09-14-2010, 15:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2001 Location: Bucharest,Romania Age: 46
Member: 5204 Status: Offline Thanks Meter: 35 | HD2 problem All goes fine but the phone is still dead. Write Boot (QBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 - MCP NAND ID: AD BC - Chip: Hynix H8BES0UQ0MCP 1024 Mbit Flash Map: - Block Count: 0x400 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:OSBL2 ...Success! - 0:OSBL ...Success! - 0:FSBL ...Success! - 0:SIM_SECURE ...Success! - 0:MIBIB ...Success! ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 ***************************************** Write Boot (SBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 - MCP NAND ID: AD BC - Chip: Hynix H8BES0UQ0MCP 1024 Mbit Flash Map: - Block Count: 0x400 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ... - Write H-Spl ...Success! ***************************************** |
09-14-2010, 15:49 | #2 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Poland Age: 53
Member: 23714 Status: Offline Thanks Meter: 18,769 | HTC HD2 have 2 pcb type use correct file for your pcb try again select use start init erase boot write correct boot again qbf and sbf files here correct file write log added by User : http://forum.gsmhosting.com/vbb/f625...ccess-1093917/ SMT |
09-14-2010, 16:07 | #4 (permalink) |
Member: 23714 Status: Offline Thanks Meter: 18,769 | Better go to htc support nad try take fw for update after enter correct serial number your device in official web You see fw version eu or usa . SMT |
04-09-2011, 21:47 | #12 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 48
Member: 110088 Status: Offline Thanks Meter: 29 | I have the same problem. HD2 after uploading different bootloader to flash the firmware of the memory card shows an error RSA. Radio 2 fail. The same is happening as fires RUU 9% and an end. I did a soft on different ways of cid 11111111 and factory. Still nothing. HTC HD2 is from the UK was without simlock. I have no idea how to bypass the RSA Radio2 fail. You can write Hspl and nothing. I think the friend has the same problem just programmed it with the RUU and not from memory card |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
