 174
did u mean FLASH CHIP?
Old 02-16-2012, 12:48   #4 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 495
CPU ID: 032D0500
where is the problem
Old 02-16-2012, 12:52   #5 (permalink)
Moderator
...:::::NP:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 8,506
T-Box Also Showing Full File Version With Chip Version.
I Can You Give Little Explain About This Topic :-
Example:-
Here T-Box Scanning Result:-
AHONG25_06B_PCB01_GPRS_MT6225_S00.A11+_V07_12_52_H25_Bengal
Here Other Tools Scanning Result:- A11+_V07.12.52.H25_Bengal
Bro:- Palash Ahammad T-Box Team
Old 02-16-2012, 12:53   #6 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
help me tbox team.
OK
You want to know the Flash chip Manufacturer name ?
Our Platform not read Manufacturer name , Read size , Id which is Important
What problem you face ? if not show Manufacturer name
The Following User Says Thank You to srinibas For This Useful Post:
Old 02-16-2012, 13:15   #7 (permalink)
mobile house dinajpur's Avatar
Member: 724680
Sonork: 100.1595118,1603297
Thanks Meter: 928
@talhaml
you need to show
Nor Flash Code: toshiba/samsung
i understand ur problem you select 4th boot in 6225 chips not show flasher identity better select 5th boot see the result.
Old 02-16-2012, 13:31   #8 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Originally Posted by shabuz_dnj View Post
@talhaml
you need to show
We not recommends to use direct 5th boot on MTK platform
Auto select is 4th boot for common MTK CPU ( not include 6252 , 6253 etc )
If 4th boot not work you can try with 5th boot
Dont use it 1st , otherwise you may damage your firmware
Note - None of our Boot read Chip manufacturer name , Only read The important thing like Size , ID
Thanks
Old 02-16-2012, 13:36   #9 (permalink)
Member: 724680
Thanks Meter: 928
i know sir thanks on report but i just ans his question and problem.
The Following User Says Thank You to mobile house dinajpur For This Useful Post:
Old 02-16-2012, 14:26   #10 (permalink)
Member: 939797
Sonork: 100.1601089
Thanks Meter: 336
@talhaml
you need to show
ok i will try it and post result.
Old 02-16-2012, 14:32   #11 (permalink)
Member: 939797
Sonork: 100.1601089
Thanks Meter: 336
Arrow
Originally Posted by srinibas View Post
OK
yes i want to know the Flash chip Manufacturer name. because many times many mobile technician flash with wrong file so this time Flash chip Manufacturer name very helpful to us.
Old 02-16-2012, 14:50   #12 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Will you pls elaborate it ?
How the manufacturer name will help in the case of wrong file flash ?
May b it will help us
Old 02-16-2012, 15:24   #13 (permalink)
Member: 1619565
Sonork: 100.1613957
Thanks Meter: 19
this is your flashfile name
[QUOTE=talhaml;8155177]I can't identify what tipe flasher in this phone? but others flash tool easy to find flasher name.
CPU ID: 032D0500
Verifying Baud...
Set Baud:921600 OK.
Reading(Nor)...
help me tbox team.
Old 02-16-2012, 15:24   #14 (permalink)
Member: 939797
Sonork: 100.1601089
Thanks Meter: 336
Arrow
many times we face that same set(mobile) but flash file is another.(Flash chip)
when we use wrong file than set is dead and i don't know what was original file.
than i collect
same set(mobile) in market and read file and flash this set(mobile). now set is on but not work perfect. may be display white screen ,keypad not work,network problem,not charging etc.
this is hardware problem?
no this is flash file problem but
so if same
set(mobile) and same Flash chips readed file with flash this set(mobile) than 100% perfect work.
many times tested by me.
Old 02-16-2012, 15:48   #15 (permalink)
Member: 724680
Thanks Meter: 928
than i collect
so if same
yes u r correct some cases like exm sprint 7700 mtk 6217 chips in box not show file u need to know chips.
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 09:21
Page generated in 0.55243 seconds with 8 queries
