11-24-2016, 15:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 626209 Status: Offline Thanks Meter: 42 | Can't check SL3 job progress. [CODES ELABORATE ] " Sending data to server: ERROR! [ SEND_DATA2 ]" The credits for the job are already deducted but I can't make sure that the job was received successfully and is placed in queue for processing. Imei is ***********6993 and hash starts with 2D7886. This should be more then enough to identify the job. Thanks in advance. |
11-24-2016, 18:01 | #3 (permalink) |
Member: 626209 Status: Offline Thanks Meter: 42 | I get this when trying to check the job I uploaded earlier Code: 16:18:55 > Checking server 1: 16:18:59 > Checking server 1: OK! 16:18:59 > Connecting to server: 16:19:01 > Connecting to server: OK! 16:19:01 > Asking server for access: 16:19:14 > Asking server for access: OK! 16:19:14 > Disconnecting from server: 16:19:14 > Disconnecting from server: OK! 16:19:14 > USING: MICRO-BOX A.I.O. NEW V4.0.1.0 16:19:14 > MICRO-BOX SN: <hidden in public> FW: 75/50 16:19:14 > MODE: IMEI & HASH 16:19:14 > Nokia SL3 CHECK ORDER / GET CODES: START! 16:19:14 > BRAND: Nokia 16:19:14 > MODEL: SL3 16:19:14 > IMEI: ***********6993 16:19:14 > HASH: 2D7886******************** 16:19:14 > Checking server 1: 16:19:17 > Checking server 1: OK! 16:19:17 > Connecting to server: 16:19:19 > Connecting to server: OK! 16:19:19 > Asking server for access: 16:19:33 > Asking server for access: OK! 16:19:33 > Getting credit from server: 16:19:46 > Getting credit from server: OK! 16:19:47 > CREDIT: 16:19:47 > USED: 0,00 16:19:47 > LIMIT: 0,00 16:19:47 > CREDIT SPECIAL: 16:19:47 > USED: 145 16:19:47 > LIMIT: 150 16:19:47 > Sending data to server: 16:20:17 > Sending data to server: ERROR! [ SEND_DATA2 ] 16:20:18 > Getting credit from server: 16:20:28 > Getting credit from server: OK! 16:20:28 > CREDIT: 16:20:29 > USED: 0,00 16:20:29 > LIMIT: 0,00 16:20:29 > CREDIT SPECIAL: 16:20:29 > USED: 145 16:20:29 > LIMIT: 150 16:20:29 > Disconnecting from server: 16:20:29 > Disconnecting from server: OK! 16:20:29 > Nokia SL3 CHECK ORDER / GET CODES: END! 16:45:34 > EXIT: BY USER! |
11-25-2016, 11:12 | #5 (permalink) |
No Life Poster Join Date: Jan 2001 Location: StarSystem
Member: 3173 Status: Offline Sonork: 100.100 Thanks Meter: 17,098 | you have get code on mail Nokia SL3 COD for 357293057166993, [email protected]; CODES: #pw+197917872137930+7# #pw+288004372060718+6# #pw+263956179987323+5# #pw+819872768884461+4# #pw+192578969878420+3# #pw+264104270223623+2# #pw+222692954544863+1# IF CODE NOT ACCEPTED PLEASE SEND IT TO PHONE BY CABLE/BOX (FBUS or USB)! |
11-25-2016, 15:35 | #6 (permalink) |
Member: 626209 Status: Offline Thanks Meter: 42 | Thanks for the code. It worked. In what regards the problem I had, it turns out that somehow my router or my ISP have some kind of a problem. Now it all makes sense... I kept having some websites not load randomly. I created a hotspot on my Android and it worked perfectly every time. |
