Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 713641 Status: Offline Thanks: 5
| BJR I TRY TO UNLOCK 3 W580i WITH NERO KEY AND 3 PHONE A RE DEAD AND IMPOSSIBLE TO FLASH IT... SAME ERROR TO UNLOCK OR FLASH... Selected current certificate: A1_DB2020_49_BROWN Power OFF the phone, connect USB cable holding '2-5' Connected to USB1 Device identification...OK Uploading logic DB2020: Sending ResetLoader...OK Authenticating with key KIDP96202033...OK Serial:132F00949223 Free:946 A1:58 A2:48 Other:0 Blocked:NO Reseting to factory defaults...OK Shutting down device...OK Shutting down device... Shutdown command error STOPPED [26sec] ANY MASTER CAN HELP ME PLEASE BR ALLYOUNEED IS |
| | #3 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Oct 2009 Location: Poland Age: 31
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks: 5,647
| Witch version of nerokey you use latest is 1F and working 100% correct. If you use 1E then this is normal and was writed lots time to NOT USE THIS VERSION. If you use 1F just in setting select "SET CERTYFICATE TO:" select ASK EVERY TIME And when you will do unlock select RED 52. After this phone will work correct and will be unlocked too after this can fla**** problem is that now your phone got BROWN 49 certyficate and can't be flashed nothing to it. |
| | #6 (permalink) |
| Ok BJR I HAVE HAD THE PROBLEM WITH 1D BUT YESTERDAY I DOWNLOAD 1F .... AND NOW I USE 1F SO IS THERE ANY POSSIBILITY TO REPAIR MY PHONES CAUSE COSTUMMER WANT TO TAKE THEM TODAY.... THANKS VERY MUCH BEST REGARDS.... ALLYOU NEED IS.... PS I HAVE FORGET MY LOG AND PASS TO SUPPORT AND CONTACT NICOLY BUT NO ANSWER.... |
| | #7 (permalink) | |
| Quote:
Why you not read what I write ?? If you use 1F just in setting select "SET CERTIFICATE TO:" select ASK EVERY TIME And when you will do unlock again (with 1F version !! !!) select RED 52. After this phone will work correct and will be unlocked too after this can flash phone , problem is that now your phone got BROWN 49 certificate and can't be flashed and not work. | |
| | #8 (permalink) |
| Work BJR I HAVE TRY WITH NEW PHONE OF MINE I CAN T SELECT CID52 .... AND AFTER TRYING TO UNLCO PHONE IS DEAD TOO..... THE SOFT DON T LET ME CHOOSE AN OTHER VERSION..... AND I HAVE VALIDATE select ASK EVERY TIME..... ANY TRICK THANKS BR ALLYOUNEEDIS |
| | #9 (permalink) |
| Mean you doing something wrong software work correcly I tested my self lots time check success unlocked topic. If still you not know what to do install teamview 6 contact with me on sonork or msn or icq and give me your id and password when got time will check on your computer what you doing wrong. |
| | #10 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Ukraine Age: 33
Member: 13611 Status: Offline Sonork: 100.1615288 Thanks: 60
| Quote:
As i can see unlock was not completed propertly. After factory reset it stops. So phone unable to boot because of missing EROM. First u have to try to update USB drivers. Use another USB port. Seems some USB problems there. Try also another PC to be sure problem is in your system settings. You can also use serial (COM) cable instead of USB. P.S. Your phones will be ok for sure. Dont worry Last edited by darkmen; 05-13-2011 at 13:36. | |
| | #11 (permalink) |
| No no no HI I CAN T FIND LOG WHERE YOU TELL ME ONLY I CAN DO IS TO COPY FULL SCREEN OF NEROKEY.... I TRY TO INSTALL THE NERO KEY ON ANOTHER COMPUTER BUT THE DRIVERS CAN T BE INTALLATED..... IS THERE A SOLUTION TO FULL FLASH THE W580 WITH NEROKEY OR AN OTHER SOLUTION?? THANKS BR ALLYOUNEEDIS |
| | #15 (permalink) |
| Not good BJR I HAVE TRY WITH COM CABLE... AND SAME RESULT....Power OFF the phone, connect COM cable and press POWER short Connected to COM9 Device identification...OK Sending Preloader...OK Starting GDFS service... Identification failed: Failed to start GDFS service, code: 0x04 Chip B2020 Model:A1 IMEI:35651402-039307-0 CID:49 Domain:BROWNOTP LOCKED:1 CID:51 PAF:1 Uploading logic DB2020: Detecting flash type...OK ID: 0x897E (Intel) Chip: Intel Sibley 512 Mbit NOR Shutting down device...OK Certificate selected by user: A1_DB2020_49_BROWN Shutting down device... Shutdown command error STOPPED [31sec] OTHER SOLUTION,,,??? THANKS BR ALLYOUNEEDIS |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Repaired dead phone without backup | Prodigal | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-29-2011 11:26 |
| HELP Dead 5130 v5.00 | N.Schmetz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 03-08-2011 03:51 |
| help! Dead 5110 v5.30 | aklishin | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 04-04-2001 11:56 |
| nokia 5110 dead | alpha | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 02-28-2001 10:59 |
| 6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) | tcamilo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 12-19-1999 21:30 |
