11-19-2014, 21:20 | #425 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | HTC Desire 200 direct unlocked 17:38:03 > HTC Desire 200 UNLOCK (HBOOT SIMLOCK MENU): START! 17:38:03 > Please power on phone and connect to usb in android debug mode! 17:38:03 > Please power on phone and connect to usb in android debug mode! 17:38:03 > If phone ask to allow usb debuging please accept! 17:38:03 > KILLING ADB SERVER (IF RUNNING): 17:38:03 > KILLING ADB SERVER (IF RUNNING): OK! 17:38:03 > Searching for phone: 17:38:12 > Searching for phone: OK! 17:38:12 > Reading info: 17:38:15 > Reading info: OK! 17:38:15 > BRAND: HTC / HTC_EUROPE 17:38:15 > MODEL: HTC DESIRE 200 / GTOU 17:38:15 > IMEI: 35623305047xxxx 17:38:15 > CID: HTC__032 17:38:15 > MID: PO6010000 17:38:15 > HWID: GTOU-2 17:38:16 > BOOT LOADER: 1.21.0000 17:38:16 > VERSION: ANDROID 4.0.3 17:38:16 > BUILD IML74K 17:38:16 > FIRMWARE: 1.06.401.1 / 10.21.98.09U_2.17.98.31 17:38:16 > KERNEL: 3.0.16-gd68a999 (gcc 4.4.3) 17:38:16 > CPU TYPE: MSM7K / ARMv7 17:38:16 > CARD ID: 7F00003033333020520000099600E1B4 17:38:16 > Please power on phone and connect to usb in android debug mode! 17:38:16 > If phone ask to allow usb debuging please accept! 17:38:16 > KILLING ADB SERVER (IF RUNNING): 17:38:16 > KILLING ADB SERVER (IF RUNNING): OK! 17:38:16 > Searching for phone: 17:38:17 > Searching for phone: OK! 17:38:17 > Reading info: 17:38:20 > Reading info: OK! 17:38:21 > Checking root: 17:38:23 > Checking root: OK! (ROOTED) 17:38:26 > Writing data: 17:38:40 > Writing data: OK! 17:38:41 > Please REMOVE CABLE from phone 17:38:41 > Select HBOOT MODE (if not already selected) 17:38:41 > Select SIMLOCK MENU using [VOLUME UP] / [VOLUME DOWN] 17:38:41 > Press [POWER] to confirm and wait for process to finish! 17:38:41 > OR (for older models) 17:38:41 > Press [SEND] to select SIMLOCK MENU! 17:38:41 > Wait for process to finish! 17:38:41 > NETWORK CODE RESET TO: 00000000! 17:38:42 > Restarting phone: 17:38:43 > Restarting phone: OK! 17:38:43 > HTC Desire 200 UNLOCK (HBOOT SIMLOCK MENU): END! |
11-19-2014, 21:23 | #426 (permalink) |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Alcatel OT6050Y code calculated correcly !! 14:26:32 > Alcatel OT-6050Y CALCULATE CODE(S): START! 14:26:32 > MODEL: Alcatel OT-6050Y 14:26:32 > IMEI: 86387002097xxxx 14:26:32 > PROVIDER: 2ARGPL7 14:26:32 > Checking server 1: 14:26:33 > Checking server 1: OK! 14:26:33 > Connecting to server: 14:26:33 > Connecting to server: OK! 14:26:33 > Asking server for access: 14:26:34 > Asking server for access: OK! 14:26:34 > Sending data to server: 14:26:35 > Sending data to server: OK! 14:26:35 > Receiving data from server: 14:26:36 > Receiving data from server: OK! 14:26:37 > MODEL: Alcatel OT-6050Y 14:26:37 > IMEI: 86387002097xxxx 14:26:37 > PROVIDER: 2ARGPL7 14:26:37 > NCK: 16849525-98 14:26:37 > NSCK: 34216737-59 14:26:37 > SPCK: 40808937-79 14:26:37 > CPCK/SIM: 38969662-68 14:26:37 > CCK: 31462602-93 14:26:37 > TYPE ###765*08# AND USE CODE! 14:26:37 > IF CODE NOT ACCEPTED PLEASE FULL RESET PHONE or CLEAR eMMC AND TRY AGAIN! 14:26:37 > FULL RESET: PHONE OFF, press [#]+[POWER] or [VOL UP]+[POWER]! 14:26:37 > CLEAR eMMC: PHONE OFF, press [VOL DOWN]+[POWER], select CLEAR EMMC, press [HOME]! 14:26:37 > Disconnecting from server: 14:26:37 > Disconnecting from server: OK! 14:26:37 > Alcatel OT-6050Y CALCULATE CODE(S): END! |
12-28-2014, 08:21 | #431 (permalink) |
No Life Poster Join Date: Jan 2014
