Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-10-2012, 16:57   #1 (permalink)
Member: 769590
3Gs Power on only with charger and Err 21
Phone came broken screen, so fall damage, the rest unknown.
When connected to USB/Charger enters restore mode (Not DFU)
- When disconnected, turns off.
When restored via iTunes Error 21.
Tested with a known working, LCD & Digitizer, battery, dock connector and power flex cable.
Battery ways checked from what is mentioned in iPhone solutions with pic thread.
Fuses Jumped....
(R35_RF, L7_AP and L13_AP)
I'm a bit lost from here where to go as it seems I have to separate problems:
1. It won't stay on without the charger.
2. The Error 21
While writing this post I noticed a dodgy looking pin. 8th one from the top right of the dock connector as shown in attached file.
This seems to be pin 27 on J3_AP which is USB_POWR_NO_PROTECT_CONN and leads to L7_AP and L13_AP. There is continuity between J3_AP_27 and L7_AP, L13_AP.
Any help is much appreciated.
Old 07-14-2012, 10:28   #2 (permalink)
Member: 769590
bump... In hope that someone can help
Old 07-15-2012, 21:18   #3 (permalink)
Moderator
Wites OM Tesla's Avatar
Member: 1017374
If you try other battery,jumped the fuse then it is PMIC problem because it is not sensing VBAT from battery this why it work with cable and it show error 21 because possible PMIC not output 1.8 voltage for mass memory NAND ic.
I recommend to chk voltages first {iPhone, iPad} Components, Schematics, Diagrams etc....
To check for voltages use battery after you press power button chk them and post here what voltage is missing or low.
Then you can chk only with cable to see the difference.
By the way chk if this pin not short to gnd it is 5V for charging,also chk for heat entire board with charged battery then with cable.
Old 07-16-2012, 14:37   #4 (permalink)
Member: 769590
Which pin would that be?
Board is not heating on battery or cable.
Here are my read outs, 1st with battery and 2nd with cable
Old 07-16-2012, 17:02   #5 (permalink)
Moderator
Member: 1017374
Phone was dropped i think it have crack at PMIC need reball or replace.
Old 07-16-2012, 17:05   #6 (permalink)
Member: 769590
That image is not the same phone, only a image I found online, i can make a picture if you like.
Possible to properly remove 338S0768 for reball? or do you have to use a replacement?
(Thanks so far )
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 04-10-2013 02:07
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 4 06-09-1999 17:04
Page generated in 0.35903 seconds with 12 queries
