View Poll Results: Any Body Like this Post? | |||
Yes | 3 | 100.00% | |
No | 0 | 0% | |
Voters: 3. You may not vote on this poll |
11-19-2010, 14:51 | #16 (permalink) | ||
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | GFive E 71 Quote:
2Nd IMEI Write OK Quote:
The Following 6 Users Say Thank You to srinibas For This Useful Post: |
11-20-2010, 12:32 | #17 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | MICROMAX X250 READ OK BY T-BOX LOG:- Code: Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6223C/D Ver: 8A05 SW:8A00 CPU ID: 6CB70C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Code: 00EC257E(25082501) Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xA000+0x400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... The phone information: JIN_S05_SMS_PCB01_GPRS_MT6223P_S00.PN-SC_CN_LLNUMLD_231_YYMMDD_CAM_MCPMCP_O.BIN |
The Following 3 Users Say Thank You to debmobile For This Useful Post: |
11-22-2010, 12:38 | #18 (permalink) | ||||
No Life Poster Join Date: Jun 2007 Location: India
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Micromax X250 Format ok Quote:
1st IMEI write ok Quote:
2nd IMEI write ok Quote:
Micromax x250 Read Flash File ok Quote:
B.Uttam | ||||
The Following 3 Users Say Thank You to uttam4u2002 For This Useful Post: |
11-27-2010, 14:34 | #19 (permalink) |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | G'Five 6700i ( SPECTRUM CPU) Format & Read Flash File G'FIVE 6700i ( SPECTRUM CPU) Format & Read Flash File Successfully Model: G'Five 6700i G'FIVE 6700i Handset Connect with T-BOX CPU Type: ( SPECTRUM ) SC6500L G'FIVE 6700i Format Successfully G'Five 6700i Read Flash File Successfully B.R., B.Uttam |
The Following 5 Users Say Thank You to uttam4u2002 For This Useful Post: |
11-27-2010, 15:11 | #20 (permalink) | |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Read Flash File Of Micromax X215 Read Flash File Of Micromax X215 Quote:
B.R., B.Uttam | |
The Following 4 Users Say Thank You to uttam4u2002 For This Useful Post: |
11-28-2010, 05:51 | #21 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | G'FIVE U606 READ OK BY T-BOX Code: Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6223C/D Ver: 8A05 SW:8A00 CPU ID: EABD0C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Code: 002088C4 Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xA000+0x400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... The phone information: GOLDDRAGON23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.GDL180B_ALP_32T3W_FM_BT_ARA_V21.BIN |
The Following 5 Users Say Thank You to debmobile For This Useful Post: |
11-30-2010, 09:00 | #22 (permalink) |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Forme F8 IMEI Write Ok Forme F8 IMEI Write Ok First IMEI Write OK Code: Please Hold "ON" to Enter Test Mode... TestMode, Read Information From the Phone... W IMEI OK: 35865301546914-5 2ND IMEI Write OK Code: Please Turn on your phone Connectted SN to be changed... OK, SN2: 35322503122509-3 B.R., B.Uttam |
12-02-2010, 12:38 | #23 (permalink) | |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Format Ok LAWOW S30 Format Ok LAWOW S30 Code: CPU Type: MT346C GND:6,RXD:3,TXD:2 The pinouts applied,Do not insert the mobile phone what do not match the pinouts,otherwise the phone will be damaged Applyed the pinouts successfully The total time??1 s Quote:
B.Uttam | |
12-03-2010, 06:49 | #24 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | PANTHER G-12 READ OK BY T-BOX LOG:- Code: Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6223C/D Ver: 8A05 SW:8A00 CPU ID: 32430C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Code: 00EC257E(25062501) Nor Flash Size: 0x800000 Hex Bytes INT/EXT RAM Size: 0xA000+0x400000 Verifying Baud... Set Baud:921600 OK. Reading(Nor)... The phone information: M7026DJWT_PANT_PCB01_GPRS_MT6223_S00.KABM7026DJWT_PANT_1_01_B02.BIN LOG:- Code: you can Set Formatting Addr Formatting Nor Flash... Format Satrt Addr£º0x700000, Size: 0x100000 Formatted OK. |
12-03-2010, 09:15 | #25 (permalink) | ||||
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Maxx mx 463 Format ok MAXX MX463 Quote:
IMEI Write ok MAXX MX463 Quote:
Flash File Read ok MAXX MX463 Quote:
B.Uttam | ||||
12-04-2010, 05:33 | #26 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | SPICE M4580 READ OK BY T-BOX LOG:- Code: Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6223C/D Ver: 8A05 SW:8A00 CPU ID: 8D7A0C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Code: 002088C4 Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xA000+0x400000 Verifying Baud... Set Baud:460800 OK. Reading(Nor)... The phone information: K120_INA_PCB01_GPRS_MT6223_S00.KACK120BFM_INA_EN_HI_1_16_902.BIN Code: you can Set Formatting Addr Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6223C/D Ver: 8A05 SW:8A00 CPU ID: 8D7A0C00 If Boot donot be supported, Please select [5th Boot] Downloading Boot4 ... Nor Flash Code: 002088C4 Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xA000+0x400000 Formatting Nor Flash... Format Satrt Addr£º0xC00000, Size: 0x400000 Formatted OK. Last edited by debmobile; 12-04-2010 at 05:42. |
12-04-2010, 14:07 | #27 (permalink) | ||||
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | Micromax X250 Format,IMEI Write,Flash File Read Micromax X250 Format,IMEI Write,Flash File Read With T-BOX Format OK Quote:
1ST IMEI Write OK Quote:
2ND IMEI Write OK Quote:
Flash File Reading OK Quote:
B.Uttam | ||||
12-04-2010, 15:39 | #28 (permalink) | ||
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | SPREADTRUM CPU Format OK With T-BOX SPREADTRUM CPU Format OK With T-BOX GALIF U909 (SPREADTRUM CPU) Quote:
NASAKI Quote:
B.Uttam | ||
The Following 6 Users Say Thank You to uttam4u2002 For This Useful Post: |
12-04-2010, 19:00 | #29 (permalink) |
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | CHINA NOKIA 6300 READ OK BY T-BOX LOG:- Code: Please Hold "ON" to connect with the phone... 3943 Connected to Phone. CPU: MT6225 Ver: 8A05 SW:8A00 CPU ID: 03C70E00 Downloading Boot4 ... Nor Flash Code: 00898812 Nor Flash Size: 0x1000000 Hex Bytes INT/EXT RAM Size: 0xC000+0x400000 Verifying Baud... Set Baud:460800 OK. Reading(Nor)... The phone information: MT6225_GEMINI_PCB01_GPRS_MT6225_S00.SYGJ_6300_1_1_3_2.BIN |
The Following 4 Users Say Thank You to debmobile For This Useful Post: |
12-05-2010, 18:37 | #30 (permalink) | |
Member: 523972 Status: Offline Sonork: 100.1596548 Thanks Meter: 1,259 | SPREADTRUM CPU ZTC Model:6234 ZTC Model:6234 Format OK With T-BOX Quote:
B.Uttam | |
