05-20-2015, 00:52 | #1 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1889273 Status: Offline Thanks Meter: 12 | all pro techs please help to test IC i want to know when is good or bad ic i have multitester also i donwload Schematics im testing 5s u2 rf ic i have 3 questions 1.first picture i want to know what mean this red lines http://postimg.org/image/fcxqf8y0x/ 2.second picture where is the volataje of the ic for know if it good or bad http://postimg.org/image/73dd8d90z/ http://postimg.org/image/tup24dbwf/ 3. how i need to put black and red arms of multitester for test ic if is good or bad or how i need to put in pbc to test + - ground for test voltaje Last edited by inkanet; 05-20-2015 at 00:57. |
05-20-2015, 11:41 | #2 (permalink) |
Freak Poster Join Date: May 2015 Location: Ireland Age: 51
Member: 2393796 Status: Offline Thanks Meter: 10 | 1 I think that red line on the corner means the number 1 pin is there 2 all thick lines are power lines 3 use schematics to test the component it connects to like ( c50_rf 0.1UF 6.3v) if its good then it will have correct power voltage to that component from the ic main power in is where is says IN PP BATT VCC CON I am sure some one will correct me if I have it wrong. |
05-20-2015, 21:35 | #4 (permalink) |
Member: 1889273 Status: Offline Thanks Meter: 12 | like this ? u see the positive and negative ? is correct for tfest ic and appear 6.3 v mean is good when is bad nothing appear ? subir imagenes gratis Last edited by inkanet; 05-20-2015 at 21:43. |
05-20-2015, 22:12 | #5 (permalink) |
Member: 2393796 Status: Offline Thanks Meter: 10 | yes is there is a 6.3v there then should be good for that part of ic, but each one needs to be checked for correct output, so 28 ref_byp should be 6.3v and cap should be 0.1uf give or take 20% 0.8uf or 1.2uf would still be good ref_GND is ground Bad could be no power or less power than 6.3 or more power than 6.3 or short so on each leg check to see if correct output input |
05-20-2015, 22:54 | #6 (permalink) | |
Member: 1889273 Status: Offline Thanks Meter: 12 | Quote:
thanks friend for the support im learning 1.for 6.3v value need to positive red cable in IN and black cable in 28 ref_byp for out and , right? 2.for capacitor 0.1 uf need to positive red cable in IN, anf for out in ref_GND the black cable ?? | |
05-21-2015, 15:02 | #8 (permalink) |
Member: 2393796 Status: Offline Thanks Meter: 10 | where it has 1 and 2 under it where the red arrow is ? that is the side of the cap c50_rf 1 = positive and 2 = negative I am still learning to as there is so much to learn and understand everyone has to ask |
05-22-2015, 16:59 | #9 (permalink) | |
yes for capacito 1 is positive and 2 is negative = 0.1uf -and for 6.3V need to positive red cable in IN and black cable in 28 ref_byp for out ? -numerber 1 pin View image: u2 is like numeber 1 in cap or is talk about another thing? | |
