Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Micro-Box Team Products > Activation Software Support (HTC, BLACKBERRY, ALCATEL, LG/ZTE, SAGEM/SE)
Old 01-20-2017, 11:04   #1 (permalink)
Member: 83772
Thanks Meter: 22
htc one x error unlock
everytime when i try unlock htc one x i get unlock done press power butonn bla bla....with htc cable v2 but htc is not unlocked,i try 8 times 0 code not ok,i think from server is coming bad data for htc one x,maybe is bug
Old 01-20-2017, 14:46   #2 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Yes, sorry for this, we are searching where's the problem.... as soon possible we will solved this issue.
Try with V. 1.0.0.5 and say if is the same please
allumts
Old 01-20-2017, 15:31   #3 (permalink)
Member: 83772
Thanks Meter: 22
i test now,it s the same problem.
Old 01-20-2017, 15:36   #4 (permalink)
allumts's Avatar
Member: 1564612
Post you Full Log please....
Old 01-20-2017, 15:40   #5 (permalink)
Member: 83772
Thanks Meter: 22
> Loading device driver dll: OK!
15:29:01 > Checking device driver dll version: OK!
15:29:01 > Checking device driver version: OK!
15:29:02 > Searching for device: OK! Found MB HTC PRO CABLE 2!
15:29:02 > MB HTC PRO CABLE 2 INFO:
15:29:02 > SERIAL NUMBER: 3F6F10F649E7D1C4
15:29:02 > VERSION: 2.0
15:29:04 > Loading data: OK!
15:29:04 > Loading models: OK!
15:29:19 > Checking server 1: OK!
15:29:19 > Connecting to server: OK!
15:29:21 > Asking server for access: OK!
15:29:21 > Disconnecting from server: OK!
15:29:21 > HTC One X UNLOCK: START!
15:29:21 > Searching for phone: OK!
15:29:24 > Reading info: OK!
15:29:24 > MODEL: ENDEAVORU
15:29:24 > IMEI: 354461056255017
15:29:24 > PLATFORM: HBOOT-T30S
15:29:24 > CID: H3G__106
15:29:24 > MID: PJ4610000
15:29:24 > BOOT LOADER: 1.39.0000
15:29:24 > VERSION: 0.5a
15:29:24 > FIRMWARE: 3.14.771.34 / 5.1204.164.30H
15:29:24 > SECURITY FLAG: ON
15:29:25 > BATTERY STATUS: GOOD
15:29:25 > ----------------- HBOOT SIMLOCK MENU INSTRUCTIONS ------------
15:29:25 > 1. Select HBOOT MODE (if not already selected)
15:29:25 > 2. Select SIMLOCK MENU using [VOLUME UP] / [VOLUME DOWN]
15:29:25 > 3. Press [POWER] to confirm and wait for process to finish!
15:29:25 > ~~~~~~~ Wait for process to finish! ~~~~~~~
15:29:25 > NETWORK CODE WILL BE SET TO: 00000000!
15:29:25 > You can STOP(ABORT) EMULATOR after process finish!
15:29:25 > Checking server 1: OK!
15:29:26 > Connecting to server: OK!
15:29:27 > Asking server for access: OK!
15:29:27 > Phone will reboot now, please wait for continue!
15:29:29 > JAVACARD emulator: BEGIN!
15:29:59 > Getting data from server: OK!
Old 01-20-2017, 15:45   #6 (permalink)
allumts's Avatar
Member: 1564612
Ok, as said first we will ceck solution as soon possible...sorry fot that
allumts
Page generated in 0.16660 seconds with 8 queries
