Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Dec 2005 Location: Guyana / USA
Member: 205897 Status: Online Sonork: 100.1589406 Thanks: 154
| Manual Guide on How to downgrade from Mytouch 4G 2.3.4 & HB 0.89.0005 Stock Rom You have to use ADB to send these commands This is the Phone info : Code: 17:32:36 > MODEL: HTC GLACIER / GLACIER 17:32:36 > CID: T-MOB010 17:32:36 > MID: PD1510000 17:32:36 > BOOT LOADER: 0.89.0005 17:32:36 > VERSION: 2.3.4 / GRJ22 17:32:36 > FIRMWARE: 2.19.531.1 / 26.11.04.03_M 17:32:36 > KERNEL: 2.6.35.10-g225de41 (gcc 4.4.0) 17:32:36 > CPU TYPE: MSM7X30 / ARMv7 Gaining Temp Root on 2.3.3 or 2.3.4 Android HB 0.890.0005 1. Download these files : unzip them and place the files in your platform-tools folder. To elaborate, place the fre3vo file inside of the fre3vo.zip file and the misc_version file inside the misc_version.zip file in your platform-tools directory.). Do not put these files in any folders just in the platform-tools directory 2. Make sure you have your sdcard inserted in your phone, and you are NOT in USB Storage Mode, and your sdcard is NOT FULL. 3. Run the following command to verify the exploit has access to what it needs. (Only the first line is the command. The second line should be the result returned if all goes well.) Code: $ adb shell cat /dev/msm_rotator /dev/msm_rotator: invalid length 5. Run the following commands from your platform-tools directory. Code: $ adb push fre3vo /sdcard/fre3vo $ adb shell $ chmod 777 /data/local/tmp/fre3vo $ /data/local/tmp/fre3vo -debug -start FAA90000 -end FFFFFFFF After you enter that command above, with luck you should see something similar to the last few lines in the following displayed below. Code: Buffer offset: 00000000 Buffer size: 8192 Scanning region fb7b0000... Scanning region fb8a0000... Scanning region fb990000... Scanning region fba90000... Potential exploit area found at address fbb4d600:a00. Exploiting device... B. If the above does not work, and fails, you can try the following, and hopefully one will work, try the following (you must reboot your phone before you try another set): Code: $ /data/local/tmp/fre3vo -debug -start 10000000 -end 1FFFFFFF $ /data/local/tmp/fre3vo -debug -start 20000000 -end 2FFFFFFF $ /data/local/tmp/fre3vo -debug -start 30000000 -end 3FFFFFFF $ /data/local/tmp/fre3vo -debug -start F0000000 -end FFFFFFFF $ /data/local/tmp/fre3vo -debug -start E0000000 -end EFFFFFFF Code: $ adb shell # exit Changing Version Number to Allow Downgrade 1. If you followed the first portion of this, you should of unzipped misc_version.zip in the platform-tools directory. If you haven't done that yet, do that now and then run the following commands from your platform-tools directory. Code: $ adb push misc_version /sdcard/misc_version $ adb shell chmod 777 /data/local/tmp/misc_version $ adb shell # /data/local/tmp/misc_version -s 1.00.000.0 --set_version set. VERSION will be changed to: 1.00.000.0 Patching and backing up partition 17... Code: Error opening backup file. Code: # sync Code: # dd if=/dev/block/mmcblk0p17 bs=1 skip=160 count=10 1.00.000.010+0 records in 10+0 records out 10 bytes transferred in 0.001 secs (10000 bytes/sec) Download the Stock Rom for the myTouch 4G (PD15IMG.zip) and save it to platform-tools directory as well. The Stock Rom can be found here: MEGAUPLOAD - The leading online storage and file delivery service Push it to your sdcard and reboot into bootloader with the following commands: Code: $ adb push PD15IMG.zip /sdcard/PD15IMG.zip $ adb reboot bootloader 2. Press the `Volume Up` button to begin the update (or in this case, downgrade). When this has finished, you can reboot and you'll be back with the Stock Rom and you can now root from there, which there are plenty of other guides to go by on how to do that. |
| | #2 (permalink) |
| Addins 5. Run the following commands from your platform-tools directory. Code: $ adb push fre3vo /data/local/tmp/fre3vo $ adb push fre3vo /sdcard/fre3vo $ adb shell $ chmod 777 /data/local/tmp/fre3vo $ /data/local/tmp/fre3vo -debug -start FAA90000 -end FFFFFFFF Changing Version Number to Allow Downgrade 1. If you followed the first portion of this, you should of unzipped misc_version.zip in the platform-tools directory. If you haven't done that yet, do that now and then run the following commands from your platform-tools directory. Code: $ adb push misc_version /data/local/tmp/misc_version $ adb push misc_version /sdcard/misc_version $ adb shell chmod 777 /data/local/tmp/misc_version $ adb shell # /data/local/tmp/misc_version -s 1.00.000.0 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
