11-19-2010, 01:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | :: How To Work With T-Box :: Here Only You Can Find How To Use T-Box 1: Comport Area (Select Your Right Comport From Here) Checking T-Box ComPort Number 2 : Scan Rx Tx Button. (It Will Help You To Find RX,TX Of Your Phone Simply It Will Help To Connect Your Phone With T-Box Software. 3: The Connect Button (Which Use For Connect Box with T-Box Program) 4 : After Finding Rx,Tx You Need To Click On Set Pinouts Button. 5: Pinouts Info Area. (Show Info Of Pinouts Example : RX,TX & Ground) Last edited by srinibas; 11-20-2010 at 09:51. Reason: Edit other Box name |
The Following User Says Thank You to GsmUniversal For This Useful Post: |
11-19-2010, 01:18 | #2 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | 6 : Soft Platforum Area (After Connecting Your Phone With T-Box Program For Flashing And Other Work Purpose You Need To Click This Button For Going Further Work) 7 : This Button Will Remove All Scan Or Saved Selected Pinouts ( Simply You Say It Will Clear Pinouts Area ) 8 : Pinouts Database Saving Area ( Scan RxTx And Save Your Pinouts Info From Here in New Database) 9 : Exit Button To Close T-Box Program After Complete Your Work. |
11-19-2010, 01:31 | #3 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Description of MTK chips scanning and operations of software platform: Description of MTK chips scanning and operations of software platform: After open T BOX master software ,connect to the mobile phone ,then power the mobile phone by the power line of the conversion lines which need to be connected to the BOX, select the chips that you want to scan (take scanning MTK for example as following),click“Scan Rx.Tx”,the master interface will appear the description of the operation automatically .As following: After select the types of chips ,a dialog will pop-up ,please click “ok” after you have confirm the selection is correct ,the scanning will be done automatically (the time of scanning MTK needs 1-10 seconds),please keep pressing the power-on key of mobile phone until the scanning done(otherwise the operation will be fail).As following: The related platform will pup-up after the scanning done .As following: Note: all the function of the platform can be used only after the definition scanning of mobile phone done. The settings of the software platform :after click “read”, it will prompt you to press the power-on key of mobile phone.(Note: please press the red key which called “reset key” of the box after every operation done ,it can power off the mobile phone and get ready for your next operation.)As following: After press the “reset key” then keep pressing the power-on key, if the communication is normal it will appear the progress reports which the words in green then needn’t press the power-on key, all the information of flash will appear in the interface. As following: After reading done, the dialog will pop-up to prompt you to save the mobile phone information, you just need to select a path to save it according the name of your mobile phone. As following: |
11-19-2010, 01:33 | #4 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Following is the Description of write flash: click here to transfer the information which you want to write ,the software will analyze it automatically. As following: Note: All the functions can be used only after the definition scanning of mobile phone done. After make sure the information is correct then it will prompt you to press the power-on key of your mobile phone, as following: |
11-19-2010, 01:34 | #5 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | After press the “reset key” then keep pressing the power-on key, if the communication is normal it will appear the progress reports which the words in green then needn’t press the power-on key, the software can unlock and write flash automatically, as following: After writing done, the platform will show the related information, as following: Note: all the function of the platform can be used only after the definition scanning of mobile phone done. Following is the function of “Unloc Anys”(can help user to read phone book).transfer the information to be analyzed, tick and then click “Anyl File”as following: |
11-19-2010, 01:35 | #6 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Note: all the function of the platform can be used only after the definition scanning of mobile phone done. Following is the operation of “Unlock”, click “Unlock”,follow the prompt of keeping pressing the power-on key of mobile phone, as following. After press the “reset key” then keep pressing the power-on key, if the communication is normal it will appear the related information and the unlock code as following: Note: all the function of the platform can be used only after the definition scanning of mobile phone done .Following is the operation of IMEI rewrite, just input the IMEI, also for the dual IMEI Click “SN1 CHG” to write IMEI needn’t to press the power-on key, this operation will be done automatically. |
11-19-2010, 01:48 | #7 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Support these types of chips which as following: MTK、SPD、Ankai、ADI、SKY、TI、INF、AGERE、OM、SI(4904)etc.. Scan these chips and BOOT signal automatically, we can upgrade the master for scanning the unknown chips ,the scanning speed is supper fast and accurate . *NEW:All intelligent operation &human design 1. Identify cable no need manual control, applicable for any cables from other factories .2.Identify chips by scanning automatically (not suggest because of the slow speed ,time from 2second to 6 minutes) 3.Scan BOOT signal automatically ,no need to press the power-on key of mobile phone when scanning the SPD chip(just need to press the “reset” key to power off when doing the “write” and “read” operation 4.The software platform will pop-up after the scanning done. Scan USB explanation of scanning master: After open T BOX master software ,connect to the mobile phone ,then power the mobile phone by the power line of the conversion lines which need to be connected to the BOX ,select the types of chips which you want to scan(Take scan the definition of SPD USB for example: 6600D CPU no need to scan USB) the operation description will appear automatically in the master interface .As following: The dialog will pup-up ,please click “ok” after confirm your connection is correct ,then the master software start to scan(press the power-on key of mobile phone when scanning chips until done ,but except SPD ,please read carefully to learn more details from the dialog of the mast software .As following It takes 3-10 seconds to scan the definition of MTK normally, and scanning the definition of MTK needs 10-30 second ,the related will pop-up automatically after scanning done. As following Description of SPD platform: NOTE :All the functions can be used only after the definition scanning of mobile phone done.When scan the new chips ,such as SPD6600MSPD6600M、E、H、R、I ,after the “scan USB” scanning done, the prompt from remind you new hardware found and install the mobile phone driver which saved in T BOX program installation list (X:\T-BOX\drivers\phone\SPD SC6600M USB driver)after driver has been installed ,there will be a new COM in the computer device manager ,please select the new COM when reading SPD CUP .The following picture shows how to use the functions of the software which can be used ony after the definition scanning of mobile done. Specification of readingplease press the red bottom of the BOX which called “reset key” before reading SPD every time) after click the “read” bottom the related dialog will pop-up to prompt you to input the name of mobile phone which you want to scan ,then the software will read automatically(please remember backup the details of the mobile in order to prevent accidents)As following: Note: all the function of the platform can be used only after the definition scanning of mobile phone done. Functions of finding password and user lock: (please press the red key which called “reset key” of the box before operate every time),first read the information of the mobile phone which was locked, then click “Analyze”, the dialog will pup-up to prompt you to transfer the information locked, the power-on password and user lock will be analyzed automatically. Note: all the function of the platform can be used only after the definition scanning of mobile phone done. Description of “write”: (please press the red key which called “reset key” of the box before operate every time)after click “write” the dialog will pup-up , input the information which you want to write ,the software can unlock the locked information and write the information automatically .As following |
11-19-2010, 01:48 | #8 (permalink) |
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Description of “Format”: Note: all the function of the platform can be used only after the definition scanning of mobile phone done. After you open the platform ,there are two options of flash which are “manual” and “HAND” ,you can select one type that fix your mobile phone, it will format automatically if you don’t select any. As following: Description of rewrite IMET: If just rewrite IMET, please read flash first, then input the IMEI and tick “set IMET” as this: , just input IMET1 if there is only one IMET in your mobile phone, click “write” for writing IMEI, then it will pup-up a dialog please click “Y” after you confirm the IMET is correct. (Note: when writing the IMET of SPD need to write flash at the same time.)As following: The method of rewrite IMEI is the same as write flash, as following: Write IMEI done, as following: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
