Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Jan 2010 Location: ++
Member: 1217701 Status: Offline Thanks: 16
| Dear Menole, I bought an UFC 3GS, Now i am trying to Connect phone but its not working. I have tested Nokia C5, E52, 6700c & E90 Same problem. Have you any tuto ? Is must i have to connect power supply ? VCC GND BSI all connect ok but why not working ? Explaine me please |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: PK Age: 25
Member: 952111 Status: Offline Sonork: 100.1608087 Thanks: 66
| YOu are doing mistake just like i did.Just look at the front ports and their names.YOu will found a port named ufc.Plug your ufc cable in it and behind ufc3gs ports use jaf port in your hwk box(If you are using hwk like me).I think now your problem should be solved.And by the way use correct pinouts for good results. |
| The Following User Says Thank You to shani420 For This Useful Post: |
| | #3 (permalink) |
| Thanks for your reply. My friend, i have connected UFC cable in UFC port. & for Nokia E52, 6700c Same cable, Cable nr 9. Now tell me where is the problem |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2002 Location: Bosnien Age: 32
Member: 12904 Status: Offline Sonork: 100.1576801 Thanks: 305
| maybe is the problem same as by me just change the bsi and gnd and post results |
| The Following User Says Thank You to DarkSkir For This Useful Post: |
| | #9 (permalink) | |
| Junior Member ![]() Join Date: Apr 2010 Age: 3
Member: 1274913 Status: Offline Thanks: 3
| Quote:
The UFC3GS should work right out of the box without external power supply for most of Nokia models. After you connect the power connector the phones you are using can power up ? without any cable attached. If so then we continue to the next test. To find out the problem we must try to check if the other functions of UFC3GS are working like the TMA mode. Please test if you can connect a phone using your normal FBUS Cable. Just connect the UFC3GS to your box ( use the appropriate connector ), and use a tested FBUS cable with one of your Nokia phones that you have there. If this is working then there should be no shortcut or other problems inside the UFC3GS and the problem might be the cable that you are using. Now if you have a multimeter please check if your UFC cable that you are using is not damaged somehow ( pins touching at the base, RJ45 with bad connection ). Pins can bend and touch each other during transportation and of course UFC3GS won't work anymore. You can eventually test with an external power supply. In some rare cases, because the computer USB voltage is too low ( maybe an old laptop etc ) this will be required. Regards | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware-Repair Area | 1 | 12-27-2006 10:20 |
| need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 1 | 06-02-1999 16:23 |
| need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 05-26-1999 11:35 |
