Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 03-02-2017, 22:17   #1 (permalink)
Member: 1481974
Thanks Meter: 42
iPhone SE fake charging
Hey guys,
I have an iphone SE here that is fake charging. I've already replaced tristar (u2) ic but same result.
It would pull 1.15A during boot and then it would drop to about 0.01-0.20.
Just not charging.
Any ideas?
Old 03-03-2017, 11:54   #2 (permalink)
Member: 2515187
Thanks Meter: 114
Hello
Check R4640 (1Kohm) replace if necessary.
Check the voltage on C4503 (5V), if missing remove Q4500 and make jumper on PIN3 to PIN2.
The Following User Says Thank You to Pallle For This Useful Post:
Old 11-24-2017, 00:39   #3 (permalink)
Member: 2018487
Thanks Meter: 2
do u have pcb diagram of the iphone se?
Old 11-27-2017, 14:12   #4 (permalink)
Crazy Poster
Member: 831155
Thanks Meter: 10
try to replaced charging flex or battery.
Old 05-13-2018, 21:27   #5 (permalink)
Member: 1514899
Thanks Meter: 49
Originally Posted by Pallle View Post
Hello
Hi,
I've problem with SE.
It's stuck at 5% charge, won't charge above 5%, seems fake charging.
Someone tried to replace the screen before I received this iphone.
I think that in my case C4503 is short.
Is there any alternative replacement I could use? I don't want to remove C4500, I'd prefer to replace C4503 with another capacitor.
I've some iphone 6, 5s motherboards so could use them as a donors.
Anybody can point me which alternatve capacitor I could use to fit C4503 ?
Many Thanks in advance.
Old 05-16-2018, 13:15   #6 (permalink)
Member: 1514899
Thanks Meter: 49
I'm sorry for another post but I've noticed FL2400 and C2400 missing near the battery connector, so soldered new one but the same, iphone se stuck at 5% and won't charge more than that. I also replaced usb flex and the same.
I reflow Q2, 1 fuse near the usb connector was loose so I soldered it back on.
Any more ideas what that could be? What else could I try? Tristar is ok.
Old 10-10-2019, 09:31   #7 (permalink)
Member: 945371
Thanks Meter: 10
I have the same problem with iPhone SE..
stuck at 5% and after one minute restart....I change U2 ic but same problem..
I check Near the battery connector and see that missing FL2400..
when i make jumper iPhone Works...
I hope to help..
Page generated in 0.16917 seconds with 9 queries
