11-04-2011, 13:52 | #46 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
Check this region for missing/damaged components. By wites13 at 2011-10-25 | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
11-04-2011, 17:25 | #48 (permalink) |
Junior Member Join Date: Mar 2011
Member: 1539682 Status: Offline Thanks Meter: 0 | Do you get an error when restoring in itunes? If yes, and it is 29 try irecovery. Not because it will solve the problem but because it reports more detailed about fault. For ex. it help a lot to me repporting about SWI line error. I used multimeter to find where the problem was. It could be something different with yours. |
11-04-2011, 17:43 | #49 (permalink) |
Junior Member Join Date: Nov 2011 Location: Stockholm, Sweden
Member: 1683380 Status: Offline Thanks Meter: 0 | Yeah, I got error 29 when restoring. But I managed to restore it successfully in DFU after many many times with ios5. Didn't think to check iRecovery though, sorry But can I run iRecovery now? Because it should still read bogus on the battery, right? |
11-04-2011, 19:17 | #51 (permalink) | |
This mean TP1 is test point for Light driver supply. | |
11-04-2011, 19:54 | #52 (permalink) |
Member: 1539682 Status: Offline Thanks Meter: 0 | I believe it is there where I marked it. There are TP._AP and TP._RF. APs are at the upper part of circuit (PMIC, CPU and DDRAM). Strange that Apple chose not to add these last to letters in schematics. In the block diagram they are there, of course. Yes it goes to J4 connector but there is connection to PMIC too. Still sdh: Are you sure you have cleaned the point. I had an iphone where the menu buttons functions were activated without touching the button. I found out that one TP on the back was corroded and after cleaning everything was all right. |
11-05-2011, 18:12 | #53 (permalink) |
Member: 1683380 Status: Offline Thanks Meter: 0 | I have cleaned the burned point and flex cable connections once. But I understand now that I need to do a more thourough cleaning. So I will go to the store and pick up isopropyl to do a complete pcb clean! Also, seems my multimeter is out of batteries so I will pick those up too. I appreciate your fast answers guys and I'm sorry that I can't keep up with your pace, I've had much to do. |
11-07-2011, 13:24 | #54 (permalink) |
Member: 1683380 Status: Offline Thanks Meter: 0 | Ok, I now have cleaned the entire PCB with isopropyl alcohol and I've had some success.. At first the 3gs seemed to work as normal when I plugged it in to my wall charger. It showed the correct charging symbol (the lightning bolt) and the battery percent meter increased up til about 60% and then the charging icon changed to the 'charged' icon. See image below. After this happened it went back to the old behavior of restarting time and time again while charging I also used the multimeter to test the continuity of some components. Below is the results. Note that I checked them while they were still soldered to the board. The component I've seen people refer to as the 'black diode' next to the PMIC is also OK. The strange thing is that I think one of the components on the first image did not show continuity the first time I checked it (directly after cleaning) but now it does, could it be it 'jumped' back to life? Dunno, strange though. What do you guys think the next step should be? It seems it almost is fixed as it managed to work as normal until it reached about 60% |
11-07-2011, 13:45 | #55 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | In first photo only 3 components must show continuity green fuse and 2 black filters. In second photo 2 black filters must show continuity. If capacitors show continuity that is not good,that mean shorting. Mark in a photo which capacitors short in GND. |
11-07-2011, 13:51 | #56 (permalink) |
Member: 1683380 Status: Offline Thanks Meter: 0 | The component I got different readings from kept bugging me so I did new continuity tests on it, I must have been too hasty and read it wrong. It is indeed dead! Is the next step to desolder the component and bridge the solder points or could I re-use a part from an old nokia? |
11-07-2011, 13:57 | #57 (permalink) | |
imei in 6110 | PIOTRS | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-16-1999 18:01 |
blue Display in Nokia Cellphones | TheDon | Nokia Hardware & Hardware Repair | 0 | 10-29-1999 18:28 |
New menu item in 5110 | GeoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 09-23-1999 20:24 |
Lock 2 in nokia 51xx/61xx | Pablo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-31-1999 04:35 |