Member: 2108593 Status: Offline Thanks Meter: 839 | Direct unlock done 14:51:19 > BlackBerry 9800 Torch UNLOCK: START! 14:51:19 > Checking server 1: 14:51:20 > Checking server 1: OK! 14:51:20 > Connecting to server: 14:51:20 > Connecting to server: OK! 14:51:20 > Asking server for access: 14:51:23 > Asking server for access: OK! 14:51:23 > Getting activations from server: 14:51:25 > Getting activations from server: OK! 14:51:25 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): 14:51:25 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 14:51:25 > Searching for phone: 14:51:25 > Searching for phone: OK! 14:51:26 > Switching to OS MODE: 14:51:26 > Switching to OS MODE: OK! 14:51:26 > Reading IMEI: 14:51:26 > Reading IMEI: OK! 14:51:26 > Reding EXTENDED INFO: 14:51:26 > Reding EXTENDED INFO: OK! 14:51:26 > IMEI: 356xxxxxxx48936 14:51:26 > SIMLOCK: MEP-30218-002 14:51:26 > VERSION: APP-34645-007 14:51:26 > PRD-27603-088 14:51:26 > FIRMWARE: SFI-31445-042 14:51:26 > HARDWARE: HWV-24871-012-4 14:51:26 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): 14:51:26 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 14:51:26 > Searching for phone: 14:51:27 > Searching for phone: OK! 14:51:27 > Switching to SYSTEM MODE: 14:51:30 > Switching to SYSTEM MODE: OK! 14:51:30 > Switching to BOOTROM MODE: 14:51:30 > Switching to BOOTROM MODE: OK! 14:51:30 > Get BOOTROM info: 14:51:30 > Get BOOTROM info: OK! 14:51:30 > BOOTROM: 5.10.0.13 14:51:30 > METRICS: 6.16 14:51:30 > HWID: 0x5001807 14:51:30 > RIM BlackBerry Device 14:51:30 > Sending loader: 14:51:41 > Sending loader: OK! 14:51:41 > Run loader: 14:51:41 > Run loader: OK! 14:51:41 > Reading flash id: 14:51:41 > Reading flash id: OK! 14:51:41 > Flash (NAND) ID: EC:50:0:0 14:51:41 > Flash geometry: 2000 sectors 40:1000 14:51:42 > Reading data: 14:51:42 > Reading data: OK! 14:51:42 > D:\MicroBoxBlackBerry_V1.0.0.3_FINAL\BACKUPS\BLACK BERRY\9800_356xxxxxxxxxx936_SECURITY_BKP_2014_12_2 0_14_51_42.mbf 14:51:42 > Saving data: 14:51:42 > Saving data: OK! 14:51:42 > Sending data to server: 14:51:43 > Sending data to server: OK! 14:51:45 > Calculating [by server] please wait: 14:51:56 > Calculating [by server] please wait: OK! 14:51:56 > Disconnecting from server: 14:51:56 > Disconnecting from server: OK! 14:51:56 > Writing data: 14:51:56 > Writing data: OK! 14:51:56 > BlackBerry 9800 Torch UNLOCK: END! 14:53:04 > NEW VERSIONS FOUND IN SUPPORT: 14:53:04 > MICRO-BOX Dongle/Box Drivers: v1.2.9.0 14:53:04 > MICRO-BOX Huawei (single): v1.0.0.0 14:53:04 > MICRO-BOX Imei (single): v1.0.0.3 14:53:04 > MICRO-BOX Samsung (single): v1.0.1.4 14:53:04 > Please press <CHECK FOR UPDATE> button for download new versions! |
12-28-2014, 08:22 | #432 (permalink) |
Member: 2108593 Status: Offline Thanks Meter: 839 | Direct unlock done 21:15:20 > BlackBerry 9300 UNLOCK: START! 21:15:20 > Checking server 1: 21:15:20 > Checking server 1: OK! 21:15:20 > Connecting to server: 21:15:21 > Connecting to server: OK! 21:15:21 > Asking server for access: 21:15:23 > Asking server for access: OK! 21:15:23 > Getting activations from server: 21:15:24 > Getting activations from server: OK! 21:15:24 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): 21:15:25 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 21:15:25 > Searching for phone: 21:15:25 > Searching for phone: OK! 21:15:25 > Switching to OS MODE: 21:15:25 > Switching to OS MODE: OK! 21:15:25 > Reading IMEI: 21:15:25 > Reading IMEI: OK! 21:15:25 > Reding EXTENDED INFO: 21:15:25 > Reding EXTENDED INFO: OK! 21:15:26 > IMEI: 3539xxxxxx61933 