Go Back   GSM-Forum > Forum Announcements and Support > Forum Announcements
Forum Announcements Here you can find all forum news, changes, Updates and other useful information about Gsm-Forum.
Old 01-21-2005, 13:10   #1 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Forum was updated?!
Hi,
I see that forum was recently updated to from 3.0.3 to 3.0.5, but no announcement...
Here´s the news:
From 3.0.3 to 3.0.4
* 3118 - AdminCP Stats are misaligned
* 3126 - Little typo in includes/functions_databuild.php
* 3132 - Short php tags used in forum.php and upgradecore.php
* 3135 - Problem with adding multiple smilies when the full URL is used
* 3139 - forumpermissions.php: Displaying a single forum is broken
* 3123 - Rebuild Styles is in English
* 3235 - Referral Report
* 3150 - Jelsoft Enterprises Limited Link in Admin Panel
* 3166 - Wrong redirect when changing into pda mode
* 3176 - Wrong link in ACP View Rep Comments
* 3164 - Who's online problem
* 3158 - Copy thread issues
* 3179 - Who's online problem - 2
* 3127 - Indexing Inefficiency
* 3172 - Style Issue Upon Registration
* 3184 - Leave email field
* 3149 - Each time you Preview, you lose a little more of your message
* 3163 - Memberlist Search member then change sort order give wrong result
* 3188 - List Visitors in the Last 24 Hours show lastvisit day
* 3189 - E-mail support for .museum TLD
* 3182 - Parent E-Mail Bug
* 3198 - Uncached template: modifysignature
* 3209 - Moderators now shown in ACP/Forum Manager (Single mode)
* 3203 - Search Users from ACP bug
* 3215 - buildpostcache doesn't work properly
* 3219 - Invalid XHTML
* 3169 - Renaming using does not rename thread starter
* 3221 - Adding a Poll for admins / mods shouldn't expire
* 3193 - Date shown in navbar after event submission is wrong
* 3262 - View Reputation Comments
* 3249 - Announcements one day off
* 3268 - Can't view permissions through forum manager
* 3264 - Wrong links in modcp/banning.php
* 3276 - Images with a width of 1px cause database error
* 3283 - FAQ searching
* 3287 - Postcount Problem with Deleting Forum
* 3115 - running install.php, catching blank page
* 3303 - Partial "Rebuild Search Index" doesn't stop correctly
* 3312 - 'alt3' CSS Class
* 3314 - Image Error in language editing
* 3328 - Wrong text in admincp/statistics
* 3326 - Problems with Memberlist searching when Advanced Search is turned off
* 3348 - Problem with searching for a user in the Mod CP
* 3361 - faq.php unchecked do variable
* 3360 - Forum Links without permissions
* 3351 - Possibility to use every function in a template condition
* 3510 - Two deletions of the same thread will cause database error
* 3365 - "Edited by" shows for admin if user gave reason.
* 3382 - referrerid cookie in register.php
* 3383 - Registration problem with custom field
* 3392 - No sanitization of poststarttime
* 3388 - Existing Searches ignored - Search always rebuilt!
* 3393 - Error handling on save smilies
* 3137 - Error with changing an users avatar via admin cp
* 3427 - Expired password reset results in error with PHP5
* 3485 - Add Camino support to WYSIWYG
* 3536 - Spelling error in ranks_modify_text
* 3488 - Unable to resend email if can view forums is set to no
* 3138 - More untranslated text
* 3195 - custom field on user options page
* 3357 - Problem with "empty" unread_x_nav phrase
* 3526 - Hard-coded phrase
* 3523 - calendar url parsing
* 3522 - variable typo
* 3519 - "Undefined" randomly appearing in posts
* 3512 - external.php fails to check if a password is required for a forum
* 3507 - admincp/user.php -> pruneusers
* 3477 - Subforum (xx Viewing) problem
* 3483 - User Permission Bug
* 3447 - Apache 2 version isn't displayed
* 3505 - Installer does not guess at port for forum/home page URL
* 3334 - $vbphrase[to_delete_a_folder] seems not to be filled
* 3120 - Helptext for profile fields
* 3140 - $vbphrase[terrible] is in the wrong category
* 3161 - $vbphrase[alignment] does not display in vBulletin options
* 3175 - Missing form action attribute
* 3159 - Phrase closed_thread missing in showthread
* 3128 - Quote on a post shown as unread
* 3200 - Some bug in PM
* 3250 - Missing help info for FAQ manager varname
* 3252 - Sentence in the MSN popup
* 3313 - Typo in a phrase
* 3318 - problems with phpinclude_start template
* 3297 - Edit Post Access Keys
* 3322 - Phrase typo
* 3223 - Password History does not do anything
* 3288 - Super Trivial -- Help File...
