Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 10-10-2016, 04:22   #1 (permalink)
Member: 1790463
Sonork: SunOfRa
Thanks Meter: 2
6S Tristar vs 6 Tristar
The iPhone 6 Tristar IC is CBTL1610A2UK.
The iPhone 6S Tristar IC is CBTL1610A3UK.
Does anyone know if these are interchangeable? Can I use a CBTL1610A2UK in place of a CBTL1610A3UK?
The Following 2 Users Say Thank You to SunOfRa For This Useful Post:
Old 10-10-2016, 14:39   #2 (permalink)
Member: 2142442
Thanks Meter: 39
Yes you can, there are similar
Old 10-10-2016, 14:51   #3 (permalink)
Member: 2354080
Thanks Meter: 4
No you Can't, as i know only A1 and A2 interchangeable
Old 10-10-2016, 16:15   #4 (permalink)
Member: 2142442
Thanks Meter: 39
1610A1 works too on iphone 6s , i have try it.
1608A1 iphone 5 is not similar and dont work.
Old 10-11-2016, 11:58   #5 (permalink)
Member: 1790463
Sonork: SunOfRa
Thanks Meter: 2
thanks for the replies.
I'll just try it and see how it goes. If it doesn't work, then I'll just have to wait on the A3's to arrive.
I'll report back.
Old 10-11-2016, 19:14   #6 (permalink)
Member: 2354080
Thanks Meter: 4
I believe it will still work but i think the A1 only capable for lower current charging. Not sure as no datasheet for the chip
Old 10-12-2016, 02:18   #7 (permalink)
Member: 1790463
Sonork: SunOfRa
Thanks Meter: 2
I have just installed a 1610A2 in a 6S, and all good. Everything is working well.
Good to know.
Old 03-01-2017, 10:12   #8 (permalink)
Member: 2687403
Anyone have datasheet for iPhone U2 chips
Looking for a datasheet for any of these chips:
1610A1, A2 and/or A3
thanks
Old 03-01-2017, 19:53   #9 (permalink)
rrvius's Avatar
Member: 1821491
Sonork: Never give up
Thanks Meter: 31
A3 work for iphone 6s , 6splus, 6 ,6plus , 5s , 5c
A2 work for 6, 6plus, 5s, 5c
A1 work for 5s,5c tested solution do not use 1610a1 or 1610a2 for 6s or 6splus
And don't use 1610a1 for 6,6splus ,5s or 5c not work properly
Genuine is 1610A1 is best result for only 5s and 5c
1610A2 is best result for 6 and 6plus
1610A3 is best result for 6s and 6splus
The Following 6 Users Say Thank You to rrvius For This Useful Post:
Old 03-01-2017, 21:31   #10 (permalink)
Member: 1481974
Thanks Meter: 41
I use 1610a3 on all iphones 5s and newer. no problems
Old 03-16-2017, 09:50   #11 (permalink)
Member: 227127
Thanks Meter: 234
Anyone knows which ic use in ipad air 2? i tried 1608A1 and 1610A1 but didnt work properly.
Old 03-16-2017, 11:35   #12 (permalink)
Member: 2350837
Thanks Meter: 7
Use iphone 5s one, they both are same, amd i have tested it. Got one ipad air 2 with no charging, so i replaceed it with iphone 5s.
Check schematics, they both use same ic
The Following User Says Thank You to manubali For This Useful Post:
Old 03-16-2017, 18:20   #13 (permalink)
Member: 227127
Thanks Meter: 234
let me try. thank you so much
Old 03-16-2017, 23:58   #14 (permalink)
orx
Moderator
orx's Avatar
Member: 1825965
Thanks Meter: 522
hi
for eveyone
go here ..
Components compatibility and manufacturer's code
The Following 2 Users Say Thank You to orx For This Useful Post:
Old 03-17-2017, 01:04   #15 (permalink)
Member: 2350837
Thanks Meter: 7
try and let mw know, i am having problem with touch id, it stops when i try to add new fingerprint,
Page generated in 0.29381 seconds with 7 queries
