06-11-2011, 11:41 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | Needed flash file!!!!!!!!!!!!!!!!! i need this badly..... i cant format this phone... any opinion on this phone.... address on formatting or flash IC damage?? result on repair security. COM7 [VCP1] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: repair security area ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [standard] type (04) TCL-ID is absent ==================== New firmware found (v.3.30, database date: 29.05.2011): CT61G3_PCB01_GPRS_MT6225_S00.CT61G3_V3_6_ST_F1.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished rom info ver: 04 sw version: CT61G3_PCB01_GPRS_MT6225_S00.CT61G3_V3_6_ST_F1.BIN project-id: CT61G3_V3.6_ST_F1, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: [standard] type (04) TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range Finished, time used: 3 min 37 sec Remove/Install battery now ! this one is from full format... COM7 [VCP4] selected module v3.30 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:0B03:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 2088C4BFFFBFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb otp offset: 00FE0000 it's time to stop: 18B09FA518B09FA518B09FA518B09FA518B09FA518B09FA5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset assigned: 00E00000 standard ffs/eeprom offset confirmed: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF firmware area: 00000000-00DFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: _ffs... warning: wrong data size at 0x00E8A800, retry... read error recovered warning: wrong data size at 0x00E96800, retry... read error recovered warning: wrong data size at 0x00F77800, retry... read error recovered warning: wrong data size at 0x00FE6C00, retry... read error recovered file saved: C:\InfinityBox\ChineseMiracle\_ffs_20110611-183527.B0E.bin flash: 2088C4BFFFBFFF:2088C400000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... Write Done ====> Finalization ... ffs formatting... flash: 2088C4BFFFBFFF:2088C400000000 Finalization Done Finished, time used: 3 min 49 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! and still dead....... |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