* 3298 - When drawing poll result bars, language direction not taken into account
* 3325 - Default Time Zone Offset has no effect
* 3404 - Typo in functions_image.php
* 3391 - Different Thread Ratings shown in showthread.php & forumdisplay.php
* 3201 - Failure to edit avatars within AdminCP
* 3338 - Activation error
* 3374 - Combination Of Characters Not Allowing Login
* 3411 - Javascript error in css.php
* 3455 - Physical delete a thread does not remove records for "soft deleted posts" inside
* 3202 - Activation Letter and spam
* 3213 - Sort by Last Visit affected by Invisible Mode
* 3237 - Html entity value of space isn't detected
* 3332 - Error when renaming a template when the new name already exists
* 3180 - bbcode manager sql error
* 3352 - Poll Maximum Options
* 3353 - email vbcode not in vbcode list
* 3286 - Opera Search Display Error
* 3225 - Show Default Post Icon description incorrect
* 3379 - SQL Injection in Authorize.net callback code
* 3337 - Add user to your *nothing* list
* 3116 - translating the sort order submit button
* 3240 - Members list not sorting by reputation
* 3405 - Extra htmlspecialchars() on search string display for phrase search
3.0.4 to 3.0.5
* 3575 - Javascript error into head of ACP
* 3573 - Can't use some bbcodes
* 3574 - Local date is not shown correctly
* 3580 - New User Email doesn't contain proper strings for Custom Checkbox and Multiple Selects
* 3578 - Can't send PMs to some users when using a multibyte language
* 3582 - Calendar.php (3.0.4) Error in the code
* 3591 - Type in $vbphrase[options_options_minreputationpost_text]
* 3572 - search thread results return other threads
* 3593 - Child Style and '--'
* 3569 - Referrer Check fails when not using port 80
* 3598 - Template Manager - Javascript Error in FireFox
* Additional PHP5 compatibility changes
* Potential security issue
* Changes so enabling NOSHUTDOWNFUNC does not cause conflicts with certain systems.
* New error handler designed to prevent accidental path disclosure
PS: New 3.0.6 is already available too
Old 01-28-2005, 04:54   #2 (permalink)
Administrator
..::Neo::..'s Avatar
Member: 14178
Sonork: 100.80393
ya last version of vb is 3.0.6 but there is problems with cookies most stable version is 3.0.5 till they fix 3.0.6
Old 01-28-2005, 11:33   #3 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
I have been using 3.0.6 on my own forum, and apparently is everything ok, but...
Old 02-01-2005, 23:19   #4 (permalink)
PHONESTREET LIMITED's Avatar
Member: 17080
thank u very much
please kindily give me more dailtails about trhis programe
Old 02-02-2005, 05:18   #5 (permalink)
ed2k_7's Avatar
Member: 4408
Bugs Fixed: From 3.0.5 to 3.0.6
3586 - Firefox Standard Editor - Increase and Decrease window size does not work
3618 - Wrong "Format For Date" Examples
3612 - "Forum Home Page" Link (Purely Cosmetic)
3478 - SQL Backup produces invalid files
3346 - Mozilla WYSIWYG Editor Adds Extra Spaces
3605 - Typo in private.php
3608 - "Display Age" cannot be translated
3609 - “Birthday Date Format Override” lost when exporting/importing language
3615 - Search by last visit in admincp returns incorrect data
3639 - Multiple choice poll percentages calculated incorrectly
3644 - PM_MESSAGELISTBIT_USER uncached
3647 - Datastore not rebuilt after delete custom phrase
3648 - Scheduled task names double escaped
3630 - Missing phrase activating_registration
3652 - language_files_text phrase missing content
3624 - SQL error when searching FAQ (MySQL 4.1.x)
3654 - Double slashes in URL path break login redirection
3653 - Searching for exact User causes mySQL-Error
3623 - Invalid XHTML (& not & )
3663 - Add smilies help misdocumented
3620 - POST referrer check broken
3665 - Redirect forums browsable in archive
3667 - Grammar error on user moderation page
3662 - Logging on forum list in archive fails
3660 - Orphaned polls cause JS error on "Who Voted"
3618 - Date format example incorrectly
3612 - Forum home page link in mod CP missing </a>
3640 - Paid Subscription DB error
3366 - Invalid characters not stripped on XML export
3482 - strip_bbcode()/strip_quotes() slow in specific case
3666 - password history only works on the 2nd try
3650 - Uncached templates in forumdisplay.php
3643 - strip_bbcode should remove URL's when checking signature length
3568 - Old versions of Camino show WYSIWYG
3642 - Start Date has no effect in Paid Subscriptions
3421 - Merging users ignores paid subscriptions
3527 - # not added to hex colors in signature
3459 - Alignment tags display in PHP tags
3669 - Holiday system cannot handle Leap Day
3617 - Moderated Posts showing up in admin panel home
Possible XSS issue in private.php (fixed previously)
Possible XSS with BB code parsing and invalid nesting
So far, it (vB 3.06) works excellent for me...
ed2k_5
www.ed2k.com.ph
Old 02-24-2005, 19:20   #6 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Just updated mine to 3.0.7...
