02-09-2014, 08:05 | #361 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 542963 Status: Offline Thanks Meter: 25 | Post Here All SuccessFully Unlock BlackBerry HTC With Micro-Box Code: 2:26:36 > Checking server 1: OK! 12:26:36 > Connecting to server: OK! 12:26:38 > Asking server for access: OK! 12:26:39 > Getting activations from server: OK! 12:26:39 > Searching for phone: OK! 12:26:39 > Switch to system mode: OK! 12:26:39 > Reading IMEI: OK! 12:26:39 > Reding EXTENDED INFO: OK! 12:26:40 > IMEI: 35xxxxxxxxxxxx 12:26:40 > SIMLOCK: MEP-14074-003 12:26:40 > VERSION: APP-37983-006 12:26:40 > PRD-27603-035 12:26:40 > FIRMWARE: SFI-31445-042 12:26:40 > HARDWARE: HWV-24871-012-2 12:26:40 > Checking USB connection: OK! 12:26:51 > Switch to system mode: OK! 12:26:51 > Switch to bootrom mode: OK! 12:26:51 > Get bootrom info: OK! 12:26:51 > BOOTROM: 5.10.0.13 12:26:51 > METRICS: 6.16 12:26:51 > HWID: 0x5001807 12:26:51 > RIM BlackBerry Device 12:26:54 > Sending loader: OK! 12:26:54 > Run loader: OK! 12:26:54 > Reading data: OK! 12:26:54 > C:\Users\dilpreet\Desktop\MicroBoxALLinONE_V2.1.7.9_CR_FINAL\Updates\MicroBoxBlackBerry_V1.0.0.0_FINAL\BACKUPS\BLACKBERRY\9800 Torch_355xxxxxxxxx_SIMLOCK_BKP_2014_02_09_12_26_54.mbf 12:26:55 > Saving data: OK! 12:26:55 > Sending data to server: OK! 12:26:59 > Calculating [by server] please wait: OK! 12:26:59 > Disconnecting from server: OK! 12:26:59 > Writing data: OK! 12:27:00 > BlackBerry 9800 Torch UNLOCK: END! Last edited by gsm9l; 02-09-2014 at 14:14. Reason: Code Tag Added |
02-09-2014, 13:09 | #362 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Post here All Successful BlackBerry MEP0 Stories Done with Micro-Box here i am starting with 9360 Code: 17:04:43 > Get bootrom info: OK! 17:04:43 > BOOTROM: 5.11.0.9 17:04:43 > METRICS: 6.25 17:04:43 > HWID: 0xE001507 17:04:43 > RIM BlackBerry Device 17:04:43 > IMEI: xxxxxxxxxxxxxx 17:04:43 > SIMLOCK: MEP-04103-001 17:04:43 > VERSION: APP-43856-017 17:04:43 > PRD-30137-001 17:04:43 > FIRMWARE: SFI-41200-032 17:04:43 > HARDWARE: HWV-44174-011-2 17:04:43 > BlackBerry 9360 Curve READ INFO: END! 17:04:56 > BlackBerry 9360 Curve UNLOCK: START! 17:04:57 > Checking server 1: OK! 17:04:57 > Connecting to server: OK! 17:04:59 > Asking server for access: OK! 17:04:59 > Getting activations from server: OK! 17:05:07 > Searching for phone: OK! 17:05:07 > Switch to system mode: OK! 17:05:07 > Reading IMEI: OK! 17:05:11 > Reding EXTENDED INFO: OK! 17:05:12 > IMEI: xxxxxxxxxxxxx 17:05:12 > SIMLOCK: MEP-04103-001 17:05:12 > VERSION: APP-43856-017 17:05:12 > PRD-30137-001 17:05:12 > FIRMWARE: SFI-41200-032 17:05:12 > HARDWARE: HWV-44174-011-2 17:05:12 > Checking USB connection: OK! 17:05:13 > Switch to system mode: OK! 17:05:14 > Switch to bootrom mode: OK! 17:05:14 > Get bootrom info: OK! 17:05:14 > BOOTROM: 5.11.0.9 17:05:14 > METRICS: 6.25 17:05:14 > HWID: 0xE001507 17:05:14 > RIM BlackBerry Device 17:05:42 > Sending loader: OK! 17:05:43 > Run loader: OK! 17:05:43 > Reading data: OK! 17:05:43 > G:\xxxxxxxxxxx.mbf 17:05:43 > Saving data: OK! 17:05:44 > Sending data to server: OK! 17:05:48 > Calculating [by server] please wait: OK! 17:05:48 > Disconnecting from server: OK! 17:05:48 > Writing data: OK! 17:05:48 > BlackBerry 9360 Curve UNLOCK: END! Last edited by gsm9l; 02-09-2014 at 14:14. Reason: Code Tag Added |
