10-31-2012, 01:06 | #18 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
And i want to tell you more i meet allot of masters that know all this things about components and they buy allot of tools that are no use they can't solve small faults,i not know this what you say and i not need allot of tools to fix any hardware fault. | |
10-31-2012, 08:49 | #19 (permalink) |
Freak Poster Join Date: May 2011 Location: Netherlands
Member: 1583294 Status: Offline Thanks Meter: 27 | phone works. 2 issues left. Wifi only connects when very close to the hot-spot. battery drains very fast. over night in standby mode from 85% down to 24%. Battery suffert waterdamage as well. So a new battery will might be needed. Is a 4S battery the same as a 4 ?? (except for the metal piece on the connector) in other words can i solder the metal piece from the 4S battery on a 4 battery and test ?? |
11-01-2012, 05:23 | #21 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1679608 Status: Offline Thanks Meter: 190 | about wifi problem check the wifi antenna iphone4swifibtsignalway.jpg |
The Following 2 Users Say Thank You to air_chair256 For This Useful Post: |
11-01-2012, 11:10 | #22 (permalink) |
Member: 1583294 Status: Offline Thanks Meter: 27 | all component in the wifi area are present and look clean. Of course i can jumper the coil and the filter to have a bit more signal strength. But if they are not damaged this is not the root cause of the problem ! |
11-01-2012, 17:24 | #23 (permalink) |
Member: 1679608 Status: Offline Thanks Meter: 190 | you can check with multimeter if the coil is good or damaged if i have your problem i will change the gold antenna J2_RF and change wifi antenna iphone-4-4s-wifi-antenna-connector-port-2.jpg ip4wifi.jpg iphone-4s-bluetooth-antenna-fastening-piece.jpg if you dont have this parts and you cant change it so you can clean the wifi antenna and resolder J2_RF also resolder or replace FL10_RF your phone is water damaged i dont think wifi ic damaged so you must be sure from antenna ways Last edited by air_chair256; 11-01-2012 at 17:33. |
11-04-2012, 20:45 | #24 (permalink) |
Member: 1583294 Status: Offline Thanks Meter: 27 | although the coil and filter seemed to be ok. I have by-passed them. Now the signal level is better but still not as good as it should be. But it is acceptable. New battery works OK So repair is done. On to the next challange |
11-21-2012, 19:10 | #26 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,594 | OMG i just now see this picture you advice to jump an 220K resistor this is very bad Last edited by Wites OM Tesla; 01-19-2013 at 23:15. Reason: small mistake |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
01-20-2013, 17:33 | #28 (permalink) |
Member: 1583294 Status: Offline Thanks Meter: 27 | if you look on the complete schematics. You can count the pins on the connnector. It is de connector where the dock flex is connected on the main board. In my case there was something wrong in the dock flex. After replacing the dock flex the auto power on was solved. |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
