03-29-2017, 11:59 | #1 (permalink) |
Freak Poster Join Date: Mar 2017
Member: 2694858 Status: Offline Thanks Meter: 64 | flashing problem sony e2105 please chack team 15:54:27 - Selected Bundle for E2105. FW release : 24.0.A.5.14. Customization : Customized GR 15:54:28 - Preparing files for flashing 15:54:33 - Please connect your device into flashmode. 15:54:39 - Device connected in flash mode 15:54:40 - Opening device for R/W 15:54:40 - Reading device information 15:54:40 - Phone ready for flashmode operations. 15:54:40 - Opening TA partition 2 15:54:40 - Current device : E2105 - WUJ01HRA2P - 1292-9617_R7A - 1290-6614_24.0.A.5.14 - WORLD-i_24.0.A.5.14 15:54:40 - Closing TA partition 15:54:40 - Start Flashing 15:54:40 - Processing loader.sin 15:54:40 - Checking header 15:54:40 - Flashing data 15:54:40 - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_11 / Bootloader status : ROOTABLE 15:54:40 - Max packet size set to 512K 15:54:41 - Making a TA backup 15:54:41 - Opening TA partition 1 15:54:41 - Start Dumping TA partition 1 15:54:41 - Finished Dumping TA partition 1 15:54:41 - Closing TA partition 15:54:41 - 15:54:41 - Error dumping TA. Aborted 15:54:41 - Opening TA partition 2 15:54:41 - Start Dumping TA partition 2 15:54:41 - Finished Dumping TA partition 2 15:54:42 - TA partition 2 saved to C:\Users\User\.sonyflasher\registeredDevices\WUJ01 HRA2P\s1ta\2017-03-29_03-54-41\2.ta 15:54:42 - Closing TA partition 15:54:42 - Error parsing TA file. Skipping 15:54:42 - No flash script found. Using 0.9.18 flash engine 15:54:42 - Opening TA partition 2 15:54:42 - Writing TA unit 00002774. Value : 01 15:54:42 - Closing TA partition 15:54:42 - Opening TA partition 2 15:54:42 - Ending flash session 15:54:42 - Can't parse field 'datalen' for IOException 15:54:42 - Error flashing. Aborted 15:54:42 - Flashing finished. 15:54:42 - Please unplug and start your phone 15:54:42 - For SonyFlasher, Unknown Sources and Debugging must be checked in phone settings 15:54:43 - Device connected in flash mode 15:54:43 - Device disconnected 15:54:48 - Device connected in flash mode 15:55:07 - Device disconnected 15:55:09 - Device connected in flash mode 15:55:28 - Device disconnected 15:55:30 - Device connected in flash mode 15:55:36 - Selected Bundle for E2105. FW release : 24.0.A.5.14. Customization : Customized GR 15:55:36 - Preparing files for flashing 15:55:37 - Please connect your device into flashmode. 15:55:38 - Opening device for R/W 15:55:38 - Reading device information 15:55:38 - Phone ready for flashmode operations. 15:55:38 - Opening TA partition 2 15:55:38 - Current device : E2105 - WUJ01HRA2P - 1292-9617_R7A - 1290-6614_24.0.A.5.14 - WORLD-i_24.0.A.5.14 15:55:38 - Closing TA partition 15:55:38 - Start Flashing 15:55:38 - Processing loader.sin 15:55:38 - Checking header 15:55:38 - Flashing data 15:55:38 - Loader : S1_Root_2f8b - Version : MT6582_15 / Boot version : S1_Boot_MT6582_TC9SP_11 / Bootloader status : ROOTABLE 15:55:38 - Max packet size set to 512K 15:55:39 - Making a TA backup 15:55:39 - Opening TA partition 1 15:55:39 - Start Dumping TA partition 1 15:55:39 - Finished Dumping TA partition 1 15:55:39 - Closing TA partition 15:55:39 - 15:55:40 - Error dumping TA. Aborted 15:55:40 - Opening TA partition 2 15:55:40 - Start Dumping TA partition 2 15:55:40 - Finished Dumping TA partition 2 15:55:41 - TA partition 2 saved to C:\Users\User\.sonyflasher\registeredDevices\WUJ01 HRA2P\s1ta\2017-03-29_03-55-39\2.ta 15:55:41 - Closing TA partition 15:55:41 - No flash script found. Using 0.9.18 flash engine 15:55:41 - Opening TA partition 2 15:55:41 - Writing TA unit 00002774. Value : 01 15:55:41 - Closing TA partition 15:55:41 - Processing partition.sin 15:55:41 - Checking header 15:55:41 - Flashing data 15:55:41 - Opening TA partition 2 15:55:41 - Ending flash session 15:55:41 - Can't parse field 'datalen' for IOException 15:55:41 - Error flashing. Aborted 15:55:41 - Flashing finished. 15:55:41 - Please unplug and start your phone 15:55:41 - For SonyFlasher, Unknown Sources and Debugging must be checked in phone settings 15:55:41 - Device connected in flash mode 15:55:42 - Device disconnected 15:55:47 - Device connected in flash mode 15:55:49 - Device disconnected why i face thi problem phone in pattern lock . i also try removed pattern lock but also face same error ? |
03-30-2017, 23:13 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Please read carefully the Video and tutorial. I've just repeat many times that "Flash Files" are directly from SONY database, so if there's any issue try of solve with Right Version File itc... BR allumts |