The Following User Says Thank You to Faisal_Computer For This Useful Post: |
02-19-2014, 14:44 | #363 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Code: 18:40:04 > BlackBerry 9320 Curve UNLOCK: START! 18:40:05 > Checking server 1: OK! 18:40:06 > Connecting to server: OK! 18:40:08 > Asking server for access: OK! 18:40:09 > Getting activations from server: OK! 18:40:09 > Searching for phone: OK! 18:40:09 > Switch to system mode: OK! 18:40:09 > Reading IMEI: OK! 18:40:09 > Reding EXTENDED INFO: OK! 18:40:10 > IMEI: 356002051483689 18:40:10 > SIMLOCK: MEP-42490-002 18:40:10 > VERSION: APP-50441-010 18:40:10 > PRD-46872-021 18:40:10 > FIRMWARE: SFI-47924-032 18:40:10 > HARDWARE: HWV-45178-006-3 18:40:10 > Checking USB connection: OK! 18:40:12 > Switch to system mode: OK! 18:40:12 > Switch to bootrom mode: OK! 18:40:12 > Get bootrom info: OK! 18:40:12 > BOOTROM: 5.34.0.5 18:40:13 > METRICS: 6.29 18:40:13 > HWID: 0x5000F07 18:40:13 > RIM BlackBerry Device 18:40:33 > Sending loader: OK! 18:40:37 > Run loader: OK! 18:40:37 > Reading data: OK! 18:40:37 > G:\Boxes\Box data\Microbox\MicroBoxBlackBerry_V1.0.0.0_FINAL\BACKUPS\BLACKBERRY\9320 Curve_356002051483689_SIMLOCK_BKP_2014_02_19_18_40_37.mbf 18:40:37 > Saving data: OK! 18:40:38 > Sending data to server: OK! 18:40:43 > Calculating [by server] please wait: OK! 18:40:43 > Disconnecting from server: OK! 18:40:43 > Writing data: OK! 18:40:43 > BlackBerry 9320 Curve UNLOCK: END! Br Faisal_Computer Last edited by gsm9l; 06-23-2014 at 12:39. Reason: CODE tag added |
02-21-2014, 20:46 | #364 (permalink) |
Junior Member Join Date: Dec 2008
Member: 928614 Status: Offline Sonork: ditenn Thanks Meter: 1 | hello help me to do my work here is micro-dongle error that it displays 19:44:37 > SEARCHING FOR BOX: FOUND MICRO-DONGLE! 19:44:38 > READING MICRO-DONGLE SN: OK! 19:44:39 > READING MICRO-DONGLE VERSIONS: OK! 19:44:39 > READING ACTIVATIONS FROM BOX: OK! 19:44:45 > READING CARD ATR: ERROR 1001! 19:44:45 > READ BOX INFO: END! |
02-26-2014, 09:11 | #365 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: RO, Nasaud
Member: 343657 Status: Offline Sonork: 100.1575777 Thanks Meter: 7,102 | Quote:
WBR, gsm9l | |
03-09-2014, 18:54 | #366 (permalink) |
Member: 928614 Status: Offline Sonork: ditenn Thanks Meter: 1 | hello really thank you my problem is solved, the card was not well placed. I opened is I'm up its work well now Saisissez du texte, l'adresse d'un site Web ou importez un document à traduire. Annuler Essayez avec cette orthographe : vraiment merci mon problème est resolu, la carte n'était pas bien place. j'ai ouvert est j'ai bien place sa marche bien thank youuuuuuuuuuuuuuuuuuuuu |
03-11-2014, 15:05 | #367 (permalink) |
