10-26-2010, 00:31 | #61 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Bucharest Romania Age: 40
Member: 8530 Status: Offline Sonork: 100.1601224 Thanks Meter: 29 | 3 hero unlock ok ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 ***************************************** Read Code: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 - MCP NAND ID: EC BC - Chip: Samsung K9K4G16 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 357988021xxxxxxx - Network Code: 25657624 ***************************************** Check Connection: Target Not Found! ***************************************** Check Connection: Target Not Found! ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 ***************************************** Read Code: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 - MCP NAND ID: EC BC - Chip: Samsung K9K4G16 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 357988020xxxxxxx - Network Code: 97093331 ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 ***************************************** Read Code: Found Target, Target Info: - HW_REVISION_NUMBER: 0x301700E1 - MCP NAND ID: EC BC - Chip: Samsung K9K4G16 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 357988023xxxxxxx - Network Code: 84251779 - SP Code: 84251779 ***************************************** |
The Following User Says Thank You to balanel For This Useful Post: |
10-26-2010, 15:39 | #62 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2006 Location: ACCRA GHANA Age: 39
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 358279013794**** - Network Code: 72276788 |
The Following User Says Thank You to OHIIM For This Useful Post: |
10-26-2010, 15:50 | #63 (permalink) |
10-27-2010, 19:21 | #64 (permalink) |
Member: 8530 Status: Offline Sonork: 100.1601224 Thanks Meter: 29 | g1 repair ok ***************************************** Write Boot (QBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:HTC ...Success! - 0:OEMSBL2 ...Success! - 0:OEMSBL1 ...Success! - 0:QCSBL ...Success! - 0:MIBIB ...Success! ***************************************** Write Boot (SBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ...Done! - Write H-Spl ...Success! ***************************************** |
10-30-2010, 17:39 | #65 (permalink) |
Member: 8530 Status: Offline Sonork: 100.1601224 Thanks Meter: 29 | another g1 repair ok ***************************************** Check Connection: Target Not Found! ***************************************** Check Connection: Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 ***************************************** Write Boot (QBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ...Done! Write Partition: - 0:AMSS ...Success! - 0:HTC ...Success! - 0:OEMSBL2 ...Success! - 0:OEMSBL1 ...Success! - 0:QCSBL ...Success! - 0:MIBIB ...Success! ***************************************** Write Boot (SBF): Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 Calculate Space ...Done! - Write H-Spl ...Success! ***************************************** - Programm Close 10/30/2010 7:04:58 PM ***************************************** |
11-04-2010, 15:54 | #66 (permalink) |
Insane Poster Join Date: Feb 2004
Member: 54112 Status: Offline Thanks Meter: 55 | HTC Desire (Bravo) successful repair Code: Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 - MCP NAND ID: EC BC - Chip: Samsung K9K4G16 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Write SIM_SECURE ...Done! - Write FSBL ...Done! - Write OSBL ...Done! - Write OSBL2 ...Done! - Write APPSBL ...Done! - Write MIBIB ...Done! Supports LCD AMOLED and SLCD After the repair can be loaded all RUU without any GoldCard! Last edited by Astel; 11-04-2010 at 16:03. |
The Following 4 Users Say Thank You to Astel For This Useful Post: |
11-05-2010, 16:07 | #67 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 35168003040279** - Network Code: 25170511 |
11-09-2010, 10:44 | #68 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | Found Target, Target Info: - HW_REVISION_NUMBER: 0x201700E1 - MCP NAND ID: AD BC - Chip: Hynix H8BES0UQ0MCP 1024 Mbit Flash Map: - Block Count: 0x400 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 354029030357**** - Network Code: 19224143 - CID: T-MOB010 |
11-13-2010, 17:01 | #69 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | hd2 unlocking done with smti jtag Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 - MCP NAND ID: EC B3 - Chip: Samsung KBY00U00VM-B450 4096 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 357779038702020 - Network Code: 87623608 - CID: T-MOB010 |
11-13-2010, 22:05 | #70 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | successfull unlock htc G1 done with smti jatg. Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 355752022608320 - Network Code: 91784262 - CID: T-MOB010 |
11-15-2010, 17:14 | #71 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | HD2 SUCCESSFULL UNLOCKED .WITH SMTI JTAG Found Target, Target Info: - HW_REVISION_NUMBER: 0x202400E1 - MCP NAND ID: EC B3 - Chip: Samsung KBY00U00VM-B450 4096 Mbit Flash Map: - Block Count: 0x1000 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 357779033744460 - Network Code: 66970282 - CID: T-MOB010 |
11-19-2010, 11:58 | #72 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | successfull unlock maple 100 Found Target, Target Info: - HW_REVISION_NUMBER: 0x901B10E1 - MCP NAND ID: 2C BA - Chip: MICRON MT29C2G12 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 358991020343050 - Network Code: 46411800 - CID: T-MOB010 |
11-19-2010, 20:32 | #73 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | htc G1 seccessfully unlocked Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 358279015937060 - Network Code: 82680404 - CID: T-MOB010 |
11-20-2010, 20:03 | #74 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | successfully unlocked htc maple 100 Found Target, Target Info: - HW_REVISION_NUMBER: 0x901B10E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 358991020248590 - Network Code: 85621267 - CID: T-MOB010 |
11-23-2010, 10:10 | #75 (permalink) |
Member: 244250 Status: Offline Sonork: 100.160773 Thanks Meter: 196 | SUCEESSFULLY UNLOCKED G1 GOOGLE Found Target, Target Info: - HW_REVISION_NUMBER: 0xA01700E1 - MCP NAND ID: EC AA - Chip: Samsung K9K2G08R0A 2048 Mbit Flash Map: - Block Count: 0x800 - Block Size: 0x40 pages - Page Size: 0x800 bytes - Total Page Size: 0x840 - Search data ...Found! HTC IMEI: 358280011397740 - Network Code: 99209880 - CID: T-MOB005 |
.::Post Here All SuccessFully Unlocked and repaired phones With USTproII::. | chimed09 | UST Pro II | 3 | 04-02-2010 19:44 |
Mcnpro Box Version 2.8.2 discussion and Post Success Stories here | Mcnbox | McnPro Box | 50 | 03-25-2010 08:25 |
6233 Successfully repaired Phones By MXKey | who_i | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 0 | 02-07-2010 13:06 |
successfully repaired phone with Mx-key free simlock Rpl | Maiwand khan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 29 | 01-28-2010 13:17 |
Can someone success on A3x repair phone? | nok | x1x to x45/x50 | 0 | 08-14-2001 23:44 |