21:15:26 > SIMLOCK: MEP-09292-004 21:15:26 > VERSION: APP-32148-005 21:15:26 > PRD-30231-002 21:15:26 > FIRMWARE: SFI-31213-015 21:15:26 > HARDWARE: HWV-30365-009-2 21:15:26 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): 21:15:26 > KILLING BLACKBERRY DESKTOP MANAGER (IF RUNNING): OK! 21:15:26 > Searching for phone: 21:15:26 > Searching for phone: OK! 21:15:27 > Switching to SYSTEM MODE: 21:15:29 > Switching to SYSTEM MODE: OK! 21:15:29 > Switching to BOOTROM MODE: 21:15:29 > Switching to BOOTROM MODE: OK! 21:15:29 > Get BOOTROM info: 21:15:29 > Get BOOTROM info: OK! 21:15:29 > BOOTROM: 5.15.0.6 21:15:29 > METRICS: 6.16 21:15:29 > HWID: 0x4000F07 21:15:29 > RIM BlackBerry Device 21:15:29 > Sending loader: 21:15:40 > Sending loader: OK! 21:15:40 > Run loader: 21:15:40 > Run loader: OK! 21:15:40 > Reading flash id: 21:15:40 > Reading flash id: OK! 21:15:40 > Flash (NAND) ID: EC:40:0:0 21:15:40 > Flash geometry: 2000 sectors 40:800 21:15:40 > Reading data: 21:15:41 > Reading data: OK! 21:15:41 > D:\blackBerry_V1.0.0.3_FINAL\BACKUPS\BLACKBERRY\93 00_353xxxxxx361933_SECURITY_BKP_2014_12_25_21_15_4 1.mbf 21:15:41 > Saving data: 21:15:41 > Saving data: OK! 21:15:41 > Sending data to server: 21:15:42 > Sending data to server: OK! 21:15:42 > Calculating [by server] please wait: 21:15:45 > Calculating [by server] please wait: OK! 21:15:45 > Disconnecting from server: 21:15:45 > Disconnecting from server: OK! 21:15:45 > Writing data: 21:15:46 > Writing data: OK! 21:15:46 > BlackBerry 9300 UNLOCK: END! |
01-18-2015, 10:09 | #433 (permalink) |
Major Poster Join Date: Apr 2012 Location: spain
Member: 1749539 Status: Offline Sonork: srn_sorinel Thanks Meter: 0 | hi hi there can somebady verify this unlock code for htc wildfire s a510e because i dont whant too block mi phone.imei 358701044062470 locked to vodafone romania.thank's for all.unlock code 12493726 |
01-25-2015, 00:00 | #434 (permalink) |
No Life Poster Join Date: May 2013
Member: 1930570 Status: Offline Thanks Meter: 82 | MODEL: Alcatel OT-7041X 20:52:34 > IMEI: 863859022758572 20:52:34 > PROVIDER: 2BVDES1 20:52:34 > NCK: 17598899-31 20:52:34 > NSCK: 32334427-47 20:52:34 > SPCK: 30252485-61 20:52:34 > CPCK/SIM: 01268462-09 20:52:34 > CCK: 02139269-03 20:52:34 > PCK: 34885018-08 20:52:35 > CODES SET 2 20:52:35 > NCK: 05309224-22 20:52:35 > NSCK: 29693977-85 20:52:35 > SPCK: 02190801-58 20:52:35 > CPCK/SIM: 38296771-31 20:52:35 > CCK: 12639229-25 |
01-25-2015, 17:07 | #435 (permalink) |
Member: 1930570 Status: Offline Thanks Meter: 82 | MODEL: Alcatel OT-304X 16:44:08 > IMEI: 356130040457678 16:44:08 > PROVIDER: 2DRGES1 16:44:08 > NCK: 22258577-16 16:44:08 > NSCK: 14885286-39 16:44:08 > SPCK: 03775938-01 16:44:08 > CPCK/SIM: 28788934-09 16:44:08 > CCK: 28305742-24 16:44:08 > PCK: 28363558-85 perfect and correct code |
Post here all successfuly flashed, unlocked and repaired phones with ATF software. | dr_aybyd | Advance-Box | 6048 | 02-04-2019 16:48 |
Post Here All SuccessFully Unlocked Phone With KK-Box | digiphone | Kulankendi Box / Dongle | 160 | 08-23-2014 00:17 |
successfully unlock lg kc550 with micro-box[ANSWERED & SOLVED] | shahinahmed007 | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 02-08-2010 14:04 |
SuccessFully Unlock OT-800 With Micro-Box | Gsm. | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 1 | 02-02-2010 17:32 |
Please Post Here All SuccessFully Unlock HTC With Micro-Box | MOBIL CLINIC | Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) | 10 | 01-12-2010 05:41 |