Member: 928614 Status: Offline Sonork: ditenn Thanks Meter: 1 | hello that is my frist unluck with microbox. it's vodafone 543 Code: 13:46:53 > VODAFONE 543 CALCULATE CODE(S): START! 13:46:53 > MODEL: 543 13:46:53 > IMEI: 359820034905305 13:46:53 > PROVIDER: 2AVDES1 13:46:54 > CHECKING SERVER 1: OK! 13:46:55 > CONNECTING TO SERVER: OK! 13:46:57 > ASKING SERVER FOR ACCESS: ACCEPTED! 13:46:58 > CHECKING ACTIVATIONS: OK! 13:46:58 > ALCATEL: ACTIVATED! 13:46:59 > CHECKING SERVER 1: OK! 13:47:02 > CONNECTING TO SERVER: OK! 13:47:04 > ASKING SERVER FOR ACCESS: ACCEPTED! 13:47:05 > SENDING DATA TO SERVER: OK! 13:47:06 > RECEIVING DATA FROM SERVER: OK! 13:47:06 > DISCONNECTING FROM SERVER: OK! 13:47:06 > MODEL: 543 13:47:06 > IMEI: 359820034905305 13:47:06 > PROVIDER: 2AVDES1 13:47:06 > NCK: 2775534875 13:47:06 > NSCK: 1697993484 13:47:06 > SPCK: 2213116143 13:47:06 > SIM: 3009710965 13:47:07 > CCK: 1698566277 13:47:07 > IF CODE NOT ACCEPTED PLEASE FULL RESET PHONE AND TRY AGAIN! 13:47:07 > FULL RESET: PHONE OFF, PRESS [#]+[POWER] OR [VOL UP]+[POWER]! 13:47:07 > VODAFONE 543 CALCULATE CODE(S): END! Last edited by gsm9l; 03-12-2014 at 08:42. Reason: CODE tag added |
The Following User Says Thank You to mamadou lamine For This Useful Post: |
03-13-2014, 19:57 | #368 (permalink) |
Member: 928614 Status: Offline Sonork: ditenn Thanks Meter: 1 | and that is unluck samsung 3212i Code: 18:46:01 > INIT DATA: OK! 18:46:07 > DETECTING PHONE: OK! 18:46:13 > WAITING FOR TAT MODE: OK! 18:46:14 > READING MSL STATUS: OK! (ACTIVE) 18:46:14 > READING BLUETOOTH ADDRESS: OK! 18:46:14 > READING IMEI: OK! 18:46:14 > READING VERSION: OK! 18:46:15 > IMEI: 353532042760020 18:46:15 > FIRMWARE: C3212IJPJE4 18:46:15 > HARDWARE: MP 0.100 18:46:15 > MSL ADDRESS: RPIB18950 18:46:15 > BT ADDR: 78471D:9C7A16 18:46:17 > READING DATA: OK! 18:46:17 > BACKUPS\SAMSUNG\C3212i Tat Mode\353532042760020_SIMLOCK_2014_03_13_18_46_17.mbf 18:46:17 > SAVING BACKUP: OK! 18:46:17 > CHECKING DATA: OK! 18:46:17 > CALCULATING: OK! 18:46:18 > ~~~~~~~ CODES SET 1 ~~~~~~~ 18:46:18 > PHONE CODE: 2015 18:46:18 > MASTER CODE: 64838990 (UNFREEZE) 18:46:18 > NET CODE: #7465625*638*00000000# 18:46:18 > SUBS CODE: #7465625*782*00000000# 18:46:18 > SP CODE: #7465625*77*00000000# 18:46:18 > CP CODE: #7465625*27*00000000# 18:46:18 > SIM CODE: #7465625*746*00000000# 18:46:18 > ~~~~~~~ CODES SET 2 ~~~~~~~ 18:46:18 > PHONE CODE: 00000000 18:46:18 > MASTER CODE: 64838990 (UNFREEZE) 18:46:18 > NET CODE: #7465625*638*00000000# 18:46:18 > SUBS CODE: #7465625*782*00000000# 18:46:18 > SP CODE: #7465625*77*00000000# 18:46:18 > CP CODE: #7465625*27*00000000# 18:46:19 > SIM CODE: #7465625*746*00000000# 18:46:19 > SAMSUNG C3212I TAT MODE READ CODES: END! Last edited by gsm9l; 03-14-2014 at 08:39. Reason: CODE tag added |
04-20-2014, 21:37 | #369 (permalink) |
Freak Poster Join Date: Mar 2008 Location: somali
