11-02-2009, 16:56 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
You need to open phone and check is it exist NAND flash chip in this phone. If NAND chip exist you can use this method: C:\Program Files\InfinityBox\Documentation\Unlock_and_repair\ LG-KG300_KG200_KG195_repair_freez_restart.txt Please, post here your results. | |
11-02-2009, 18:28 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | problem solved with KG30, KG200 CONSTANT BLINKING on LG logo Thanks infinity team |
The Following User Says Thank You to StRaNgE PeRsOn For This Useful Post: |
04-26-2010, 13:13 | #4 (permalink) | |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Quote:
here is log COM5 [VCP0] selected module v3.11 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7338SA00-002-R1B detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN project-id: 7S7338SA00-002-R1B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 2CFBFB2F4B9BEE4AE7DCBC253ECD15E8 warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 1 min 53 sec Remove/Install battery now ! | |
04-26-2010, 13:24 | #5 (permalink) |
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | This is log with erase whole flash chip Again same problem COM5 [VCP0] selected module v3.11 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: erase whole flash chip interface: BROM_DLL_v3.952.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6219:8B02:8B01 status: FF bbchip bl ver: FE NOR flash id[005D]: 0098:004900000000 [TOSHIBA] TV00578002DABD chip size: 16Mb otp status/size: S_DA_NOR_OTP_EXIST/00010000 NAND flash id[0043]: 0098:00F000800095 [TOSHIBA] TC58NWM9S3B chip size: 64Mb page/spare size: 0800/0040 pages/block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00047000 external RAM [HW_RAM_SRAM, CS1] size: 00800000 done Set baudrate (115200)... done interesting cpu type found: 6219:8B02:8B01 ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/04000000 ffs size: 64Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7338SA00-002-R1B detect NOR info... number of areas to read: 1 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: ARIMA26_05C_PCB01_GPRS_MT6226M_S01.7S7338SA00-002-R1B.BIN project-id: 7S7338SA00-002-R1B, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done Format (HW_STORAGE_NAND)... 00000000-03FFFFFF... Disconnect... done Finished, time used: 2 min 14 sec Remove/Install battery now ! |
Lg Kp320 , hang on "kp320" logo on lcd screen. | nakshatra | Infinity-Box | 6 | 03-21-2010 10:01 |
Lg U8500 hang on LG Logo cant be flashed | alfox | FuriousGold | 2 | 11-19-2009 23:20 |
LG U830 hang on LG logo [Solving] | villa_wency | Z3X-Team Products | 4 | 10-01-2009 15:56 |
LG KP500 HANG on LG... Just FLashing with Z3X LG!! | bestncheap | Z3X-Team Products | 6 | 08-22-2009 16:16 |
LG C3380 hangs on startup logo ... | harim_1981 | Multi-Box | 4 | 06-18-2008 17:09 |