Bugs Fixed from 3.0.6 to 3.0.7
* 3675 - Mozilla WYSIWYG editor eats spaces
* 3678 - % in custom BB codes causes problems
* 3683 - Importing XML in PHP5 defaults to UTF-8 encoding
* 3685 - "Multiple Choice" vs "Multiple-Choice"
* 3687 - Redundant code in poll.php
* 3691 - "CSS Selector" can't be translated
* 3695 - URLs with parentheses not auto-parsed
* 3696 - BB codes with options not stripped by strip_bbcode()
* 3697 - Can't close thread while creating
* 3699 - User titles not wordwrapped
* 3703 - "0" not accepted as phrase text
* 3708 - Extra column displayed in PM list if icons off
* 3710 - Missing semicolon in HTML entity in memberlist.php
* 3714 - Smilies don't upload properly
* 3724 - Typo in "Message Attachment Options"
* 3725 - Redirected to wrong page after removing moderator
* 3730 - Attachment.php doesn't check "can view others"
* 3731 - Calendar moderator queue broken
* 3733 - Rebuild post cache results in empty cached post
* 3737 - URLs not auto-parsed in signatures
* 3738 - Editpost.php does not auto-parse links in preview
* 3739 - Call to non-existing template in register.php
* 3746 - Event ending at midnight spans two days in calendar
* 3748 - Unreachable code in functions_bbcodeparse.php
* 3749 - Inconsistent phrase in BB code manager
* 3751 - Smilies parse as IMG tags with Mozilla WYSIWYG
* 3754 - Uncached template in joinrequests.php
* 3763 - Bad chdir in modcp/deletedposts.php
* 3765 - Poll icon visible even when poll not posted
* 3772 - URLs not parsed immediately after closing BB code tags
* 3780 - Spacing issue with reply button and legacy postbit
* 3785 - Uncached templates in profile.php
* 3787 - Variable globalized twice in register.php
* 3788 - Unreachable code in register.php
* 3793 - Redirects in moderator.php don't respect admin perms
* 3796 - Can't delete profile picture from ModCP
* Potential security issue in misc.php
* Significant improvements to attachment.php (Etag support, ability to send signficantly larger attachments, ability to cancel sending attachment if user cancels)
This were the problems:
The discovery of a potentially serious security hole has necessitated the release of vBulletin 3.0.7. All customers are strongly encouraged to take one of the actions described in this post.
All versions of vBulletin 3 up to and including 3.0.6 are affected only if you have enabled the Add Template Name in HTML Comments option (Admin Control Panel -> vBulletin Options -> General Settings). We hope most of you will not have had this option enabled anyway, as it is mostly for debugging and wastes a fair amount of bandwidth on a production site.
Thus, to fix the issue, you should choose one of these options:
1. Disable the Add Template Name in HTML Comments option on your board.
2. Download the zip file attached to this post (or from here) and overwrite the misc.php in the main vBulletin directory on your server with the version in the zip. (More extensive instructions are provided in the zip file.)
3. Upgrade to 3.0.7. A link to upgrade instructions is provided below.
We would strongly recommend options 2 or 3 if possible.
Old 04-14-2005, 21:22   #7 (permalink)
Administrator
Member: 3
Sonork: 100.44530
We always update our forum, but no announcement
Old 04-18-2005, 13:10   #8 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Yeah I realised it only after. Anyway, no harm to announce the news.
Thx ZFrank
PS: Never got replys to the mails I sented you
Old 05-07-2005, 08:52   #9 (permalink)
blaiseid's Avatar
Member: 37735
These days the forumis BUSY,each click ,i see a page saying THE FORUM IN CURENTLY BUSY,TRY AGAIN LATER.
Any work about that?
Salam
Old 05-08-2005, 08:24   #10 (permalink)
ryumahon's Avatar
Member: 4021
im experiencing that to!!! its so annoying... moderators pls try to resolve this... forum is always busy try again later.....
tnx so much!!!
Old 05-08-2005, 11:45   #11 (permalink)
Member: 47532
Red face
tnx so much!!!
ME 2 always got this problem
Old 05-08-2005, 12:50   #12 (permalink)
Drug_Store's Avatar
Member: 15312
Sonork: 100.1576041
Guys, this not correct section to report forum problems, besides, this is not forum sw problem, is db problems.
Old 05-23-2005, 21:45   #13 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Sonork: 100.75672
why did not update to the newest ver . that is VB 3.0.7, i use that before , very nice !
Denis
Finding this forum was a blessing.. I REALLY need help :(! UMULAHOO P2k Series 7 11-03-2003 20:27
Page generated in 0.73478 seconds with 11 queries