Member: 717872 Status: Offline Sonork: 100.1589423 Thanks Meter: 22 | Alcatel OT-2005X UNLOCK DONE Code: 23:11:56 > Alcatel OT-2005X CALCULATE CODE(S): START! 23:11:56 > MODEL: Alcatel OT-2005X 23:11:56 > IMEI: 8697 23:11:56 > PROVIDER: 2FOBGB1 23:11:57 > Checking server 1: OK! 23:11:57 > Connecting to server: OK! 23:12:00 > Asking server for access: OK! 23:12:00 > Sending data to server: OK! 23:12:01 > Receiving data from server: OK! 23:12:02 > MODEL: Alcatel OT-2005X 23:12:02 > IMEI: 86 23:12:02 > PROVIDER: 2FOBGB1 23:12:02 > NCK: 0460402182 23:12:02 > NSCK: 2928147178 23:12:02 > SPCK: 0226087099 23:12:02 > CODES SET 2 23:12:02 > NCK: 4209304182 23:12:02 > NSCK: 1579050947 23:12:02 > SPCK: 3868066175 23:12:02 > TYPE ###765*08# AND USE CODE! 23:12:02 > IF CODE NOT ACCEPTED PLEASE FULL RESET PHONE or CLEAR eMMC AND TRY AGAIN! 23:12:02 > FULL RESET: PHONE OFF, press [#]+[POWER] or [VOL UP]+[POWER]! 23:12:02 > CLEAR eMMC: PHONE OFF, press [VOL DOWN]+[POWER], select CLEAR Last edited by gsm9l; 04-22-2014 at 16:00. Reason: Code Tag Added |
05-07-2014, 17:04 | #370 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | BlackBerry 8520 Curve Direct UNLOCK Code: 17:58:08 > BlackBerry 8520 Curve UNLOCK: START! 17:58:09 > Checking server 1: OK! 17:58:09 > Connecting to server: OK! 17:58:10 > Asking server for access: OK! 17:58:10 > Getting activations from server: OK! 17:58:11 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 17:58:12 > Searching for phone: OK! 17:58:12 > Switching to OS MODE: OK! 17:58:12 > Reading IMEI: OK! 17:58:12 > Reding EXTENDED INFO: OK! 17:58:12 > IMEI: 357827048669530 17:58:12 > SIMLOCK: MEP-08918-001 17:58:12 > VERSION: APP-31329-005 17:58:12 > PRD-30001-066 17:58:12 > FIRMWARE: SFI-24398-044 17:58:12 > HARDWARE: HWV-21408-004-6 17:58:12 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 17:58:13 > Searching for phone: OK! 17:58:21 > Switching to SYSTEM MODE: OK! 17:58:21 > Switching to BOOTROM MODE: OK! 17:58:21 > Get BOOTROM info: OK! 17:58:21 > BOOTROM: 5.6.0.20 17:58:21 > METRICS: 6.9 17:58:21 > HWID: 0x8C000F03 17:58:21 > RIM BlackBerry Device 17:58:30 > Sending loader: OK! 17:58:30 > Run loader: OK! 17:58:30 > Reading flash id: OK! 17:58:30 > Flash (NAND) ID: EC:44:0:0 17:58:30 > Flash geometry: 2020 sectors 40:800 17:58:31 > Reading data: OK! 17:58:31 > D:\MicroBOX\Updates\BACKUPS\BLACKBERRY\8520_357827048669530_SECURITY_BKP_2014_05_07_17_58_31.mbf 17:58:31 > Saving data: OK! 17:58:31 > Sending data to server: OK! 17:58:34 > Calculating [by server] please wait: OK! 17:58:34 > Disconnecting from server: OK! 17:58:35 > Writing data: OK! 17:58:35 > BlackBerry 8520 Curve UNLOCK: END! |
05-13-2014, 11:19 | #371 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Paris Age: 48
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code: 12:17:32 > PORT: BlackBerry SPEED: BlackBerry 12:17:32 > BLACKBERRY 9700 READ CODES: START! 12:17:32 > READING ACTIVATIONS FROM BOX: OK! 12:17:32 > BLACKBERRY: ACTIVATED! 12:17:40 > SEARCHING FOR PHONE: OK! 12:17:40 > READING IMEI: OK! 12:17:40 > READING SECURITY DATA: OK! 12:17:40 > IMEI: 352479043196534 12:17:40 > SIMLOCK: MEP-05277-005 12:17:41 > CALCULATING: OK! 12:17:41 > IMEI: 352479043196534 12:17:41 > SIMLOCK: MEP-05277-005 12:17:41 > NCK CODE: 7699446096868519 12:17:41 > SPCK CODE: 6011542921916760 12:17:41 > SIM CODE: 6480248227984240 12:17:41 > SUBS CODE: 1541581641928288 12:17:41 > CP CODE: 9702655394667655 12:17:41 > HOW TO: Insert any sim card and power ON phone 12:17:41 > Turn off all wireless connections 12:17:41 > Go to Options/Advanced Options/SIM Card 12:17:41 > Press menu select for show keyboard (if needed) 12:17:41 > Type MEPPD or MEPD (will not see when type) 12:17:41 > Type MEP2 or MEPP2 (will not see when type) 12:17:41 > Enter corresponding mep code 12:17:41 > BLACKBERRY 6720 READ CODES: END! Last edited by gsm9l; 05-13-2014 at 14:26. Reason: "Code" Tag added |
05-28-2014, 16:40 | #372 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Alcatel 2040G UNLOCK FREE Code: 16:08:04 > Alcatel 2040G UNLOCK: START! 16:14:56 > Waiting for phone: OK! 16:15:03 > Sending loader: OK! 16:15:03 > Setting parameters: OK! 16:15:07 > Reading data: OK! 16:15:07 > MODEL: 2040G-3ASFFR1 16:15:07 > IMEI: 352273017386340 16:15:07 > CPU ID: SPRD3, SC6531-0000 16:15:07 > FLASH ID: CS0:EF4016 16:15:07 > D:\Updates\BACKUPS\ALCATEL\2040G_352273017386340_EEP_BKP_2014_05_28_16_15_07.mbf 16:15:07 > Saving data: OK! 16:15:08 > Unlocking: OK! 16:15:10 > Writing data: OK! 16:15:10 > Alcatel 2040G UNLOCK: END! |
05-31-2014, 15:27 | #373 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | HTC A9191 CHANGE CID Super 11111111 Code: 15:24:41 > HTC A9191 CHANGE CID: START! 15:24:41 > Please power on phone and connect to usb in android debug mode! 15:24:41 > If phone ask to allow usb debuging please accept! 15:24:41 > KILLING ADB SERVER (IF RUNNING): OK! 15:24:42 > Searching for phone: OK! 15:24:45 > Reading info: OK! 15:24:46 > Checking root: OK! (ROOTED) 15:24:47 > BRAND: HTC / HTC_WWE 15:24:47 > MODEL: DESIRE HD / ACE 15:24:47 > IMEI: 352668042088300 15:24:47 > CID: HTC__001 15:24:47 > MID: PD9810000 15:24:47 > HWID: SPADE-128 15:24:47 > BOOT LOADER: 0.85.2425 15:24:47 > VERSION: ANDROID 2.3.3 15:24:47 > BUILD GRI40 15:24:47 > FIRMWARE: 2.50.405.2 / 12.56.60.25U_26.10.04.03_M 15:24:47 > KERNEL: 2.6.35.10-gd2564fb (gcc 4.4.0) 15:24:47 > CPU TYPE: MSM7X30 / ARMv7 15:24:47 > CARD ID: 0000003030303030100000397300E280 15:24:47 > New CID: 11111111 15:25:02 > Sending loader: OK! 15:25:08 > Waiting loader answer: OK! 15:25:31 > Prepairing phone: OK! 15:25:52 > Reading data: OK! 15:25:52 > BACKUPS\HTC\A9191\352668042088300_SIMLOCK_BKP_2014_05_31_15_25_52.mbf 15:25:52 > Saving backup: OK! 15:25:52 > Calculating: OK! 15:26:13 > Writing data: OK! 15:26:17 > Restarting phone: OK! 15:26:17 > HTC A9191 CHANGE CID: END! |
06-04-2014, 17:10 | #374 (permalink) |
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | BlackBerry 9700 direct UNLOCK Code: 17:08:35 > BlackBerry 9700 UNLOCK: START! 17:08:57 > Checking server 1: NOT OK! 17:08:57 > Checking server 2: OK! 17:08:57 > Connecting to server: OK! 17:08:58 > Asking server for access: OK! 17:08:59 > Getting activations from server: OK! 17:09:00 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 17:09:00 > Searching for phone: OK! 17:09:00 > Switching to OS MODE: OK! 17:09:00 > Reading IMEI: OK! 17:09:00 > Reding EXTENDED INFO: OK! 17:09:00 > IMEI: 352481043725304 17:09:00 > SIMLOCK: MEP-09292-004 17:09:01 > VERSION: APP-27331-039 17:09:01 > PRD-23593-053 17:09:01 > FIRMWARE: SFI-26559-054 17:09:01 > HARDWARE: HWV-22152-009-1D 17:09:01 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 17:09:01 > Searching for phone: OK! 17:09:05 > Switching to SYSTEM MODE: OK! 17:09:05 > Switching to BOOTROM MODE: OK! 17:09:05 > Get BOOTROM info: OK! 17:09:05 > BOOTROM: 5.6.0.34 17:09:05 > METRICS: 6.12 17:09:05 > HWID: 0x4001507 17:09:05 > RIM BlackBerry Device 17:09:13 > Sending loader: OK! 17:09:13 > Run loader: OK! 17:09:13 > Reading flash id: OK! 17:09:13 > Flash (NAND) ID: EC:40:0:0 17:09:13 > Flash geometry: 2000 sectors 40:800 17:09:14 > Reading data: OK! 17:09:14 > D:\MicroBOX\Updates\BACKUPS\BLACKBERRY\9700_352481043725304_SECURITY_BKP_2014_06_04_17_09_14.mbf 17:09:14 > Saving data: OK! 17:09:14 > Sending data to server: OK! 17:09:17 > Calculating [by server] please wait: OK! 17:09:18 > Disconnecting from server: OK! 17:09:18 > Writing data: OK! 17:09:18 > BlackBerry 9700 UNLOCK: END! |
06-11-2014, 10:53 | #375 (permalink) |
Member: 1202782 Status: Offline Sonork: 100.1608261 Thanks Meter: 634 | Code: 11:48:52 > PORT: BlackBerry SPEED: BlackBerry 11:48:52 > BLACKBERRY 9360 READ CODES: START! 11:48:53 > READING ACTIVATIONS FROM BOX: OK! 11:48:53 > BLACKBERRY: ACTIVATED! 11:49:10 > SEARCHING FOR PHONE: OK! 11:49:10 > READING IMEI: OK! 11:49:10 > READING SECURITY DATA: OK! 11:49:11 > IMEI: 353489044333209 11:49:11 > SIMLOCK: MEP-07723-007 11:49:11 > CALCULATING: OK! 11:49:11 > IMEI: 353489044333209 11:49:11 > SIMLOCK: MEP-07723-007 11:49:11 > NCK CODE: 6640594402331194 11:49:11 > SPCK CODE: 3225474021635766 11:49:11 > SIM CODE: 0812015598574195 11:49:11 > SUBS CODE: 1744317327222178 11:49:11 > CP CODE: 5248617835586618 11:49:11 > HOW TO: Insert any sim card and power ON phone 11:49:11 > Turn off all wireless connections 11:49:11 > Go to Options/Advanced Options/SIM Card 11:49:11 > Press menu select for show keyboard (if needed) 11:49:11 > Type MEPPD or MEPD (will not see when type) 11:49:11 > Type MEP2 or MEPP2 (will not see when type) 11:49:11 > Enter corresponding mep code 11:49:11 > BLACKBERRY 6750 READ CODES: END! Last edited by gsm9l; 06-23-2014 at 12:35. Reason: CODE tag added |
Post here all successfuly flashed, unlocked and repaired phones with ATF software. | dr_aybyd | Advance-Box | 6048 | 02-04-2019 16:48 |
Post Here All SuccessFully Unlocked Phone With KK-Box | digiphone | Kulankendi Box / Dongle | 160 | 08-23-2014 00:17 |
successfully unlock lg kc550 with micro-box[ANSWERED & SOLVED] | shahinahmed007 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 02-08-2010 14:04 |
SuccessFully Unlock OT-800 With Micro-Box | Gsm. | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 02-02-2010 17:32 |
Please Post Here All SuccessFully Unlock HTC With Micro-Box | MOBIL CLINIC | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 10 | 01-12-2010 05:41 |
